03-04-2024, 05:17 AM | #1 |
Rep 272
Bootmod3 XHP and factory torque Limit
I am not sure why this is not discussed widely before. I may have seen some posts mentioning in the m340 forum, but only slightly related
TLDR: For those that have Bootmod3 and stage 2 or higher engine tune, you may really need the XHP to lift the torque limit to fully harvest the additional power. If you don't, the torque is gonna be limited <550nm all the way (under LC, it's even <500nm), while stg2 torque can easily go beyond 620nm. ============================= Before XHP, I had been running stage 2 93 on a 2020 model for a few weeks. One thing I noticed is that the boost target and boost, when doing a 3rd gear WOT pull, was only around 16-17 psi at < 6000 rpm. This is as low as the stock boost, and much lower than the ACN91 boost (which is all the way >20 and boost target is 22.4). I was confused why stg 2 93 was so much more conservative than stg 1 ACN 91. It made no sense to me. Although with stg 2 93 the car certainly runs faster, but the displayed "torque actual / target after clutch" is merely <550nm, while the torque predrivedynamics is 670nm. This is abnormal since with stock tune or ACN91 stg 1, these 3 torque values are within 30 nm different. Also these estimated torque values should be relatively accurate when compared between maps, meaning a 20% gain in these values should reflect on a real dyno run. The facts are implying that the engine held up power somehow while it could do much better. I have asked ptf but they didn't find anything wrong, or explain the reasons why torque is limited https://www.bootmod3.net/log?id=65dd...bc901ce26e3fe6 ====================== And then I installed the XHP. I didn't even purchase the TCU map and was just trying out basic settings to fine tune shift behavior. And then immediately I did a BM3 stg 2 93log with updated XHP settings, and the car felt obviously faster. Upon checking the log I realized now the torque can easily go above 550nm, reaching 650nm easily. And boost target was right on at a constant 22.4 with actual boost 21-23 mostly. I then did a 0-100 pull. Guess what, even with the wet road under the rain and an entire wheel spinning 1 st gear, it did 0-100 (62mph) in 3.68s, easily beating smoking the fastest time I did before XHP on perfect road 3.97s. https://www.bootmod3.net/log?id=65e5...912436fb2ff41a Now things make sense. Somehow the BM3 stg2 93 map did not remove the torque limit inherently from ZF8HP51. It achieved this by pre-calculate how much boost it should reduce, and apply the different boost target curve when you do the pull. Every pull is very repeatable and you won't find a sign that it cuts off power abruptly because DME redefines the curve in advance. So it is still confusing why PFT did not make a simple switch in BM3 so you can switch off the global or by gear torque limit (it does allow you to further REDUCE torque, though). From what I know, if you get a custom tune, your tuner should be able to control if the torque limiter is active, and for that reason, a lot of people sing custom tune do not need to resort to XHP to release the hidden torque. If you stick with OTS BM3, this is a must If you want to use true stage 2 or even Ethanol maps. And maybe this is B58TU specific issue? But anyway if not for XHP I would never realize what the true power of BM3 OTS map. |
03-04-2024, 07:14 AM | #2 |
Cowboy Astronaut Millionaire
2420
Rep 2,975
Cool write up. So you need XHP with BM3 OTS. But my custom tune does not.
What B58 engine code do you have on your 2020?
earlgsxbusa130.50 |
03-04-2024, 09:59 AM | #3 |
BM3 Tuner
736
Rep 538
You really need xHP on both, when you bypass those torque limits on the trans it can cause traction control and a few other things not to properly.
2019 BMW X3M40I
Paul Johnson Tunes/ACX Solutions Shop/Development Car, XHP stage 3 with custom settings, CTS Downpipe, intake, Chargepipe, turbo inlet, coils, Nostrum Stage 1 Injectors and Nostrum Big Bore HPFP, Vargas PCV and Oil cap, HnR springs, ACX Rear poly bushing, ACX Intake scoop |
earlgsxbusa130.50 |
03-04-2024, 03:53 PM | #4 | |
Rep 272
In BM3 it's listed as B58-TO-D. Not sure what code type this is . It is commonly referred to as B58M30O1, the one with 382hp rated. |
03-04-2024, 03:57 PM | #5 | |
2420
Rep 2,975
03-04-2024, 03:59 PM | #6 |
2420
Rep 2,975
Right on. I haven’t adjusted anything on XHP. Just stage 3. Set it and forget it. Summer setup and maintenance coming in a few weeks.
03-04-2024, 05:06 PM | #7 | |
Rep 272
bTW, what oil do you use after you got the tunes? |
03-05-2024, 07:37 AM | #8 | |
2420
Rep 2,975
Oil I use is Liqui Moly 0W20 Top Tec 6600. In the summer every 5K miles. And in the winter every 7K miles.
earlgsxbusa130.50 vrships109.00 |
03-05-2024, 04:16 PM | #9 | |
Rep 272
03-05-2024, 04:19 PM | #10 |
2420
Rep 2,975
Quarter mile at a time. 😁
03-05-2024, 07:11 PM | #11 | |
Rep 341
03-05-2024, 07:22 PM | #12 |
BM3 Tuner
736
Rep 538
I used 5w-40 and honestly it burns less oil and the engine sounds better. I’d look at EU approved weights.
2019 BMW X3M40I
03-06-2024, 01:23 AM | #13 | |
Rep 272
That's almost 6 psi boost gain for low to mid range rpm, and 100 Nm torque too. Which amounts to at least 0.4s 0-100 time repeated many times. |
Rottweiler4333.00 joebie3458.50 |
03-06-2024, 02:42 AM | #15 |
Rep 272
03-06-2024, 08:01 AM | #16 |
BM3 Tuner
736
Rep 538
My foot ruins my mpg more than oil does😂😂
2019 BMW X3M40I
03-06-2024, 08:39 AM | #18 |
BM3 Tuner
736
Rep 538
2019 BMW X3M40I
Alias1431806.50 |
03-06-2024, 08:40 AM | #19 |
BM3 Tuner
736
Rep 538
Doesn’t matter the order, I’d do both at the same time, make sure to cycle ign or it will fail the second flash
2019 BMW X3M40I
03-06-2024, 09:01 AM | #20 |
Rep 341
I didn't see any log here. Without knowing how your AFR, Timing and most importantly whether you're getting any knock retard is more important than just turning up boost.
03-06-2024, 11:05 AM | #21 | |
Captain (Retired)
4333
Rep 1,858
https://www.bootmod3.net/log?id=65dd...bc901ce26e3fe6 |
03-06-2024, 12:30 PM | #22 |
2420
Rep 2,975
This was before XHP existed on the M40i. I can show you the time stamp of the datalog. So no XHP installed at all here...
