      03-21-2024, 09:57 AM   #1
Canuck714
Drives: 2021 X3MC Black
Brake Service
Hello All,
Just rolling into 50k miles on the 2021 X3MC and the Brake fluid service light has appeared. Was thinking it was probably time for rotors and pads as well.
Do most people do their own service or is this something that has to go to the shop to reset or program sensors?
Normally I would order parts and do myself, but figured I would ask the experts before just jumping in. I was told by a trusted buddy from the Porsche club to stick with OEM rotors as he tried aftermarket in the past and was not happy with performance.
Any advice is appreciated.
      03-21-2024, 10:57 AM   #2
Th3Walrus
Drives: 2020 X3MC Alpine White/Sahkir
You can easily do it yourself. Is this the first time your fronts are being done? My 2020 I just picked up already needed new front rotors (as part of the safety) at only 28k miles, they were at the min. thickness already.
      03-21-2024, 12:37 PM   #3
TacosRule!
TacosRule!'s Avatar
606
Drives: 2022 X3M
This dude has aftermarket rotors and says they work great. I'm planning on going this route as well
https://x3.xbimmers.com/forums/showp...7&postcount=37
      03-21-2024, 01:48 PM   #4
Th3Walrus
You can get the complete kit with the 5000 series pads here, currently $333:
https://www.rockauto.com/en/moreinfo...13824&jsn=1420
      03-21-2024, 02:43 PM   #5
Canuck714
First set of rotors, its the wife's car so not pounded too hard.
out the OEM rotors and they are very proud of them..lol Big $$
      03-21-2024, 06:29 PM   #6
Kevin_The_Clean1
Kevin_The_Clean1's Avatar
Drives: 2020 X3 MC
Those rotors look pretty good. Can you order just the rotors alone... ? Or is this just a kit... ?
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten
2011 E90 335i M-Sport - Daily Driver
2017 F87 M2 - Sold & missed
2020 F97 X3 M Competition - Finally arrived ///
      03-22-2024, 05:40 AM   #7
Th3Walrus
Apparently Dynamic Friction is the same as R1 Concepts.
Bottom right click on the info button, you can order the rotors alone. $136 each.
They have cheaper ones that aren't coated for $120, but get the coated ones, the hub will stay clean longer.
I've run multiple sets of the Power Stop from Rock Auto with zero issues and I drive hard, but they don't make them for the X3M. I'm tempted to try these when I need them. Me being in Canada, the dealer wants $750+ per rotor.
      03-22-2024, 12:14 PM   #8
Canuck714
I decided to go with OEM rotors. Not cheap, but I know what I am getting..lol
      03-22-2024, 05:08 PM   #9
Edgar_FriendlyX3M
Edgar_FriendlyX3M's Avatar
Drives: 2020 BMW X3M
2020 BMW X3 M  [10.00]
...an expensive bill
      03-22-2024, 05:10 PM   #10
knali8
knali8's Avatar
Australia
429
Drives: 2021 X3M Comp
This does sound good thanks for sharing. Wouldn't mind giving this a try when the time comes!
      03-23-2024, 09:52 AM   #11
evoix
Drives: X3m Evo IX Evo X
Can we throw out some numbers in terms of prices instead of saying big money lol. Maybe this will help others who are overpaying at some places
      03-26-2024, 08:24 AM   #12
R0ot.Us3r
I don't want to know the Price of Gas
R0ot.Us3r's Avatar
229
Drives: 2023 X3 MC
2023 BMW X3MC  [10.00]
I'm at like 35K; I've not gotten a brake pad replacement notification and the dealership says their fine (I got the maintenance plan - sue me), is that not odd? I personally start to get antsy at 20K
      03-26-2024, 08:29 AM   #13
Th3Walrus
You get 2 notifications - one based on time/odometer which is likely the one you got, and then an actual warning once the pad sensor trips.
      03-26-2024, 09:02 AM   #14
pyo
Drives: 2022 X3MC
You should be fine. The sensors trip when its below 3mm. Need to drive harder
I just got my rear pads replaced at 26.5k under Ultimate Care+. The front pads still had 6mm inner and 7mm outer on the drivers side wheel. Front rotors were 35.2mm (min is 34.4mm) and rear rotors were 23.1mm (min is 22.4mm).
This is with 2 track attack days at Dominion Raceway and 2 HPDEs at Summit Point...
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
R0ot.Us3r228.50
      03-26-2024, 10:05 AM   #15
Th3Walrus
Q.. in your iDrive under vehicle status/service required, does it even list the front & rear brake pads? Mine doesn't, it just lists engine oil, brake fluid, and I think vehicle inspection.
My previous 340i and my wife's '19 Countryman list the pads and when it thinks they are due.
      03-26-2024, 10:18 AM   #16
Potatohead-M2
Potatohead-M2's Avatar
216
Drives: X3MC
My 2021 is the same. I believe either the pads don't show until the sensor is tripped or it's a iDrive 7/LCI thing.
Th3Walrus340.50
      03-26-2024, 10:30 AM   #17
pyo
Drives: 2022 X3MC
It won't show until it is tripped. Once it tripped, it specifically said my rear pads needed to be replaced.
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
      03-26-2024, 01:29 PM   #18
TacosRule!
TacosRule!'s Avatar
606
Drives: 2022 X3M
Dude you need to tell me who your dealer is. My local wont even look at them until the light is tripped...
I really dislike my local shop.
      03-26-2024, 01:40 PM   #19
pyo
Drives: 2022 X3MC
To be clear, only my rear pads were replaced since the sensor tripped. They did not touch the front pads or both rotors, since they are above thresholds.
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
      03-27-2024, 07:36 PM   #20
bloom
bloom's Avatar
15
Drives: none
Does your rotor have an edge showing around the perimeter since it’s so worn? My pads are gunna pop any day now
