02-20-2020, 07:39 PM | #1 |
Internet Weasel
769
Rep 763
Drives: 2023 X3 M40i
In Defense of ASD
I know people really dislike ASD (Active Sound Design, or, engine noise supplemented through the stereo system). Nonetheless, I'd like to lay out a few points in favor of this feature. I currently have had it turned off for a few days now, and I will probably code it back on after a week or so of experiencing what it's like without it.
Here's why I understand BMW's impulse to increase engine sounds using artificial means:
There are definitely some points against ASD:
Anyhow, just my thoughts. Feel free to disagree vehemently. These cars are all in good fun. |
02-20-2020, 08:07 PM | #2 |
Rep 1,495
Honestly, I really don't mind - maybe even enjoy - the ASD in my M40. It would actually give me a headache on trips over ~30 min in my F80, so I coded it off. Definitely don't feel the need in the M40.
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
02-20-2020, 08:25 PM | #3 | |
Rep 115
02-20-2020, 08:56 PM | #4 |
New member
318
Rep 553
Removing the fuse, coding ASD off, or using the ASD bypass harness does exactly the same thing. Take your pick. The only difference is that if you pull out the fuse and don't put it back before a dealer visit, your dealer may run into issues updating the software on your car.
02-20-2020, 09:24 PM | #5 |
Rep 8,028
Drives: 2024 X5 M60i
I spent a vast majority of my first year of ownership with the ASD fuse pulled. I recently put it back in so that the dealership wouldn't run into any issues when performing the camera software recall update. The fuse has been back in for about two weeks now and I can definitely tell a difference but overall I haven't been majorly annoyed with it. I will likely pull the fuse again at some point. Overall put me down as one that is indifferent in regards to the matter.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
02-20-2020, 09:29 PM | #7 |
Rep 8,028
I believe that is only on 2020 models currently. The 2018 & 2019 models definitely don't correlate with the two.
02-21-2020, 06:44 AM | #9 |
Rep 911
Drives: 2020 X3 M40i
I get your points, OP. And I will add, the car is quite quiet with ASD coded off. I can understand someone feeling that some of the fun is let out when you cannot hear the engine roar.
..But for me, ASD is a big lie. I bit like clipping a playing car into your bicycle spokes as a child. It’s not your real engine noise. I don’t mind so much when they put a tube from your intake through the firewall - that’s your actual engine and that’s real engine noise. But to artificially create noise and play it through the stereo system? Some BEV vehicles have looked into doing this - using v8 engine sounds as the electric motors are someone sensorial lackluster. I don’t know that any have actually brought this to market yet.
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
02-21-2020, 07:30 AM | #10 | |
Deadly
1311
Rep 2,068
As an aside, since I have HK and thus two subwoofers, I wonder the ASD must be a poorer experience in those who do not have? |
02-21-2020, 08:39 AM | #11 |
Rep 3,689
The 2020 models have the option to set ASD according to your preference - dynamically according to driving mode, loud or reduced - but not off. I find the dynamic/loud settings a little artificial, so run with reduced. However I would be severely hacked off if the reduced setting impacts the physical valve opening as well as the in-cabin sound. Unlike the OP I want people outside the car to hear what a nice expensive car I’ve bought, and marvel at the paucity of my reproductive gear
Has anyone managed to empirically confirm that this is (or indeed isn’t) the case? |
dmlgc88.50 |
02-21-2020, 10:18 AM | #12 |
Internet Weasel
769
Rep 763
Yeah, I had not understood there to be a relationship between coding ASD off and the exhaust valves--and I have a 2020. I know that, at least in prior years, you could pull fuse 218 to turn off ASD so long as you have HK, and 203 to impact the valve. I find the threads on that latter one ambiguous as to whether pulling fuse 203 requires that you get the valve into an open state first and then pull the fuse to lock it that way or it just opens permanently after you pull it. I'm sure most of you know all this is discussed in How to disable ASD on your X3 M40i: 3 methods that do not require coding
Further ambiguity exists as to whether all this changed in 2020. However, Bimmercode makes it easy to turn on and off, and is pretty cheap if you use enet cables and your iPhone. |
02-21-2020, 06:27 PM | #13 | |
Rep 120
Drives: MY20 X4 M40i
02-22-2020, 01:34 AM | #14 | |
Rep 115
02-22-2020, 02:54 AM | #15 |
Rep 67
In 2020 m40i with ASD coded off but idrive engine noise set to loud/sporty, it's perfect IMO. When I had ASD on, the audio quality suffered pretty significantly to my ears and made music much less enjoyable. I can hear the engine plenty with it set to sporty/loudest.
02-22-2020, 08:27 AM | #16 | ||
Rep 8,028
rkx3m40i176.50 |
02-22-2020, 10:40 AM | #17 | |||
Rep 115
02-22-2020, 12:31 PM | #18 | ||||
Rep 8,028
02-22-2020, 02:37 PM | #19 |
Rep 2,221
On my X3MC I get all kinds of fake pops and burbles in sport+ mode.
I coded it off via Bimmercode but it doesn’t seem to have taken for some reason (I did it twice). Although it can sound pretty cool, I think of it the same way as someone putting an //M badge on a non-M car or a woman faking an orgasm . I would have liked that burble in only sport+ so I don’t have to listen to it all the time. I’ll have to pull the fuse as I require authenticity. What’s next? Are they going to put a speaker outside the car so passerbys can hear the fake engineered sound? |
02-22-2020, 08:18 PM | #20 |
Internet Weasel
769
Rep 763
I didn't think that ASD did burbles and pops. I think that's real. I think it just does vrrrrooom stuff.
02-22-2020, 09:26 PM | #21 | |
Rep 2,221
Keep in mind I have the X3Mc so that may be a factor. I understand the M40i has burbles and pops by default. |
02-23-2020, 03:03 AM | #22 |
Rep 1,642
Pardon the newbie question...but does ASD only do in-cabin sound, or does it also control the actual exhaust burble/pops?
And..do the newer M40i with particulate filter still make any special exhaust sounds?
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
