      05-16-2019, 08:03 PM   #1
pungo
pungo's Avatar
LED foglights for pre-LCI
Looking at some of the aftermarket LED fog light assemblies for a 2011. Came across these on ebay. Anyone have any experience with them?
Or is it better to retrofit a LCI LED fog? What else is needed besides the LED assembly? I was reading somewhere that the bracket for the assembly is different. Not sure about the wiring connector or light module coding. Has anyone put LCI fogs in their pre-LCI?
Hoping to increase lighting to the sides of the road on the narrow dark country roads I drive on.
Ebay Fog Light Link
      05-22-2019, 12:55 AM   #2
g2423_1
Drives: BMW X3
The wiring is plug and play but you need to code lighting module or else it will flicker
      05-23-2019, 06:39 AM   #3
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Pre-LCI and LCI fog lights are not interchangeable. They mount differently. You'd need to go with LED bulbs for stock fog light housing. Make sure to get error-free LED bulbs or you'll need error-free resistor harnesses. Optionally, coding to remove the error.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      05-23-2019, 07:24 PM   #4
pungo
pungo's Avatar
The aftermarket ones I linked in the first post says they fit 2011 model. I read that LCI ones will work but the LCI mounting brackets are required. Either way, I plan to code out the error.
My question is has anyone had any experience with these aftermarket LED fogs I linked?
      05-27-2019, 10:21 AM   #5
x3sm
x3sm's Avatar
282
Drives: M3 E93 Porsche
I have LED LCI on my 2011 X3, I have the whole front end converted. These fogs flicker, I coded them out, but they still flicker, I changed the input in FRM to "LED BulB" and they still flicker. I bought some LED resistors, but had no time to plug them in yet since you have to remove the bumper, and fender flares.
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      05-28-2019, 10:36 PM   #6
pungo
pungo's Avatar
Sucks you spent the effort to change to full LCI front and got flickering fogs. Wonder if there's some other coding besides what you already tried that will eliminate the flicker. If you do get the flickering to stop, let use know what worked.
      05-29-2019, 06:22 PM   #7
x3sm
x3sm's Avatar
282
Yeah, it's not a big deal though. I never really use the fog lights. Plus I'm 100% sure the resistors will work. I have read that people on the F30 forum code their FRM when they change to LED bulbs in fogs and it works, but someone suggested that it's easier just to plug in some resistors
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      06-08-2019, 07:39 PM   #8
pungo
pungo's Avatar
You changed the bracket that holds the fog light? Do you have the part number?
      07-26-2019, 12:34 PM   #9
x3sm
x3sm's Avatar
282
So I got some pnp resistors for my fogs and that did not work, the fog lights did not even turn on with resisters in place. I coded and still they flicker.
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      07-26-2019, 08:09 PM   #10
pungo
pungo's Avatar
What exactly did you code?
FRM>3090>AUSG_11_NSW_L_IS_LED>aktiv
FRM>3090>AUSG_12_NSW_R_IS_LED>aktiv
      07-27-2019, 09:13 AM   #11
Mpw2081
Drives: X3 sDrive
Can anybody recommend led bulb upgrades for DRL lights on x3 sdrive version
      07-28-2019, 05:53 PM   #12
x3sm
x3sm's Avatar
282
That is the first thing I did and they still flicker
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      09-01-2019, 07:24 AM   #13
Lorenas
Drives: BMW X3
Hi! I have retrofitted (for mine 2015 f25 LCI) genuine LED front antifogs, coded (bimmercode) lamps for LED and cold/warm check has been disabled as well. No error codes, though flickering starts after some 20seconds. It needs some deeper coding in expert mode. I found some coding ideas but with that was with ESys. Any ideas how to solve situation with Bimmercode?
      09-03-2019, 02:09 AM   #14
Lorenas
Drives: BMW X3
As I have mentioned before after retrofitting genuine LED fog lights, coded with BimmerCode for LED lamps also warm and cold check on nonexpert mode. Error messages gone but flickering after some 20sec from start was a problem to deal with. With some help from BimmerCode team and some tinkering I have now working trouble free original LED fogs. See coding below.
