04-11-2019, 11:42 AM | #1 |
Rep 418
Drives: 328is, 528e, 335i, X3 M40i
Exterior Black Trim Cleaner and Scratch Removal?
Hi Fellow GO1 owners, any suggestions on cleaners for the black trim on the car and something to remove the scratches with?
AC328
2018 AW G01 X3 M40i 2008 AW E92 335i Coupe 2006 SG E85 Z4 3.0si 1996 AW E36 328is (original owner) 1986 DG E28 528e |
04-11-2019, 02:15 PM | #3 |
Rep 301
Drives: 2019 BMW X3 M40i - Sold
I would start with something milder than Megs UC... Perhaps Megs UP (Ultimate Polish) is enough. You cannot use compound without following up with a milder polish or else it will leave small micro scratches. It is like sand paper, you start coarse and work your way finer.
That being said, I think for shiny plastic trims, I would start with a fine polish first. Meguiars Ultimate polish line is user friendly, effective and can be applied by hand. And yes, a ceramic coating would be great to minimize future scratches, but buying a full bottle just to do trims sounds like a waste - might as well do the whole car...
2023 BMW X7 40i // Mineral White // Silverstone Sensafin // MSport Pro + Performance Enhanced
2020 BMW X6 M50i // Alpine White // Mocha Vernasca // Performance Enhanced 2019 BMW X3 M40i // Alpine White // Cognac Vernasca - SOLD |
04-11-2019, 02:24 PM | #4 | |
Rep 32,881
04-11-2019, 04:40 PM | #5 |
Rep 418
UC?
AC328
04-11-2019, 05:04 PM | #7 |
Rep 418
Everyones got some sort of scratches on it right. The scratches aren't deep. I am looking for something to clean and wash it without adding more scratches. Also seeing if it possible to remove some of the scratches without using something abrasive, car is still fairly new and don't want to do any damage.
AC328
04-11-2019, 05:13 PM | #8 | |
Rep 32,881
04-11-2019, 07:41 PM | #9 |
Rep 5,109
MechX3M40i1006.00 |
04-12-2019, 07:34 AM | #10 | |
Rep 301
Ultimate Compound and Ultimate Polish are designed to be used together, one after the other. If you're only going to use a single stage, you would use Ultimate Polish.
04-13-2019, 04:13 AM | #11 | ||
Rep 32,881
I then coated it with Gtechniq C2v3 and the paint surface was like glass! |
04-13-2019, 04:01 PM | #12 |
Rep 301
Don't get me wrong, UC is great. Here's a black car I did with UC and UP :
To my eye, UC alone did 90% of the correction and UP did the other 10% and also added polishing oils to the paint for more gloss and shine. 90% is still better than 0% though!
SSBMW14369.00 |
04-18-2019, 12:04 AM | #13 |
Rep 418
Isn't that too abrasive for the piano black trims all over the car?
AC328
04-18-2019, 02:21 AM | #14 |
Rep 175
A very good alternative is the Blackfire products. Blackfire paint cleaner is very good at dealing with swirls and minor scratches, with the sealant applied as a second stage to protect.
04-18-2019, 09:21 AM | #15 | |
Rep 301
I personally use M205 (MEguiars Ultra-Finishing Polish), which is a more aggressive version of UP (same non-diminishing abrasive technology, just more cut, but a bit harder to use) and it would definitely be enough to remove minor webs and swirls on black gloss trim. M205 not meant for hand application though, so that's why the Meguiars Ultimate Line (consumer line) would be ideal.
IM_ALL_IN57.00 |
04-21-2019, 08:51 PM | #16 |
Rep 120
Agreed, I always want to start with the least aggressive product to see if that fixes the problem. I'm annoyed at the scratching on my piano black interior and will likely attempt to polish it soon...there's no way I would start off with a compound before trying something with a much lighter cut. It feels cheap and I bet the clear is super thin.
04-25-2019, 10:48 PM | #17 |
The limit of adhesion is my home.
1702
Rep 3,778
Ultima is amazing. It totally impressed me. Wipe on, wipe off, no buffing.....I was like..."WAAAAHT???" I even use it on the annoying piano black center trim we have and it works wonders. HIGHLY recommend it
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
TheMooseMan83.50 |
