      09-18-2018, 07:29 AM   #1
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
Downpipe Dilemma
I tried to install a VRSF catless downpipe over the weekend but my plans were foiled by a very mean and evil person at the BMW plant who decided to tac weld the lower clamp to the exhaust.
Any suggestions on what to do? I do not really want to use a cutoff wheel because I then run the risk of gashing the exhaust.
If I loosen the clamp all the way, should I be able just to push the stock downpipe up so the smaller end of the downpipe is freed from the exhaust?
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      09-18-2018, 08:28 AM   #2
E90705
E90705's Avatar
Drives: E90/F25 M-sport
For some reason I don't think that spot weld is welded to the DP as the mid pipe goes over or slides over the oem DP. As it looks similar to mine.
TheCoolX3173.50
      09-18-2018, 08:32 AM   #3
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
The clamp can stay as it is. Remove the first hanger bolt behind it holding the exhaust to the chassis to be able to pivot and lower the front of the whole setup, so that you'll have room to get the DP out.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
TheCoolX3173.50
      09-18-2018, 08:53 AM   #4
E90705
E90705's Avatar
Should be looking like this in no time
TheCoolX3173.50
      09-18-2018, 09:40 AM   #5
TheCoolX3
E90705 hardparker
Thank you so much guys! Ill give it another go this week and let you guys know how it goes
      09-18-2018, 10:55 AM   #6
E90705
E90705's Avatar
No problem, I also reused the oem hardware (turbo gasket, exhaust bolt & clamp, v-band clamp). But I had new ones on hand ready to go as I thought they would be rusted out but original was still good.
      09-18-2018, 11:36 AM   #7
TheCoolX3
Okay sounds good. My car is only 2 years old and has not been exposed to salt on the winter roads in the north so they should not be rusted I hope!
      09-22-2018, 07:00 AM   #8
TheCoolX3
I installed downpipe yesterday, car sounds so much better now! thank you for the advice!
hardparker E90705
      02-25-2023, 01:04 PM   #9
archangel24z
Drives: BMW x4 35I M-Kit
TheCoolX3
is your x3 with EWG or PWG, im searching for a downpipe for my x4 35i with EWG, but all I find is specific for PWG.
