10-09-2019, 09:40 PM | #1 |
Rep 10
Adding 3.5mm AUX jack back in (2019.5 UK x4)
Unfortunately I have only just found out that BMW have removed not only the CD/DVD player, but more importantly the AUX input jack.
I’ve only got the basic UK Sport spec, but the removal seems to be across the range. I am hoping that the head unit remains the same, and I can retro-wire a jack socket back in, which I am more than happy to do. I am guessing the AUX option in the ID6 can also be re-enabled, but I could do with some help on this too. My only other option is to use a £100 usb Aux encoder, which is not as reliable for what I need. Any ideas guys ? Schematics or software pointers will be well received - and by the look Of things others may need this too.... Thanks Jim |
10-12-2019, 07:22 AM | #2 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Sorry I had to. I have no actual assistance for you other than just posting this. Good luck in your find though. Hopefully some other members are actually useful.
https://draftpunkt.com/wp-content/up...is-it-meme.jpg |
10-13-2019, 01:21 PM | #3 |
New member
318
Rep 553
I don't believe the head unit has an AUX input anymore, so I don't think it can be re-enabled by taking the head unit out and plugging in an AUX cable. I am at work right now, but will find the schematics when I get home.
10-13-2019, 02:47 PM | #4 |
Rep 2,046
Drives: X3 G01 30i xDrive
Check this site:
https://www.newtis.info/tisv2/a/en/g.../a42-headunit/ Under "Pinout (PIB) A42 Headunit" section, there is table mentioning AUX-IN along with USB - that is probably inside of the HU. As I understand it, you could connect AUX connector instead of USB hub. But there is definitely no connector on the HU itself. Try to search the site, maybe you find something more useful. |
10-13-2019, 08:11 PM | #5 |
New member
318
Rep 553
Thank you titomi. I was referring to this
https://www.newtis.info/tisv2/a/en/g...nit/1VnYeyOjMv No physical connectors for a dedicated AUX input. |
01-26-2021, 04:07 PM | #6 |
Rep 103
FWIW, I purchased this device:
https://www.ensightauto.com/products...ne-aux-adapter (Looks like they just doubled the price. Was $19.99 when I ordered last week.) I'm 99% sure this is the Cartizan unit from https://www.icartizan.com/products/a...t-adapter.html In any case, it works quite well, presenting as "USB AUX" in the iDrive media menu. Perhaps most importantly it has no noticeable latency, so if you happen to have audio from a video source, the audio and video will be synchronized correctly. |
01-26-2021, 04:11 PM | #7 |
Rep 103
Also, if you really wanted to be slick, you could add a second USB port for the AUX adapter using this HOWTO (https://x3.xbimmers.com/forums/showthread.php?t=1574192) and still keep the standard USB port available.
01-26-2021, 08:15 PM | #8 |
New member
318
Rep 553
Interesting. Do you know how it pushes the audio to the head unit? Does it digitize the analog signal on the 3.5 mm jack to a format that the head unit can play. I read somewhere that the NBT Evo units did not support audio streaming over USB.
01-26-2021, 09:37 PM | #9 |
Rep 103
Not sure on the particulars. It must do some type of analog to digital conversion, right?
Demo of the latency, or lack thereof (Digging up this video is what sold me on it, as a potential first step in adding an Android Auto box.) |
Tags |
3.5mm, aux, id6, input, retrofit |
