01-29-2020, 08:41 PM | #1 |
Joint Chiefs of Staff
24348
Rep 191,145
Bootmod3 Now Available for the X3M/X4M S58
bootmod3 - World's First, Most Advanced and Widely Adopted BMW Flash Tuning Platform
Cloud based solution with a web based interface for use on macOS, Windows and mobile apps for iOS and Android. Developed and tested in-house from the ground up over the course of almost 2 years prior to its November 2016 debut with new features and updates being added regularly makes the bootmod3 platform a custom BMW factory DME tuning solution like no other on the market today. Build the ultimate tune for your S58 powered vehicle and go from stock to full race calibration, and everywhere in between, with a map switch in the provided mobile app. bootmod3 calibrates the factory vehicle modules over the OBD port in just 3 minutes, switching among maps in seconds, in the convenience of your driveway or anywhere internet access is available. After initial activation, flashing and datalogging in offline mode without internet connectivity is also available. Maps and power gains with OTS maps based on X3M/X4M non-comp model: Stage 1 ACN91 octane: 11%HP / 25% TQ Stage 1 91 octane (95 RON): 17% HP / 28% TQ Stage 1 93 octane: 21% HP / 31% TQ Stage 1 E30 octane: 31% HP / 41% TQ Stage 2 ACN91 octane: 13%HP / 28% TQ Stage 2 91 octane: 20% HP / 30% TQ Stage 2 93 octane: 23% HP / 34% TQ Stage 2 E30 octane: 33% HP / 44% TQ Stage 2 Race Gas: 33% HP / 44% TQ ** ACN91 maps are for vehicles that fill up with 91 octane that in some places around the Globe can be of questionable quality and not up to 91 (95 RON) standards. Lower than 95 RON (US 91 octane) cannot be used. Vehicle Models Supported: F97 X3M 2019 - Present F98 X4M 2019 - Present Integrated Advanced Tuning Solution for building custom maps. Work with a professional tuner of your choice through bootmod3 cloud or even on your own if so inclined Datalogging hundreds of diagnostic channels, up to 40 channels concurrently Datalog sharing and charting without a need to upload to 3rd party websites or apps using the mobile app or web browser Cloud based storage for map data and datalogs and use at any time on any laptop or device with ease Only solution on the market that tunes using your actual vehicle's software instead of a cookie cutter approach other tuning companies use flashing every car with the same software. Flash back to your true stock map and re-lock the DME back to stock programming for service visits Live Dash Gauges - realtime vehicle parameter monitoring via in-app gauges Set up gauges with thresholds and monitors for peak values Peak value recall on gauges Adjustable gauge layout and color themes Diagnostics Read and clear trouble codes in all vehicle modules Reset learned adaptations (octane, knock, transmission, Valvetronic, etc) Reset all ECUs in the vehicle Some of the many map features provided, for details consult the bootmod3 User Manual: Map Customization through Integrated Advanced Map Editor Customize various map options with dropdowns/toggles/sliders through the Map Configuration screen Exhaust burble fully end user customizable from OFF to very aggressive mode and anywhere in-between, switchable with the steering wheel controls in efficient vs. sport mode Boost By Gear end user configuration per map Top speed (VMAX) limiter removal Cold start cat heating cycle (loud cold start) Catalytic converter efficiency check configurable (ON/OFF) for high flow downpipes (off-road use) Re-calibrated Sport Gauges on iDrive E85/blend, race gas and meth injection tuning For more info take a look at the bootmod3 FAQ here! *** bootmod3 OBD WiFi Agent device is not required to use the bootmod3 platform. It is a convenience option that removes the need for using a laptop in the car when using bootmod3's features. If you're looking to simply load a tune on the car without much datalogging and monitoring then using your Windows or macOS laptop is the ticket for you! VEHICLE MANUFACTURER WARRANTY AND EMISSIONS DISCLAIMER Some items used and/or installed by PRO TUNING FREAKS may void portions of your vehicle’s factory warranty. Some items may not be legal for “on highway use”. PRO TUNING FREAKS makes no guarantees to the legality of any parts used for “on highway vehicles” and accepts no responsibility for compliance with the vehicle’s factory warranty.
01-30-2020, 06:08 AM | #2 |
Rep 33
Wow, that is amazing. I can’t imagine how quick these cars will be with 21% HP and 31% extra torque on a stage 1 tune. I’m looking forward to some real world acceleration data.
01-30-2020, 10:06 AM | #3 |
24348
Rep 191,145
01-31-2020, 05:01 PM | #4 |
Rep 356
Why is the power gain so small for ACN91? Is this something that will get updates with more hp in the future as more testing is done on ACN91?
