04-24-2022, 01:43 AM | #1 |
Rep 4,035
Are the G80 M3 CF shift paddles true plug & play... ?
Just like the title says, are the sick OEM BMW carbon fiber shift paddles from the G80 M3 compatible on both the pre & post LCI X3 MC's... ?
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
04-24-2022, 03:11 AM | #2 |
Rep 323
Drives: E46 m3
04-24-2022, 09:31 AM | #3 |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
All we can say is, just do it! Easy to install (plug and play) and makes it so much better!
- Another fellow member with G8X CF paddles |
Spoonhead362.50 Kevin_The_Clean13421.50 |
04-24-2022, 10:12 AM | #4 |
Rep 375
I've got a set of the G8X paddles on the way for my pre LCI, and as far as I can tell, they should be plug and play.
Managed to grab an OEM set off eBay for £250/$320 so they were an absolute steal as well |
04-24-2022, 01:06 PM | #5 |
Rep 55
It sure does fit, plug n play. It’s one of the cooler mods
04-24-2022, 08:09 PM | #6 |
Rep 18,786
Yes it is.
Sold and installed many of them. Still have couple sets in stock.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
04-25-2022, 08:36 AM | #8 | |
Rep 18,786
Don't want to Hi-Jack the thread.
04-26-2022, 02:06 AM | #10 |
Rep 323
Drives: E46 m3
Kevin_The_Clean13421.50 Savage_M3301.00 |
04-26-2022, 03:09 AM | #11 |
Rep 4,035
I assume it's the same for all other paddles. Disconnect main battery terminals, wait 5 minutes to ensure airbag is not in stand by mode, remove air bag, remove steering wheel, remove old units & replace with new units. The reassemble everything in the reverse order.
Savage_M3301.00 |
04-26-2022, 09:51 AM | #14 |
Rep 116
I was trying to take pics but got in a hurry. The first steps of disconnecting the battery, let the car drain, and removing the airbag, is the same process as this video:
I needed a T60 torx, not a 16mm socket, to get the steering wheel off. Harbor freight should have a 1/2" socket set that includes this bit. Once you get the wheel off its pretty straightforward, now that I've done the swap once I could do another in less than an hour, maybe 30 minutes. Very easy mod. |
Savage_M3301.00 Kevin_The_Clean13421.50 |
04-26-2022, 10:00 AM | #15 |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
I'm loving mine. And there's no need to take the steering wheel off at all. Just unplug the negative terminal battery, remove airbag, remove each screw that holds the paddles in place, unplug, remove, and replace. simple. I've done both the paddles and trim with the steering wheel in place.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
PabstBleuRibbon487.50 r33_RGSport13108.50 JB20DGM132.50 Savage_M3301.00 bear1m87.00 Kevin_The_Clean13421.50 |
04-26-2022, 04:03 PM | #16 |
Rep 196
Don't suppose you have the PN for the paddles and CF trim reasonably handy?
2020 BMW X3M Competition
2006 BMW 325i (E90) 2006 Pontiac GTO |
04-26-2022, 04:38 PM | #17 | |
Rep 323
Drives: E46 m3
Paddles are- 61-31-9-501-592 |
04-27-2022, 04:41 PM | #18 | |||
Rep 185