In my case besides of:
NSW_L_KALTUEBERWACHUNG » nicht_aktiv
NSW_L_WARMUEBERWACHUNG » nicht_aktiv
NSW_L_KURZSCHLUSS » nicht_aktiv
NSW_L_IS_LED » aktiv
NSW_R_KALTUEBERWACHUNG » nicht_aktiv
NSW_R_WARMUEBERWACHUNG » nicht_aktiv
NSW_R_KURZSCHLUSS » nicht_aktiv
NSW_R_IS_LED » aktiv
Needed to code this:
AUSG_12_NSW_R_VORGLUEHEN_AKTIV aktiv>>nicht aktiv
Same thing with
AUSG_12_NSW_L_VORGLUEHEN_AKTIV aktiv >>nicht altiv
Update: it looks like flickering’s gone while fog lights come with low beam. If turn on position lights with fog lights (rings + fogs) then flickering starts after a while). I will check and update if I find coding.
      09-04-2019, 01:55 AM   #15
Lorenas
Drives: BMW X3
Tried many things yesterday but it looks was needed to code U_EFF_NSW
In my case it has been set to 13,4v and there were 2 other options: 100% or 13v. I have set on 100% and now it is not flickering anymore. If you have comments on this, please respond.
      09-05-2019, 08:54 PM   #16
x3sm
x3sm's Avatar
282
WOW! Thank you so much for all the info, I will code it all and report back
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      09-07-2019, 07:53 AM   #17
hogwldfltr
Drives: X3 35i Xdrive
What has been used as bulb replacement and harness upgrade without the need for coding on a pre-facelift model? Thanks!
      09-11-2019, 01:01 AM   #18
Lorenas
Drives: BMW X3
In my case (F25 LCI) it looks like this now:
AUSG_11(12)_NSW_EINSCHALTSTROMRED.. aktiv 0x01
AUSG_11(12)_NSW_L(R)_IS_LED aktiv 0x01
AUSG_11(12)_NSW_L(R)_IS_INDICATOR nicht_aktiv 0x00
AUSG_11(12)_NSW_L_(R)_IS_XENON nicht_aktiv 0x00
AUSG_11(12)_NSW_L_(R)_KALT_UEBERW_AKTIV nicht_aktiv_vor_lci 0x00 nicht_aktiv_ab_lci 0x00
AUSG_11(12)_NSW_L(R)_KURZSCHLUSS wert_01 0x9A
AUSG_11(12)_NSW_L(R)_OPENLOAD wert_01 0x1E
AUSG_11(12)_NSW_L(R)_PART_OPENLOAD wert_01 0x7F
AUSG_11(12)_NSW_L(R)_VORGLUEHEN_AKTIV nicht_aktiv 0x00
AUSG_11(12)_NSW_L(R)_WARM_UBERW-AKTIV nicht_aktiv_vor_lci 0x00 nicht_aktiv_ab_lci 0x00
DUAL_SPG_AKTIV_NSW nicht_aktiv 0x00
FLB_NSW nicht_aktiv 0x00
DUAL-DUMP_SCHUTZ_NSW aktiv 0x01
NSW_AUS_BEI_FL nicht_aktiv 0x00
U_EFF_NSW wert_02__100% 0x32
WL_FUNKTION_NSW nicht_aktiv 0x00
I hope everybody understands what I mean 11(12) or L(R) - just did not want to expand everything double that size. Also I want to say that I didn’t post this unless was waiting for response from BimmerCode, though after request fro one of members I share it here. It works ok, though I am not sure how bright should it be. Anyway, flickering is gone. Note: my car is without cornering lights function. This is purely my experience which I share and would not take any responsibility if anything goes wrong while you coding your car yourself. Always use backup restore function if something is not working after coding.
      09-11-2019, 02:19 PM   #19
x3sm
x3sm's Avatar
282
Thanks, looks like mine worked.
Do you know how to turn on Fog Lights as Daytime Running Lights?
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      09-11-2019, 02:50 PM   #20
Lorenas
Drives: BMW X3
Can’t say about fogs for DRL. Should be somewhere. Ask BimmerCode team for a hint.
      09-13-2019, 10:18 AM   #21
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
Thanks for this worked like a charm.
After 2 years i can now use my foglights without flickering
      09-14-2019, 11:54 PM   #22
willywi
Drives: BMW x3, BMW x5
Wow, after coding "U_EFF_NSW wert_02__100% 0x32" the lights no longer flicker.
