02-24-2020, 08:53 AM | #1 |
Rep 4
Lost key help!
Hi all,
This is kind stupid, but life is like that. My wife lost the key to my car inside it and after countless searches we cannot find it anywhere! She doesn't remember dropping it or anything so I don't even know where to focus. It's driving me crazy. I know the key is inside the car because if I leave it unlocked I can start it and drive away. I left home with my phone, to lock/unlock the car with bmw connected, and drove the car all day without issues. I've looked in all the obvious places like the glove box, bellow the seats, armrest, ... doors. I've also looked at some not so obvious places, like the plastic vents beneath the seats, and as far as i can put my hand inside i cannot feel it there. Any idrive feature that can pinpoint the location of the key inside the car? Can anyone give me some hints on where the hell can this key be hidden? Thanks alot |
02-24-2020, 08:56 AM | #2 |
Rep 223
Drives: X3 M40i (MY19)
Hmm...
Usually you can't lock the car if the key is detected inside the vehicle.
Jens Ejvinsson, Sweden
BMW X3 M40i (MY19), every option in the book, Pictures BMW X1 20d M-Sport xDrive (MY17), Nav, HUD |
nyalpine907433.00 |
02-24-2020, 09:05 AM | #3 |
Rep 4
02-24-2020, 09:17 AM | #4 |
Rep 223
You can run the car without the key, but you can't start the car without it.
02-24-2020, 10:16 AM | #5 |
Rep 11,843
Drives: MY24 G01 AW Msport
i dont think you can shift into D if the key is not present.
you cant lock the car if key is inside the car. |
02-24-2020, 10:47 AM | #6 | |
Rep 4
I can start the engine without having any key in the car. |
02-24-2020, 11:12 AM | #7 |
Rep 11,843
did u check slot in center console by cup holders, above usb port |
02-25-2020, 08:32 AM | #9 |
Rep 496
Keep us informed - curious where it tuns up.
FYI, I have tossed my jacket with the key in the pocket into the rear cargo area and car still started, thus it could be anywhere in the car. Sometimes we empty our hand when we need to open, hold something. So not in the glove compartment but putting the key down to open the glove compartment. My back seats are almost always down, I found something that fell into the cack between the cargo floor and the collapsed seats. I forgot how I retrieved it, but it did not end up on the seat when folded back up. Last edited by kevinkay; 02-25-2020 at 09:29 AM.. |
02-25-2020, 10:25 AM | #10 |
Rep 596
The seats remove fairly quickly; I'd pull the front seats first, look closely, and if not found pull the rear seat out.
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
02-25-2020, 12:05 PM | #11 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Wait. Can you lock your car doors with another remote? You should not be able to lock the doors from the outside if the key is inside. Also are when you are in the car are you able to start the car or do you get a insert key message?
Also keep in mind the key could possibly be outside on the ground maybe close proximity to the car where it reads it? Good luck. But this is interesting.
02-25-2020, 08:32 PM | #12 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,207
Trust me it's in there somewhere. There is no easy way to find it other than really digging around. You may need to remove the seats. Check under the rear seat as well. It IS somewhere in that vehicle If you can start it.
02-25-2020, 08:34 PM | #13 | |
3511
Rep 4,207
For example if you left key 1 in the cup holder and locked the car with key 2, you should theoretically not be able to break the window and grab key 1 and start the vehicle and drive off. I would actually like to try this sometime as I have never actually verified this feature. |
02-26-2020, 05:01 AM | #14 |
Rep 107
I know of at least one place in the car where small things like coins and keys can easily get lost without any trace. The ISOFIX points in the rear seats have a cover that lifts up but it's all hollow inside. My kid accidentally dropped a coin in there and I wasn't able to recover it. The coin is obviously under the rear seat but there's no rattle and no trace of it whatsoever. It would have to be a stroke of (bad) luck, if somehow your key got dropped in there. You can possibly recover it by removing the rear seat but I have not tried that on mine.
03-03-2020, 10:10 PM | #15 |
2314
Rep 2,885
OP so where is you key?
03-04-2020, 07:37 AM | #16 |
Rep 4
hi!
Sorry for the lack of updates, but so far I've had no luck. I didn't invest a lot of time but i did check the isofix points and the space between rear seats and cargo bay. I'll update when i get some new developments on this breaking story. |
03-04-2020, 08:36 AM | #18 |
Rep 2,244
try in the air vents under the seats. they are pretty big and things can do into them. other than that, do you have the little cubby hole next to the steering wheel / a sunglasses holder
10-02-2020, 09:53 AM | #19 | |
Rep 2
Please Help Me Too
Please let me know if you found your key. I have checked in every nook and cranny (except the one the key is in |
10-02-2020, 11:30 AM | #21 | ||
3511
Rep 4,207
10-02-2020, 12:07 PM | #22 |
Rep 1,044
The space between the seats and the console is a black hole.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
