      02-25-2024, 05:12 PM   #1
Zlatan
Drives: 2020 BMW X3M
BM3 Timing Correction - 91 Octane
Hey Guys,
Did some logging today on 3 different maps after I noticed some timing corrections. Any reason to be concerned here?
2020 X3M Base
17K Miles
CTS Xpipe (Essentially a res delete)
Dinan Drop In Filters - Charcoal filters removed
All pulls done on 91 octane - BM3 OTS
Stage 0+ LCI Map: Flashed and ran logs within 5 minutes
https://www.bootmod3.net/log?id=65db...c9c9791cfaea67
https://www.bootmod3.net/log?id=65db...c9c9791cfae9a0
Stage 1 91 ACN Map: Flashed and did logs within 10 minutes
https://www.bootmod3.net/log?id=65db...befb28ac8102bf
https://www.bootmod3.net/log?id=65db...c9c9791cfae65f
https://www.bootmod3.net/log?id=65db...c9c9791cfae5f7
https://www.bootmod3.net/log?id=65db...b72d567fe22c0c
Stage 1 91 Map: This was the map I had been using for about a month.
https://www.bootmod3.net/log?id=65db...c9c9791cfaaeca
      02-26-2024, 03:58 PM   #2
Zlatan
Went and added 1 gallon of E85 that typically tests E80-E85
https://www.bootmod3.net/log?id=65dd...9d5436b30e9d74
https://www.bootmod3.net/log?id=65dd...e0325928d4cc21
Gas is pretty weak in Idaho if you're stuck on 91.
