04-01-2020, 11:57 AM | #1 |
Rep 100
Downpipe regret?
Has anyone gotten a catless do and wish they got a catted one or vice versa? About to order a vrsf but can't make up my mind on which one
04-01-2020, 12:05 PM | #2 |
Rep 1,123
For what it's worth, I went catless on a Trans Am...couldn't take the fuel smell. I would only go performance cat...my 2 cents.
04-01-2020, 12:16 PM | #3 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Im not fully answering your questions but I ordered a catted DP. Its sitting my my garage for about a month now. I am debating if I want to deal with a check engine light, until a tune is available to clear it.
Chief Orman671.00 |
04-01-2020, 02:01 PM | #4 |
Rep 568
Had vrsf catted and the cats blew out (likely due to burbles .. stock burbles at that) so I removed my downpipe and gutted the cats and now I have a catted-to-catless converted downpipe. if you don't mind the smell when stopped I think it's worth the extra sound and money saving but that's just me.
18 X3 M40i/ Dark Graphite/ Cognac/ MP ECU Stage 2.5
04-01-2020, 11:33 PM | #5 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,207
I have VRSF Catted Downpipe. I can smell it some times if I'm getting rowdy in sport with burbles and high RPM stuff. It's enough for smell for me alone with Catted. I couldn't imagine what catless would be like. I smell some cars in the shop with catless though and i really dislike it
04-02-2020, 05:23 PM | #6 | |
Rep 728
I've done catless DPs with welded race cats on my X5M. It was terrible without the cats. With the 200 cell race cats there was still smell but wasn't awful. I recommend just getting DPs with hi flow cats in them to save any hassle.
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs |
04-03-2020, 01:44 AM | #7 |
Rep 306
Even if there's a tune to clear the code, will you be able to pass emissions when it comes time for inspection? I ask cause in NYC once you have a CEL light you won't be able to pass
2020 BMW X3 M40i (stock)
Chief Orman671.00 |
04-03-2020, 07:09 AM | #8 | |
Rep 72
1) My car was getting custom dyno tuned, so catless will give more flexibility and more power 2) Makes your exhaust louder 3) You can definitely hear turbo spool 4) It's cheaper than a catted version Downside, only one, the fume smell but you quickly get used to it. |
Chief Orman671.00 |
04-03-2020, 07:25 PM | #9 | |
3511
Rep 4,207
Chief Orman671.00 |
04-04-2020, 07:15 PM | #10 |
Rep 312
Drives: 2019 x3 M40i
I go back and forth. I got the ER catted pipe and it sounds great. noticeable increase over stock without being overly loud. There is a very minor change in odor with the exhaust because there is less cat surface area, but not like catless and only when cold. I still get the CEL after about 15 min of driving so have to code it out or use a spacer (i'll try later on). I'm starting to waffle a bit on if I did the right thing on getting catted. am unhappy? no. but i've never had catless cars and I'm starting to think i'd want to try it even if for a little while. Like above, if my cat fails I'll just punch it out and run gutted for a bit and see if I want it replaced, but I don't regret the extra expense of getting catted or getting ER. I'm happy, just curious about the other side.
Chief Orman671.00 |
04-04-2020, 08:14 PM | #11 | |
3511
Rep 4,207
Chief Orman671.00 |
04-04-2020, 09:56 PM | #12 | |
Rep 82
OP... no regret at all except for the smell. I love it. |
04-05-2020, 11:32 AM | #13 |
Rep 1,044
Been in an X3M40i with no cats. Phew! Not worth it. It's not a race car.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
Chief Orman671.00 |
04-06-2020, 04:01 AM | #14 |
Rep 568
Smell is definitely stronger with windows down but unchanged with windows up. Sound is definitely much better as far as tone and volume which is what I care most about. Couldn't tell much difference in performance as far as when my cats were still functional. I was getting hiccups however when my cats were all dislodged in the downpipe.
04-06-2020, 03:39 PM | #15 |
Rep 114
So would you do a bootmod3 without a downpipe mod?
So my big question is: Would you do the bootmod3 without the Downpipe mod? Is it even worth it or not?
Chief Orman671.00 |
04-07-2020, 06:12 PM | #16 |
Rep 13
Been running catless for months now with no regrets. The smell of fumes is definitely there when I start up in the garage. Really depends on the individual if it’ll bother them. I ran catless on my G35 for over 6 years, so it doesn’t bother me at all.
04-07-2020, 06:18 PM | #17 |
3511
Rep 4,207
I don't personally have tune but you can do stage 1 with stock everything. Stage 2 and up is where you really want to have at least a Downpipe for the tune to really take advantage of the no restriction used by the cat
05-20-2022, 11:40 PM | #20 | |
Rep 1,442
Does the stock B58 gen 2 have a more restrictive cat than the stock gen 1? Sounds like BMW tightened up emissions on the gen 2. Anyone running catless with a pure E85 setup? I assume this would take care of the fumes issue. |
05-20-2022, 11:56 PM | #21 | ||
3511
Rep 4,207
Chief Orman671.00 |
05-21-2022, 09:12 PM | #22 |
Rep 2,067
With catless AA DP enroute, shortly will have first hand experience of the level of stink this will be (for the wife). Hopefully as mentioned already the higher E blend may help to offset the smell. Does seem to, with 200 cell cats from HJS running E85.
Then again, read somewhere that higher E blends can, has possibility of killin catts, so yeah... |
Chief Orman671.00 Eris496219.50 |
