07-01-2018, 05:42 PM | #1 |
Rep 72
M40i satin finish trim, how to clean?
Anyone any recommendations on how to clean the satin trim parts (wing mirror caps, kidney grill etc). Not sure what product works well, as standard car shampoo seems to leave a residue and weird water markings on it.
Any advice appreciated |
07-01-2018, 07:20 PM | #2 |
Rep 165
I had the same question. I had some water spotting that a normal wash wouldn't lift. I found that a spray detailer works great for me. Specifically I'm using Meguiar's Ultimate Quick Detailer. It's a lower cost product I found at Walmart and there are probably better products. But it does a good job of cleaning that finish.
rrao5610.00 faffoocasey30.00 |
07-02-2018, 07:15 AM | #3 | |
Rep 72
07-03-2018, 07:06 AM | #5 |
Rep 72
JustChris17487.50 stein_325i25083.00 |
07-03-2018, 08:55 AM | #6 |
Rep 292
I would recommend using a sealant, like Optimum Opti-seal. It will clean the water spots as well as protect the finish for about 3 months.
Current: 2018 X3 M40i (PB)
Previous: 2019 M240i (EB); 2002 E46 330i in OB |
07-03-2018, 12:48 PM | #7 |
Rep 24
Would applying Opti-Seal create a more glossy finish on the matte/satin Cerium Gray elements, including the 21" wheels?
Current: 2018 X3 ///M40i | Dark Graphite Metallic
Previous: 2015 428i xDrive Gran Coupe M Sport | Black Sapphire Metallic |
07-03-2018, 12:52 PM | #8 | |
Rep 292
07-03-2018, 01:06 PM | #9 |
Rep 24
Smart to use on painted calipers too?
07-03-2018, 02:38 PM | #10 |
Rep 292
Sure, you can use on calipers. Probably won't last as long due to heat, but easy enough to re-apply every couple of months.
07-03-2018, 04:51 PM | #11 |
Rep 3,447
Drives: 2018 X3 M40i
Quick Detailer! Great tip!
07-31-2018, 09:07 PM | #12 |
Rep 24
I found that Eagle One Wipe and Shine isn't doing a thing to clean the 21" wheels.
Any other products that have worked for anyone? I haven't had a chance to use Opti-Seal yet. I used cleaner wax on the mirror caps, kidneys, etc. Definitely cleaned them up, but can't wax wheels every couple days like using Wipe and Shine.
07-31-2018, 10:30 PM | #14 |
Rep 1,487
Drives: 2108 X3 xDrive30i
Clean very carefully with a good spray detailer.
08-01-2018, 06:00 PM | #18 |
Rep 304
Agreed...
When I ran out I used J&J baby oil... yes you read that correct. Washed, dried thoroughly and then apply lightly with a dry cloth. My Mrs swears by it in the kitchen on the stainless steel so thought I’d try it... and it works well and lasts. |
04-21-2019, 08:56 PM | #20 |
Rep 120
Bump. Any other thoughts on how to tackle the cerium pieces and protect from water spotting? Has anyone tried polishing these pieces?
I may try laying down a layer of powerlock on it. |
04-21-2019, 10:26 PM | #21 |
Rep 8,028
Drives: 2024 X5 M60i
I found my solution to the issue. Swap all the parts out for gloss black pieces. :
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
04-22-2019, 01:45 AM | #22 |
Rep 13
Found out by accident that glass cleaner works perfect on the cerium trim. All the dead bugs wiped right off with zero streaking or residue. I don’t think the brand would matter, but for reference I was using some 3M glass cleaner I had lying around.