I have an X3M comp and it would only give me about 4% more hp. On my S55, I am getting 20% more hp with the ACN91 tune. Maybe we are starting with a VERY conservative tune for ACN91 to avoid knock on early "test customers"? Don't get me wrong, I love the tune on my S55 and Bootmod3 is awesome. |
01-31-2020, 06:30 PM | #5 | |
24348
Rep 191,145
Im sure with time, newer maps will be more aggressive. It also depends on how much BMW are pushing the car stock
ILLMATIC2313.50 |
01-31-2020, 08:41 PM | #6 | |
Rep 356
Considering the X3M comp has 500 HP already, 20HP is not that much. |
01-31-2020, 08:45 PM | #7 |
24348
Rep 191,145
Right as i said in my post, its a mix of bad fuel + how much HP space left by BMW
01-31-2020, 08:49 PM | #8 | |
Rep 356
The Stage 1 91 for the F97 makes a 17% gain, which is very respectable, while the ACN91 is making 11%. That is a huge difference just based on fuel quality. |
01-31-2020, 08:54 PM | #9 | |
24348
Rep 191,145
They did the same with the 335. The N54 can easily push another 100 HP with only a tune. Then they came out with the N55 which could only do 40 HP
Ironwood25.00 |
01-31-2020, 08:59 PM | #10 | |
Rep 356
Because with ACN91 and bootmod3, I have almost 550HP at the crank on the S55, while this ACN91 tune for the S58 only goes to 520. |
01-31-2020, 09:13 PM | #11 |
Rep 95
Was wondering the same thing myself with tunes in general actually. Never used the s55 platform but in researching I’ve been trying to draw parallels and scratching my head a bit.
01-31-2020, 09:53 PM | #12 |
Rep 59
I'm running Stage 1 93 octane and it's a beast. It is a completely different vehicle on this tune. Everything from part throttle tip in to WOT is a significant improvement.
01-31-2020, 10:05 PM | #13 |
Rep 59
I'm going to be working on a E85 tune. If I squeeze in a couple pulls on a Dynojet, I'll post the results. Hoping for around 620whp once boost and timing is sorted. For anyone on the fence about BM3, I can vouch for how good Stage 1 93 is.
01-31-2020, 11:23 PM | #14 | |
Rep 356
I suspect that the only people who know the answer are the ones who released and tested the tunes. |
02-01-2020, 10:25 AM | #15 | |
24348
Rep 191,145
Based on PTF website, S55 on 91 (not 91 ACN) power is 20% HP 22% TQ Considering stock numbers are 425 and 405 tq power with stage 1 is 510 HP 494 TQ Remember this is 91 not 91 ACN the S58 power is 11% HP and 25% TQ considering stock numbers are 480 HP and 443 TQ power with stage 1 532 and 553 TQ the S58 is making more power on lower grade fuel. If you compare the 2 on the same grade fuel like 91 the S58 is making 561 HP and 567 TQ
DKX4///M757.00 |
02-01-2020, 11:15 AM | #16 | |
Rep 99
It's an OTS tune for shit gas, of course it's going to be really conservative When I ran BM3 on my B58 M240i, I saw better results on normal stg1 vs the ACN stg1, and I live in CA with our shitty 91. For my car....logs looked better on the normal stg1 than the ACN, and car felt stronger. Results may vary....
2020 BMW X3M Competition
2019 MINI Cooper S 2006 MINI Cooper JCW GP--GP1599 |
02-01-2020, 12:07 PM | #17 | |
Rep 1,219
S58 Stage 1 ACN91 octane: 11%HP / 25% TQ Stage 1 91 octane (95 RON): 17% HP / 28% TQ Stage 1 93 octane: 21% HP / 31% TQ S55 Stage 1 91: up to 20%HP / 22%TQ Stage 1 93: up to 22%HP / 23%TQ I mean its definitely interesting how there is only 2% different in S55 and 4% in S58. But then again testing has only just begun so I can only assume these figure will increase over the next 12 months. Nobody wants to hear a shameless plug for racechip
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
02-01-2020, 03:54 PM | #18 | |
Rep 356
The S55 Stage 1 ACN 91 gains are not listed there, but I can assure you that it is very close to Stage 1 91. This is not the case with the S58. The question is: why are they so far apart for the S58? |
02-01-2020, 04:05 PM | #19 | |
Rep 356
Obviously, you're correct about the part where you compare the two on the same non-ACN 91 fuel. My question about the low grade fuel still remains unanswered though -- why is the gap so high between ACN91 and 91 for the S58, but not the S55? |
02-01-2020, 04:43 PM | #20 | |
Rep 95
Take an s58 use 91 ACN file fill with gas from the same gas station you use then compare results on the same dyno. That’s literally the only way even then the tune is brand new. Right now we are comparing apples to oranges. Time will tell if your theory is correct of course but right now there’s not enough information to know for sure. My 2cents |
02-01-2020, 04:47 PM | #21 | |
Rep 1,219
02-01-2020, 04:51 PM | #22 | |
Rep 99
Try your S58 with ACN91 gas and tune, then try stg1 with "better" 91 and I think you will find similar results and gains that you saw on your S55. You live in Germany...why are you using ACN91 tune anyway?
new2the3381.50 |
