      03-28-2024, 08:19 AM   #1
JOE YOUNG
SEAL TEAM SIX
JOE YOUNG's Avatar
Drives: E46 E90 E84 F30 X3G01 LCI
leak from Roof
Hi there
Any one had this issue where a water leak is coming from the Panoramic roof Control Panel and also running down from the A pillar to the floor.
Floor mat is soaking wet.
Had the car from new, 22 model and probably only opened the pan roof a handful of times.
I haven't thoroughly looked around the Pan roof as I just found out last night and its pissing rain still.
I have already booked the car as its under warranty.
Just want to know what could be the cause.
Thanks much
DON'T MAKE ME ANGRY!
GO1 LCI PHEV 30e. M Sport plus Pack, Tech Plus Pack, Comfort Pack, Pano sun Roof, Sensatec dash with Blue stitching, HUD, Galvanic controls.
      03-28-2024, 08:35 AM   #2
avi66
avi66's Avatar
Drives: X3 M40d LCI
Originally Posted by JOE YOUNG View Post
Hi there
Thanks much
Possibly blocked sunroof drain.
There is one drain tube at each corner, and if they become blocked, water builds up in the pano roof tray and overflows, resulting in what you’re experiencing. The front drains are visible when the front doors are open and can be found below the door tension link.
      03-28-2024, 10:48 AM   #3
BMWbiker
Drives: 2015 328i xdrive wagon
I had this happen with a previous non-BMW car. The dealer unblocked the drains and all was well.
A BMW car and several BMW motorcycles
      03-28-2024, 10:57 AM   #4
avi66
avi66's Avatar
Drives: X3 M40d LCI
It’s a poor design, especially as the pano roof seals shrink and allow more water through. Just needs some organic growth or a build of detritus, and you end up with a fish tank.
Also needs care clearing the drain tubes as it’s possible to disconnect them from the roof tray and they have a small diameter.
      03-28-2024, 11:15 AM   #5
BMWbiker
[QUOTE=avi66;31026157]It’s a poor design, especially as the pano roof seals shrink and allow more water through. Just needs some organic growth or a build of detritus, and you end up with a fish tank.
Also needs care clearing the drain tubes as it’s possible to discount them the roof tray and they have a small diameter.
Is this something that is done at the 10K service? Or should I request it? Or is it easy to DIY?
      03-28-2024, 11:20 AM   #6
avi66
avi66's Avatar
Drives: X3 M40d LCI
[QUOTE=BMWbiker;31026197]
Afaik it’s not done on any BMW service. It’s usually down to the owner to improvise a cleaning device, such as the thick nylon cord used by garden string trimmer etc. Hence my comment about being careful.
      03-28-2024, 01:07 PM   #7
BMWbiker
Thanks for the info. I got to thinking about it, after washing flower buds from a tree off of my car yesterday.
avi662698.50
      03-28-2024, 05:56 PM   #8
JOE YOUNG
SEAL TEAM SIX
JOE YOUNG's Avatar
Thanks for the reply.
Funny thing is, I probably only opened it twice in 2 years, which is why Im wondering how could it be blocked. Does the drain share drainage with the windscreen drain as well?
But would check tomorrow when its not raining.
      03-28-2024, 06:29 PM   #9
ContactPatch
ContactPatch's Avatar
2139
Drives: It's Quick!
Amazon has this tool and many more like it for less than $10...
https://www.amazon.com/Brush-sunroof.../dp/B09SWSVZ8Z
...if you don't want to use .065 string trimmer line. Handy tool to have for this particular car.
Rottweiler3983.00
      03-28-2024, 08:20 PM   #10
Plusforce
Plusforce's Avatar
156
Drives: 2023 X3 M40i
Is there any way to clean the two drain pipes on the back? I only could find the front ones.
      03-28-2024, 09:22 PM   #11
peeezy
Drives: x3 m40i g01
open ur sunroof all the way back. you will them see it then.
Plusforce156.00
      03-29-2024, 04:20 AM   #12
avi66
avi66's Avatar
Drives: X3 M40d LCI
The drains are sunroof only, but water can get past the seal pretty much around the entire perimeter, even with the roof closed. It’s a bit like a door seal that attaches to the glass side, but just presses on the out edge of the roof.
Problem is it’s constantly exposed to UV and environmental containments, which cause it to shrink. Water can then build up even without opening the roof, resulting in organic sludge forming that can block the drain.
      03-29-2024, 06:04 AM   #13
avi66
avi66's Avatar
Drives: X3 M40d LCI
Here's why you need to be careful not to damage the front sunroof drain !
      03-29-2024, 08:49 AM   #14
rob175
rob175's Avatar
Drives: BMW X3 xiDrive30
From the video, the rear drain looks to be a total PITA to clean. I would think that IF you can get under the car it would be easier to clean out the drain from the outside instead of taking so much of the interior out.
I assume the drain is visible from under the car since the water must drip onto the pavement.
Plusforce156.00
      03-29-2024, 01:31 PM   #15
Plusforce
Plusforce's Avatar
156
100% agree!
