03-30-2019, 09:35 AM | #2 |
Rep 85
this is why always protect your paint with some sealant and/or ceramic coatings.
Best way to repair at this point would be wet sanding + light compound/polishing. |
03-30-2019, 09:46 AM | #3 | |
Lurker
148
Rep 97
Ymmv |
03-30-2019, 09:47 AM | #4 |
Rep 46
03-30-2019, 09:48 AM | #5 | |
Rep 179
03-30-2019, 11:18 AM | #7 |
Rep 893
I have always had good luck using "Meguiar’s Water Spot Remover – Water Stain Remover and Polish for All Hard Surfaces" for anything that is difficult to remove from my paint.
https://www.amazon.com/Meguiars-A371.../dp/B009OBVS2K I always just use Optimum Car Wax to help protect my cars and have had good luck with it too. https://www.amazon.com/Optimum-SW200.../dp/B00GG9FI8I |
03-30-2019, 12:00 PM | #8 |
Rep 8,030
Drives: 2024 X5 M60i
Have you tried using a clay bar?
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
03-30-2019, 01:10 PM | #9 |
Rep 179
Probably looking at a 1 stage machine polish. If you don't want a full ceramic detail you could just give the whole car a hand polish and ceramic wax like angle wax enigma.
03-30-2019, 02:58 PM | #11 |
Rep 467
chicagofan0019143.00 IM_ALL_IN57.00 |
03-30-2019, 03:30 PM | #12 |
Rep 211
The Protect X system is much maligned and I agree it is usually overpriced and does not provide anywhere near the protection a ceramic or similar coating will provide BUT, the fact you had Protect X applied to you car should allow you now to tap into the benefit it DOES provide over after market applications - namely the 'insurance / guarantee' element. When I had bird poo attack the clearcoat on my last X3, (when I left it in an airport carpark whilst on holiday for 2 weeks) I took it straight into my local dealer and they honoured the Protect X protection promise and completely fixed the damage to 'as new' F.O.C. Certainly worth exploring this route 1st I would suggest.
03-30-2019, 03:43 PM | #13 |
Rep 969
Not a stain -- it etched the clear coat. I just had this happen to my X3 and it happened in a matter of hours. Car was clean at lunch. At quitting time I came out, saw the mess and wiped it off, but the damage was done.
I was able to buff it to my satisfaction with 3M scratch remover, which is a polishing compound that is about a "4" on the scale of aggressiveness. Use a foam pad and do it by hand. You can make multiple applications of this until the etching is polished out to your satisfaction, and don't be afraid to put some pressure into it. I followed that up with #3 and #1 Meguiars polish then re-waxed the area with Klasse. BTW, even the best ceramic coatings can't prevent this damage, although they might buy you an extra hour. No reputable product will claim to prevent damage from bird drippings (if they do, laugh and look elsewhere). Bird droppings are highly acidic and can pretty much burn through any protective layer. |
03-30-2019, 04:26 PM | #14 |
Rep 6,248
I feel your pain!
On Monday this week, I came out to my Carbon Black G01 to see 6 giant bird drops on the hood. I rushed home and immediately washed it. Unfortunately, the paint was etched in 6 spots, identically to your photo above. I’ll have to use my Porter Cable orbital polisher to remove them, but even that may not completely take them out. I normally would use an orange pad on these, anyone want to recommend an appropriate level of cut compound? |
03-30-2019, 05:21 PM | #15 | |
Rep 25,113
Good luck, I had the same on my M4 a few years back, I literally washed it off the night it happened but it baked in the day in the sun. I have some emergency wipes now at hand in the car.
My car made front page of Bimmerpost
03-30-2019, 06:40 PM | #16 |
Rep 312
Drives: 2019 X3 xDrive 30i
For the fear of this happening, I keep a bottle of Meguiar's Ultimate Waterless Wash & Wax and two microfiber towels in my trunk.
2019 X3 xDrive30i Alpine White | Cognac w/ Fineline Cove Matte | 20" 699M Wheels | M Sport | Dynamic Handling PKG | Drive Assist | Parking Assist | Navigation | Trailer Hitch
scrammer421.50 |
03-30-2019, 09:23 PM | #17 | ||
Rep 2,067
Perhaps there is difference of kind of poop and time that its baked in under sun at certain climate/weather. So far i was able to, not yet on X3 (Carbon Black), on other cars (blue water metallic, mystic blue metallic) loosen up the poop's, and wipe them off completely (again, using Griot's Speed Shine wipes). Perhaps what i was overlooking was whether there was any damage already done underneath. |
03-30-2019, 09:34 PM | #18 | |
Rep 2,067
Kind of hoping the slickness would help avoid this... https://ceramicpro.com/aftercare/ Ceramic Pro is extremely slick, this means most things will dissolve and be pulled off by Ceramic Pro’s self-cleaning effect. Minimizing rubbing, (especially with a dry towel) on the coating will ensure its longevity. Dry bird droppings, bugs and tree sap can be dissolved using alcohol type solvents and wiped off with a damp microfiber towel. Bird droppings, tar, sap, etc. should be removed as soon as possible to avoid temporary staining or hardening on the coating. Any staining left behind from bird droppings will break down over a few days without affecting the coating. |
04-04-2020, 12:10 AM | #19 |
Rep 51
I have phytonic blue and have a similar mark on my bonnet. I have tried Autoglym super resin polish but wont shift it. Any other recommended products I keep hearing of meguirs ultimate compound for this sort of thing?
I have also seen numerous reports of applyimg heat with a hairdryer which sorts these marks out. I am obviously very reluctant to try this due to fear of damaging paint |
04-04-2020, 04:20 AM | #20 |
Rep 382
Hi,
For me - nothing beats a clay bar for correcting bird lime etchings. It’s a cheap and relatively easy way of sorting out the problem. Just make sure you start with a clean car, keep the bar constantly lubricated, turn it frequently and never drop it on the floor! Cheers Steve
Checkout my Instagram @carsandheels
2019 X3M40i - gone! 2023 iX40MSport |
chicagofan0019143.00 |
04-04-2020, 06:33 AM | #21 | |
Rep 169
‘22 X5 40i Alpine White/Cognac | '17 X5 35d Black Sapphire Metallic/Terra | '17 X3 35i Carbon Black/Saddle Brown
04-04-2020, 10:06 AM | #22 | |
ANM8
87
Rep 189
