04-28-2024, 01:23 AM | #1 |
Rep 1,822
Drives: 2022 X3 M40i
What options for HPFP and LPFP upgrades for GEN 2 B58TU
Just wanted to see what's available as upgrades, was considering Spool's FX 350/400 HPFP https://spoolperformance.com/collections/b58-tu
and LPFP from Precision Raceworks https://precisionraceworks.com/produ...47280262578369 stg 1/2 anyone know of any other offerings? |
04-28-2024, 12:56 PM | #2 |
Rep 371
Visconti has a kit Stg1 Fuel System Upgrade
Dorch’s HPFP is similar in cost to Spool, but couldn’t say which product offering is “better”. I do know Dorch seems to be a popular choice though |
Burr0013360.50 |
04-28-2024, 12:58 PM | #3 |
BM3 Tuner
348
Rep 303
Do not buy the spool hpfp nothing but issues. Dorch is a bit more reliable and easier to tune, overall I would just go PI route or do dorch pump with lpfp and s58 injectors.
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, Nostrum Big Bore HPFP, VTT PCV and Oil cap, HnR springs.
Paul Johnson Tunes Shop/Development Car |
Burr0013360.50 5LEEPR_G01503.50 |
04-28-2024, 01:12 PM | #4 |
Rep 371
I’m glad to have yall on these forums Burr001 AshtonPJT look forward to seeing this platform continue to get pushed
04-28-2024, 01:16 PM | #5 | ||
Rep 1,822
I need to keep doing more research if I decide to go bigger turbo than the vtt gc I have sitting in the corner...lol. If I decide to stick with gc turbo, the stock fuel system will be enough? |
04-28-2024, 01:17 PM | #6 |
BM3 Tuner
348
Rep 303
I’d wait for rev 2 to come out honestly.
Burr0013360.50 |
04-28-2024, 01:44 PM | #8 |
BM3 Tuner
348
Rep 303
I’d also stay away from DAW🤷‍♂️
Stock fuel system will get you around 600ish with the GC
Burr0013360.50 |
04-28-2024, 01:52 PM | #9 |
Rep 371
Gr8ZongB58279.50 |
04-28-2024, 01:57 PM | #10 |
Your Average B58'er
280
Rep 233
Wondering the same as I have daw in my sights
2019 X3 M40i - MHD STG2 HPFP E40ish | MHD FlexFuel Kit | TU HPFP | xHP stg 3 | VRSF catless downpipe | MST intake | BMS occ | Verus turbo heat shield | P3 V3 gauge w/ P3 ESVA | FTP Charge Pipe | RossRacing PCV v1 VTA | MSS Springs | RES Exhaust w/o valves | Vossen HF-5 21x9.5/10.5 265/295 PS4S | Yellow DRLs | Paragon Rotors w/P3 pads |
04-28-2024, 01:59 PM | #11 | |
BM3 Tuner
348
Rep 303
Or they end up upgrading the turbo to the next model up with daw then still don’t ever reach the results they want. To top it off most of these upgrades are from failed turbos after only a few hundred to thorns miles on them.
Burr0013360.50 |
04-28-2024, 02:03 PM | #12 |
Rep 1,822
04-28-2024, 02:04 PM | #13 |
BM3 Tuner
348
Rep 303
I have the full nostrum fuel setup on my car so plan to stay DI only until rev 2 comes out
04-28-2024, 02:05 PM | #14 | |
Your Average B58'er
280
Rep 233
5LEEPR_G01503.50 |
04-28-2024, 02:17 PM | #15 |
BM3 Tuner
348
Rep 303
Power, car would make way less than advertised with the turbo being maxed out
Gr8ZongB58279.50 |
04-28-2024, 02:24 PM | #16 |
Rep 371
AshtonPJT have you tuned any Remnant Performances turbo?
04-28-2024, 02:26 PM | #17 |
BM3 Tuner
348
Rep 303
Working on one right now, and might go with this option myself
5LEEPR_G01503.50 |
04-28-2024, 02:36 PM | #18 |
Rep 371
04-28-2024, 07:56 PM | #19 |
Rep 1,822
The only thing about Rev 2 is that those who are looking to do it may have to resend their DME back to Femto?? I'm not sure if this is true or for those who do did not opt for the custom ROM from BM3.** found the ans
post from @mikeAx-ph.com https://www.2addicts.com/forums/show....php?t=2090626 🔸What's a REV2 board? The FIRST and ONLY automotive aftermarket ECU with FlexRay™ protocol support providing standalone ECU features such as DIRECT port fuel injector control, boost solenoid control among many others as well as adding an expansive list of sensor inputs to supplement tuning abilities like never before, while running on a High-performance 32-bit Power Architecture MCU for Automotive Applications. 🔸What do you mean DIRECT control? DIRECT, pulse width modulation (PWM) using spare outputs on the factory DME repurposed for REV2 use, courtesy of bootmod3 CustomROM. 🔸Why not CANBus? We wanted direct control, without overhead and potential loss of messages that may happen over CANBus. Factory DME uses PWM control for fuel injectors, so does the REV2. 🔸What the heck is FlexRay™? FlexRay is a next-gen automotive communications protocol. It addresses many shortcomings of CANBus while being designed to ensure high data rates, fault tolerance and ability to guarantee message delivery. Google it 🔸What is different between running this and an off the shelf standalone ECU? Tuning done in one place and integration. Once REV2 is installed, you never connect to it again. Your tuner makes a map in bootmod3 editor as usual, you flash it, and off you go. 🔸What other outputs can it control? Any PWM device (e.g. nitrous solenoid, meth solenoid, fuel pump, etc). 🔸What sensors can it handle? Any 0-5v analog or digital sensors, including 2 EGT inputs, pre-configured. 🔸Is it water resistant? Yes! REV2 has an IP66 water resistant enclosure for convenience of engine bay install. 🔸When, when, when? REV2 board is ready. CustomROM V2 software release ETA Q2 2024! 🔸What cars will be supported? All bootmod3 CustomROM supported vehicles. Releases will be staged with S58 support coming first, followed by the rest of the vehicle platforms currently on CustomROM (B58, S55, N55, and others). |
Gr8ZongB58279.50 |
04-28-2024, 08:19 PM | #20 |
Rep 131
I am running a Dorch DS25-350 and I am very pleased with it until now. Customer support is very good.
Burr0013360.50 Rottweiler4054.00 |
04-29-2024, 12:01 AM | #21 | |
BM3 Tuner
348
Rep 303
I will definitely keep everyone updated. I also expect us to have a newgen daw coming in the near future and will let y’all know how that is as well, hopefully they’ve fixed the issues and the turbo can deliver like promised
Gr8ZongB58279.50 5LEEPR_G01503.50 |
05-05-2024, 04:26 PM | #22 | |
Rep 1,822
this?https://precisionraceworks.com/produ...47280262545601 Stg1 of course. Will stock LPFP handle 100% E85 with stock TU HPFP? Was driving around the other day and got sudden fuel cut at WOT...wasn't logging and at E63 at the time. Just concern that once I install new GC turbo I will be maxing it and will want some room and not run the system at 99.9%. |
