01-18-2020, 04:28 PM | #1 |
Rep 111
Drives: BMW X3 M40i, Carbon Black
Side Vent removal?
Anyone have any tips on removing the side vents? I have a set of gloss black ones from IND to replace the cerium gray but I cannot seem to be able to pry them loose and I am very worried about damaging the paint. There are lots of guides and videos online for the grills and mirrors but nothing for the side vents. Any tips?
I was able to swap out the grills and the mirror caps no problem but am stuck on these. Here is what I was trying to do: 1. Used painters tape all around the side vents to protect the paint. 2. From the new pieces it looks like the clips are all around the back/aft side so I used 2 different pry tools to try and unclip each one. I can get the pry tool in there but I haven’t been able to unclip anything and start to get them to wiggle free. If anyone has done this it would be great to learn. I’d really like to get rid of the cerium but not at the expense of the paint! |
01-18-2020, 04:50 PM | #2 |
Rep 914
I’m interested in this as well. I can’t find anything online. The easiest way I can think of is remove the wheel well liner and pop them out from behind. That’s the way I removed the reflectors on my M235.
01-18-2020, 05:22 PM | #3 |
Rep 194
I used one of those reference guides to show where the tabs are. But I can't find where on the forum I found it now. You should be fine just using the new pieces for reference. If I remember correctly, I used a plastic pry tool (a cheap one from amazon) and released all the tabs. I pulled it out enough to fit my fingers in and wiggled it loose, pulling toward the rear of the vehicle. I had to pull on it a little harder than expected, but it also turned out I broke half the tabs on both sides. But no damage to the paint.
Good luck! It'll look a lot better once you're done! |
01-18-2020, 05:22 PM | #4 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
There are at least 5 threads on this. Some have actually have clear instructions.
They pop out with a pry tool from the backside of the car. And you full them to the backside also. To remove the fender is just silly. Side Vents https://x3.xbimmers.com/forums/showthread.php?t=1627475 Anyone have the install guide videos for the side vents, mirror caps and boomerangs? https://x3.xbimmers.com/forums/showthread.php?t=1598370
01-18-2020, 05:23 PM | #5 |
Rep 8,030
Drives: 2024 X5 M60i
My side vents popped off extremely easily. Used a trim removal tool and had both sides off in under a minute and he new ones from IND popped right in without issue.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
01-18-2020, 06:17 PM | #6 |
Rep 111
Yes, I see there are other threads but most of them just "stick a pry tool in there an it pops right out" or something to that effect. I must be an idiot and/or too nervous with respect t to the paint. Was hoping for something more detailed.
Ironically, i thought these would be the easiest and grills and mirrors would be hard. Did all of those in less than 20 minutes but no go on this one. Maybe I will have another go at some point. |
01-19-2020, 05:00 PM | #7 | |
Rep 120
Drives: MY20 X4 M40i
01-19-2020, 05:58 PM | #8 | |
Rep 111
01-20-2020, 08:23 AM | #9 | |
Rep 914
01-20-2020, 08:29 AM | #10 | ||
2314
Rep 2,885
Marmugmotleocay1568.50 |
02-22-2020, 02:46 PM | #12 |
Rep 111
I finally, finally completed this task. You all were right, once you approach it with confidence it’s a pretty simple task. It does take more force than I expected and putting the new ones back in was trickier than I thought but it probably took 10 minutes total and most of that was me prepping the car with painters tape.
Thanks all! |
chicagofan0019143.00 Mpetey75.00 |
02-23-2020, 08:05 PM | #13 |
Stay Tuned!
297
Rep 390
You can try what I did to get mine out. I got hit by a spinning pathfinder on ice.
The things just popped right out with no broken tabs. Paul Reminds me of Ron White talking about his friend that was all decked out in hunting wear, who woke at the crack of down, and quietly waited for the deer. Ron said that you need to be driving a 4K lb minivan with lights on, horn blowing, and the driver screaming. He said you'll get a deer every time! |
02-24-2020, 01:17 PM | #14 | |
Rep 111
dinan5m34263.50 |
