06-08-2022, 01:48 PM | #1 |
2022 M4 Comp Xdrive
1016
Rep 1,540
5w40 vs 5w30 for the S58
So I searched through the threads on here so far and most of the folks seem to be using 0W30 or 5W30. I have seen folks on the b58 side using 5W40 when tuned.
Why isn't the general census here the same on tuned examples? Or Did my search not yield the correct results. |
06-08-2022, 02:06 PM | #2 |
Rep 441
There are good suggestions and speculations under the G8x forums
06-08-2022, 02:41 PM | #3 |
Rep 442
There are probably REALLY good suggestions in the owners manual. I'd like to think the engineers who built the engine might know better than a few tuned examples. Then again, maybe you're not in warranty or are ok being your own warranty on a $30k engine.
06-08-2022, 05:04 PM | #4 | |
Rep 1,279
Drives: 2024 BMW M4 Base
Use what BMW says to use. Even if you don’t care about the warranty. Engine tolerances today are much different than 15-20 years ago. My opinion is if you care about your engine, stick with BMW recommend oil. If you want to learn more check out www.bobistheoilguy.com. More information about oil than anyone wants to know 😁 |
allwheelsdriven112.00 |
06-08-2022, 05:45 PM | #5 |
2022 M4 Comp Xdrive
1016
Rep 1,540
BMW also recommends absurd oil change intervals. I wouldn't follow them to spec. This is why I'm asking.
Coming from an e70 x5m where they recommend using 5w30 on that super hot v8 is troubling. Engine temps on that motor reach 225 to 230. 5w30 becomes water thin at those temps. Leads to premature wear and ultimately carbon build up and damaged bearings over time. Having said that, I think 5w30 seems to be an OK choice here for the s58 |
06-08-2022, 06:12 PM | #6 |
Rep 1,279
Once a year or 5,000 miles is when I do an oil change. I think 10k is too much but BMW wants to keep maintenance as cheap as possible since maintenance is include. I also do an oil test after each oil change. Just piece of mind to know how the internals are doing. Saved my butt in one case. 2015 Corvette with a SC putting down 697 at the wheels on 11lbs of boost, headers, tune, and Meth injection. After the next oil change I sent the sample to BlacKStone labs and they basically said the engine had way too much copper in it due to premature wear. Sold it to a dealer the next day.
pdotc847.50 |
06-09-2022, 07:35 AM | #7 |
Rep 194
I did an oil analysis after a ~5k mile change (I change my own oil between the ones covered by the maintenance plan on the factory interval) and the BMW 0w30 LL-01FE oil had already sheared down below the weight of a 0w30. A virgin oil analysis of the oil showed the viscosity is already towards the low end of a 0w30 at the start, I guess that's where the "Fuel Economy" (FE) portion of the oil comes in.
All that being said, there were not any abnormal wear metals present and nothing else overly concerning. I may change over to a different 0w30 S(x) spec oil later if I continue to not see what I want from the oil analyses.
2020 BMW X3M Competition
2006 BMW 325i (E90) 2006 Pontiac GTO Last edited by JB20DGM; 06-09-2022 at 07:40 AM.. |
FSociety3812.50 |
06-09-2022, 03:54 PM | #8 | |
2022 M4 Comp Xdrive
1016
Rep 1,540
Thanks, btw do u mean it sheered to a 20 weight? |
06-09-2022, 05:14 PM | #9 |
Rep 194
It wasn't quite down that low, or at least relative to a virgin sample of the BMW 0w20 (LL17 or whatever)...but it was below the range for a 0w30 oil. Considering it was halfway through the BMW oil change interval and about where I normally change the oil in my other vehicles and don't have the oil drop out of spec I'm not super thrilled.
This was also from a dealer change and they use bulk oil. I haven't done a sample yet from my change where the 0w30 came out of litre bottles to see if there's any appreciable difference (ideally there shouldn't be). But, wear metals were still low...and in my case low compared to 'universal averages'.
2006 BMW 325i (E90) 2006 Pontiac GTO |
FSociety3812.50 |
06-22-2022, 11:05 PM | #11 |
IG @bmwF9xG80
3813
Rep 7,593
JB20DGM curious to see your finding on your current 0w30 non-bmw oil
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
09-28-2023, 05:27 PM | #13 |
Rep 3,929
The 5W30 takes way too long to get up to ideal operating temps in the cooler months. I'm sticking with the 0W-30 like it came with.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
09-28-2023, 08:32 PM | #14 |
Need mo $$s
833
Rep 885
Running Mobil 1 European Formula 0W-40, stage 1 93 BM3 Tune.
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
09-29-2023, 04:19 AM | #15 |
DisplacementReplacement
409
Rep 1,104
Rotella T6 5-40 on every turbo vehicle I've owned (four bimmers and three wrx/sti's) including this one and it's been good to them to date... most in bmw land don't like this oil... i do
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
joebie3298.50 |
09-29-2023, 06:06 AM | #16 |
Rep 291
Drives: 2014 STI - 2020 X3MC
I was running T6 in my Subaru before I put the IAG shortblock in(regular maintenance LOL). Switched to Motul 8100 at that time. Labs always came back good in terms of sheer when I was doing them, even with E85, but I'm running 3k oil changes. I actually have one queued up to send out, but need to get over to the post office.
Jnat408.50 |
09-30-2023, 11:27 AM | #19 |
2022 M4 Comp Xdrive
1016
Rep 1,540
Wow, super old thread lol.
I've switched to 5w40 a while back after I was told by a few folks about some bearing issues that some s58s have. Better to run this slightly thicker oil for better protection. |
Jnat408.50 lethal_x3mc1.50 |
09-30-2023, 05:37 PM | #20 |
Rep 1,053
