02-02-2020, 09:45 PM | #1 |
Rep 21
front tire abnormal wear
Hi all, I got my 2 front tires replaced last Aug due to wear on the outside and did an alignment at the same time at an AD. But I noticed an abnormal wear of the sides of the 2 front ones AGAIN recently which is now not even 6 month into it.
My car is 2018 X3 X30i, 20in wheels, staggered setting on my tires, 4 wheel drive, and M sport package. I dont drive aggressively, the road conditions are not bad in where I live or to work. I do notice the front 2 tires might have "positive camber" causing the abnormal wear, because my rear 2 tires are completely fine. I have never driven the car aggresively either just my commute in the past was longer than now, but I dont know why isnt there significant wear on the rear ones but just the front ones? Also I am wondering could it be they didnt remove the transportation block on the front 2 wheel circled in the picture attached? And is it normal to have wider wheel gap (the space between the body of the car and the tire) on the front than in the rear wheels? Or they should have the same wheel gaps all around? I am going to the same AD this week and I want to find out if it has to do with the alignment that they didnt done right last time, and I am afraid that if that is indeed the cause they are no willing to help me replace the tires. Also want to know what is exactly causing this issue, thanks. Last edited by danchang79; 02-02-2020 at 10:01 PM.. Reason: adding more info |
02-02-2020, 10:13 PM | #2 |
Rep 1,906
The only 'wrench adjustable' front suspension parameter on BMW cars is "toe". Adjusting camber (and castor) up front can be done but requires work beyond simple wrench adjustment- fronts are not designed to be readily adjustable for those parameters as it's rare they would ever be out of spec, unless car suffered accident or encountered a major pothole.
Excessive Wear at the outer edge of the tire as your pic shows can be caused by incorrect toe setting. My guess is the alignment you had done last year was not performed correctly. Not certain I understand your comment about the suspension "block". |
02-03-2020, 01:09 AM | #4 |
Rep 121
I have a very similar setup on my car, only I have the Pirelli’s. My wear is similar to yours. I guess it is just a consequence of the natural setup of the car.
02-03-2020, 08:20 AM | #5 |
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
I can confirm I had the same wear on the fronts... the outer wear bars. Typically this can also be evidence of hard cornering, but you know how you drive the car and if that’s the case. As mentioned above, get an alignment done and insist on the tech zeroing out the front toe-in; it appears that it may be excessive on your car. The only toe you really need is a bit of toe in on the rear.
02-03-2020, 11:19 AM | #6 | |
Rep 21
02-03-2020, 11:21 AM | #7 | |
Rep 21
02-03-2020, 11:27 AM | #8 |
Rep 21
Another thing, can anyone tell me the correct PSI I should do for both front and back? The label states 32 front/35 rear when cold.
I feel I need to be adjusting it when temperature change sometimes from week to week or even day to day. Can doing this lead to the wear as well? |
02-03-2020, 01:29 PM | #9 | |
Rep 108
02-03-2020, 02:17 PM | #10 |
Rep 679
Hes got a staggered setup so no rotation possible! This could just be normal wear with the standard suspension setup.My other BMWs eat the rear tires first! Anyway, Im on square 19" setup and fine for now...
02-03-2020, 02:55 PM | #11 | |
Rep 32,881
02-04-2020, 03:04 AM | #15 | |
Rep 32,881
02-04-2020, 05:33 AM | #16 |
Rep 744
I'm running 39psi on my winter tires. That's the BMW 19" 245 recommendation for fully loaded car and i always tend to go to the higher values of the recommendation. The tradeoff for lower tire wear is slightly reduced comfort.
But it worked for me for the past years on all my cars. |
02-04-2020, 10:25 AM | #17 |
Rep 21
02-04-2020, 10:35 AM | #18 | |
Rep 32,881
02-04-2020, 02:52 PM | #19 | |
Rep 596
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
02-04-2020, 03:25 PM | #20 |
Rep 135
Dealer constantly states "bad wear" is normal to these cars....
Im 25k miles in and on my 4th set of tires in the next month. |
02-04-2020, 03:51 PM | #21 |
Rep 69
My Bridgestone alenza did the exact same thing after ~8k miles, and I believe there have been a few other threads with this issue and these tires.
I always kept mine at the recommended pressure (32F/35R) and agree that's probably too low. I've bumped the pressure on my winters (also Bridgestone RFTs) to 35F/37R and don't see that kind of wear. I'll be picking up Michelin PS4 SUV as replacements and plan on running 35F/37R on those, along with an alignment when they're put on. |
02-04-2020, 05:43 PM | #22 |
Rep 21
What are you doing about it? I get frustrated everytime I need to reason with them because they almost always say there's nothing they can do.
