11-28-2023, 11:43 AM | #1 |
Rep 10
X3m competition oil leak
2020 x3 M, 50k miles. Discovered the oil leak recently.
Anyone has the same issue and being fixed before? Thanks Update: Job finished by dealer today. They stated it was oil pan leak. They replaced the entire oil pan.not sure if it is necceary but they did it. Will drive around and see how it holds up. Last edited by zhoubowei008; 01-04-2024 at 02:01 PM.. |
11-28-2023, 12:18 PM | #2 | |
Need mo $$s
983
Rep 984
That's a mess...
2020 TRM-BLACK X4///M Competition
1995 Dodge Stealth TwinTurbo Past: 2020 Macan, 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
11-28-2023, 03:24 PM | #3 |
Rep 214
That is the pits.... No leaks here after 58K. Not heard of anyone else having one actually in an F97/98. You've probably already done this, but I would clean and degrease all of that. Then put a good day of driving in, let it sit overnight and then look again in the morning.
On a side note.....My old f06 N63TU was an oil leaking machine.... After 40k the leaks started and then about every 10K (miles) I'd degrease and search out the new leaks that would sprout up. I had gaskets, vacuum lines etc. The only worse leaker I've ever owned was my daughter's 2009 R56 mini.... That little beauty sprung a new leak almost as often and I had to replace coils...... |
11-28-2023, 03:30 PM | #4 |
Rep 381
An oil leak on a BMW? SHocked...lol
Alright sorry, but I had to. As poster above mentioned, clean the area and then re-inspect or fill with liquimoly molygen oil and check with a blacklight. Unfortunately leaks are not uncommon, they just go unnoticed as its seeping onto the undercovers. Common s58 leak areas include oil filter housing, valve covers, and timing covers. |
11-28-2023, 03:57 PM | #5 | |
Rep 214
11-28-2023, 04:14 PM | #6 | |
Rep 381
The B58 is starting to behave the way older models leaked and I wouldn't expect the s58 to be any different as the use of plastic parts persists and the platform ages. |
11-28-2023, 04:23 PM | #7 | |
Rep 214
I've read this as well: https://lifeonfour.co/engine-problem...e-reliability/ |
e30 4 life!299.50 |
11-28-2023, 05:30 PM | #8 |
DisplacementReplacement
625
Rep 1,304
Hopefully this is not a sign of things to come, i have bad memories with my N54. My N55 and B58 were both "leak" free so i'm hoping for the same on this thing, cross our fingers this is not an "itis".
2020 X3M /// MHD Tune
2017 240XI Hybrid Turbo / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 2007 328XI Stock Last edited by Jnat; 11-29-2023 at 04:31 AM.. |
11-28-2023, 09:40 PM | #9 |
Rep 4,385
Looks like the rear main seal. But I could be wrong.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
11-29-2023, 06:10 AM | #10 |
Rep 396
Drives: 2014 STI - 2020 X3MC
Kevin_The_Clean13868.00 |
11-29-2023, 07:48 AM | #11 |
Rep 1,412
Can you see where the oil is leaking from or can it be residual from possibly the oil filter housing?
When I go in for an oil change I have to come home and clean under my X3m. The dealers no longer take pride in wiping down any residual oil from runoff or spillage. |
11-29-2023, 10:36 PM | #12 |
Rep 10
Took to the dealer few days ago, they do not know…. They said something
Leak came out from transfer case and may need to replace transfer case and transmission….. Car will go back in to dealer again for 1 week for repair. Car is still under warranty. But I’m very worried after they remove many parts they can break some thing else. Not happy……….. |
cfm56d7b6358.00 |
11-29-2023, 10:41 PM | #13 | |
Rep 10
11-30-2023, 08:49 AM | #14 | |
Rep 214
They found all this oil leaking, which appears to be a significant leak, but then could not find the leak. Then the dealer mentioned the leak is coming from the transfer case ??? They then said they may need to replace the Transfer case and the Transmission and then they sent you home with it? I'm sorry, something about this just seems off. You may have the world's worst dealer service department. |
DBU236.50 |
11-30-2023, 01:05 PM | #15 | |
Rep 10
I have to go back to dealer again, then they will keep the car for the repair for 1 to 2 weeks. Dealer said BMW usually ask to replace the entire unit if they can not find where the leak is. |
11-30-2023, 01:17 PM | #16 | |
Rep 214
Any oil leak can be tracked down using dye and UV light. |
DBU236.50 |
12-14-2023, 09:21 AM | #17 | |
Rep 214
Thanks! |
12-15-2023, 03:43 PM | #18 |
Rep 407
Drives: 2022 X4MC - Marina Bay Blue
Is that the oil drain plug I see there?? Did someone leave it a bit loose??
'22 ///X4M Competition - fully loaded Marina Bay Blue.
Lowered on MSS springs. 20" x 10 ET20 Vertini RFS1.2 wheels wrapped in Firestone Indy 500 Firehawk 275/40 tires (square setup). Hers: '15 X4 2.8i - Glacier Silver - loaded M-Sport |
12-18-2023, 12:42 PM | #19 | |
Rep 11,726
e30 4 life!299.50 joebie3458.50 |
12-27-2023, 11:12 AM | #21 |
Rep 11,726
12-28-2023, 12:30 PM | #22 | |
Rep 10,625
