06-10-2022, 02:55 AM | #1 |
Rep 29
Exhaust Valve Controller
Had CG VSC-2 on my F82 M4 and it worked a treat, is there such a controller for the LCI X3M Comp?
06-10-2022, 09:08 AM | #3 |
Rep 128
with OEM Exhaust? Do you really notice a better sound improvment?
Incoming - X3MC F97 LCI ByeBye - M3 F80 ZCP LCII |
06-10-2022, 10:03 AM | #4 |
Rep 1,277
Drives: 2024 BMW M4 Base
You want volume? Skip the controller and swap the midpipe to delete the secondary cats and resonator. Or if you need to keep the secondary cats look at the Dinan X pipe. ER mid pipe here…
thestimp975.00 |
06-10-2022, 10:58 AM | #5 | |
Rep 4,392
Drives: 2022 F97 X3M Comp LCI
the valves open up at standstill (when transmission is in Park or Neutral), but the moment you shift into D the valves damn near close immediately and never really fully open up unless at WOT. even with a full akrapovic exhaust the car sounds damn near OEM to me. ive driven without the valves (fully open) and it was sooooo much louder. I assume it'd be the same with any other setup. valves really make a difference. I've already ordered a VSC-2 controller (read that it works on the G8x platform so I figured it would be the same for the F97) a month ago and still waiting.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
Ftpohyeah285.00 |
06-10-2022, 11:23 AM | #6 | |
Rep 1,277
06-10-2022, 11:28 AM | #7 |
Rep 1,700
Working on it....
06-12-2022, 02:52 PM | #8 |
Rep 483
I have an Akra set up but same concept with the controller. The sound is unrestricted with the valves open and makes the car sound more natural. I programmed my mirror buttons to control the valves open/normal function and the Dahler remembers the last setting. I leave my valves open and only go to normal mode for service or when I am on a call in the car.
06-13-2022, 08:47 AM | #9 | |
Rep 4,392
ive had the vsc-2 on my old F80, but was wondering where you would put the controller under the F97. any fitment issues when it comes to length of the cables? if CG precision continue to ignore my emails for another week or so I'm about to cancel the order and get the Dahler and would like a clean install.
06-13-2022, 08:58 AM | #10 |
Rep 688
Drives: 22 TR X3MC
Is there anyway to code the existing exhaust button to full open the valves?
2022 X3M Comp
2013 335i xDrive (Sold) |
06-13-2022, 11:09 AM | #11 |
Rep 1,277
06-13-2022, 11:11 AM | #12 |
Rep 688
Drives: 22 TR X3MC
The difference in sound is minimum with the exhaust button
2022 X3M Comp
06-13-2022, 11:26 AM | #13 |
Rep 1,277
06-13-2022, 01:13 PM | #15 |
Rep 562
I pulled the valve fuse on my pre-lci and while it is quite a lot louder when driving which is kind of cool, it has a pretty obnoxious drone during the high-idle phase during cold start or re-start after a drive. Having a controller like this would be a good mix so I could mute it during those parts, but open it up whilst driving. Hopefully someone finds a good source for them.
07-24-2022, 09:55 AM | #16 |
Rep 68
If I'm reading it correctly the JB4 has flap controls for F97 (doesn't work for G8X). Does anyone have any experience with this? Or would it be better to just get a separate controller?
07-25-2022, 07:52 AM | #17 | |
Rep 4,392
I got the VSC-2 and it works well. haven't had an issue yet.
07-25-2022, 09:37 AM | #18 | ||
Rep 68
07-25-2022, 09:44 AM | #19 |
Rep 4,392
simple. took me 5-10 mins to install to see if it works, another 10 mins or so just to clean up the wires by rerouting and using electrical tape.
Lifted55.50 |
07-25-2022, 10:38 AM | #20 |
Rep 441
08-08-2022, 12:41 AM | #21 | |
Rep 169
Are you on stock exhaust? Curious what it sounds like with a stock system. Will sport plus and other modes still sound different with the controller open and closed? Is closed just back to factory mode? Thanks |
08-08-2022, 08:31 AM | #22 | |
Rep 4,392
2. They will sound less different with the valves fully open since they will be open ALL the time. The difference in the modes will come down to the "burbles". Volume itself will remain constant throughout the rev band. 3. No. There are three options you can program with the VSC-2.. OPEN (valves open ALL the time), CLOSED (valves closed ALL the time), and AUTOMATIC (OEM/Factory Control).
