      01-09-2019, 09:29 AM   #1
antjones21
antjones21's Avatar
Drives: 2022 BMW X4 M40i
Gas
I just ordered my first BMW X4 xdrive30i on Saturday and it's due production week 4. What type of gas should I be using once I get the car? I've seen premium and mid grade mentioned but no definite answer.
      01-10-2019, 10:49 PM   #2
drexplode
drexplode's Avatar
1781
Drives: G26 i4x
Premium preferred. Engine has a knock sensor so if you use 87/89, spark timing will adjust
      01-11-2019, 07:52 AM   #3
antjones21
antjones21's Avatar
Thank you
      01-11-2019, 11:52 AM   #4
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
check the gas cap sticker, no less then 91
      01-21-2019, 04:28 AM   #5
Barathon
Barathon's Avatar
579
Drives: 2022 M3 Comp xDrive
It's usually best to look in the owner's manual and use what is recommended by the manufacturer. (I also wouldn't vary what you put in)
I pulled the digital manual for the 30i it says;
General information
For the best fuel efficiency, the gasoline should be sulfur-free or very low in sulfur content.
Fuels that are marked on the gas pump as containing metal must not be used.
Fuels with a maximum ethanol content of 25 %, i. e. E10 or E25, may be used for refueling.
Ethanol should meet the following quality standards:
US: ASTM 4806–xx
CAN: CGSB-3.511–xx
xx: comply with the current standard in each case.
Recommended fuel grade
BMW recommends AKI 91.
Minimum fuel grade
BMW recommends AKI 89.
If you use gasoline with this minimum AKI Rating, the engine may produce knocking sounds when starting at high external temperatures. This has no effect on the engine life.
Current: 2022 ///M3 San Marino Blue, Comp, xDrive, Fjord Blue/Black --plus-- 2022 ///M440i Gran Coupe, Aventurin Red, Cognac Vernasca
Past
'20 X4 ///M Competition Toronto Red -- '16 ///M3 Tanzanite Blue, ZCP -- '15 ///M3 Mineral Grey
      01-27-2019, 05:18 PM   #6
jmh600cbr
jmh600cbr's Avatar
Drives: G80
2021 BMW G80  [0.00]
False. No less than 89. 91 recommended. I use 89.
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM
      01-28-2019, 06:19 AM   #7
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
i bet you get shitty performance.
      02-08-2019, 06:33 PM   #8
jmh600cbr
jmh600cbr's Avatar
Drives: G80
2021 BMW G80  [0.00]
General information
US: ASTM 4806–xx
CAN: CGSB-3.511–xx
Minimum fuel grade
I mistyped. I use the highest gas at whatever station I'm at. 91-93
2021 G80 6MT BSM
