      06-11-2019, 09:15 AM   #1
XthreeMist
Drives: 2007 BMW X3 M-sport.
PROBLEM SOLVED : E83 Uphill Rattle
I have a '07 X3 M-sport automatic.
There is this rattling noise (like if you put some pennies in a dryer) from under the car, not in the engine bay. It happens when the car is on an incline (uphill) in gear or in park or in neutral or when taking off on level ground, when the car is facing downhill the noise is gone. The drives fine , no problems driving just a crazy rattling noise. If I drive in reverse then stop quickly it rattles again. It doesn't matter if the car is cold or warmed-up.
Any ideas what could cause this ?
Thanks
      06-11-2019, 09:19 AM   #2
XthreeMist
Also the rattle goes away at 40mph
      06-11-2019, 12:09 PM   #3
David0ff
Combined Applications Group
David0ff's Avatar
Drives: Lada Scrapus Trofeo R
Check exhaust heat shields
      06-11-2019, 12:27 PM   #4
XthreeMist
Thanks I will check that out.
Could it be the Torque Converter ?
      06-11-2019, 05:29 PM   #5
David0ff
David0ff's Avatar
Take a video it would be easier
I don't think it's the torque converter from what you describe
      07-10-2019, 02:23 AM   #6
r_1
Drives: e83,e46,e24,e30,e36,e39
hidden rattle
There is a shied attached to the bottom of the gas tank with three clips. The parts list says its not used after 2004 but 2007 had it. Drove me crazy. Took it out! Also found both U-joints gone at 140k, this was causing shudder when accelerating from a stop.
      09-23-2019, 09:15 PM   #7
XthreeMist
UPDATE: Problem SOLVED!!
The rattle was caused by the starter having a loose gear shaft , every time I went uphill the starter gear would slide towards the flywheel teeth making a rattling noise (like having nuts/bolts in a washing/dryer machine going round and round).
Replaced the starter , problem solved.
David0ff1056.00
      11-02-2023, 01:50 AM   #8
E83Nate
E83 Nate
E83Nate's Avatar
Drives: 04 bmw x3
Omg I have been dealing with that same stupid noise for a few years now! Drove me nuts! Nobody else heard it, couldn't find what was actually making th rattle, couldn't find anything online about it. Just had to do a transmission swap so while I was in there I took a closer look. My flex plates teeth were worn from the starter bendix not retracting fully and making that metal ball bearing In a can rattle... xthreeMist did you go in from the top or bottom? It's gotta be a Mother #&*$%× of a job to? No room anywhere and it's buried about a much as it could be! Any hints and or tips? TIA.
      11-08-2023, 04:33 AM   #9
GT4560
Drives: X3 1st Gen (456)
Replacing the starter is a pain period... Doable but still a pain. I've done it always from above which calls for removing the intake. If it's below your 4th time doing the job assume nothing, take pictures and have a boat load of patience. Over the weekend you'll be back driving to work on Monday.
