03-27-2024, 12:03 PM | #1 |
Rep 648
Drilled rotors for m40i with M-Sport brakes?
Hi guys,
I'm looking for drilled rotors (front + rear) for my M40i with M-Sport brakes. I mainly want a better look, and if I can get better heat management, that would be a plus. Has anyone here tried the rotors from ECS Tuning? https://www.ecstuning.com/b-ecs-part...4116860911-xs/ Or can you guys please recommend some other options? Thanks!
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
03-27-2024, 12:08 PM | #2 |
Captain (Retired)
3983
Rep 1,728
Drives: X4 M40i
https://www.tarox.com/us/aftermarket/
Part #’s 5550 & 5551 https://paragonbrakes.com/gr-supra-mk5/ Not cheap |
jrveron265.50 earlgsxbusa112.50 |
03-27-2024, 12:28 PM | #3 | |
Rep 648
03-27-2024, 12:29 PM | #4 |
Captain (Retired)
3983
Rep 1,728
Drives: X4 M40i
03-27-2024, 12:38 PM | #5 |
Rep 648
And what about pads for these rotors? Are you using the ones from Tarox? https://www.taroxbrakes.us/product/f...48x36mm-discs/
03-27-2024, 12:55 PM | #6 |
Captain (Retired)
3983
Rep 1,728
Drives: X4 M40i
No
I went with Power Stop ceramics Akebono did not have both front/rear for my car at the time; not sure if they do now In hindsight I would’ve gone with one of the EBC options but the PS’s have been fine thus far |
earlgsxbusa112.50 |
03-27-2024, 01:03 PM | #7 |
Rep 6,032
You mentioned doing this for aesthetics. Here's a good summary of some pros/cons with advice for a daily driver, albeit written by a supplier.
https://www.r1concepts.com/blog/maki...r%20pad%20wear.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
03-27-2024, 06:40 PM | #8 |
Rep 721
Drives: 2018 530e
At some point I’m swapping for some ceramic pads just because I like the low dust. How are the Power Stop pads treating you?
2018 BMW 530e Alpine White | Black Napa Leather | Bone Stock
03-27-2024, 06:49 PM | #9 | |
Captain (Retired)
3983
Rep 1,728
Drives: X4 M40i
If I ever felt that they were inadequate then I’d go with EBC’s (unless Akebono is now making pads for both front and rear) |
TXGrey1284.00 earlgsxbusa112.50 |
03-27-2024, 09:10 PM | #10 | |
Rep 721
Drives: 2018 530e
Rottweiler3983.00 |
03-27-2024, 10:03 PM | #11 |
Senior Chief (Ret.)
72
Rep 180
Drives: '90 M3, '05 ZHP, '24 X4 M401
Swapped my '24 G02 brakes to Power Stop from Rock Auto at 740 mi and using the OEM Rotors. I had the brakes installed professionally by my mechanic since my back is out of whack. No squealing, No rumbles. Smooth all the way. Hope this helps.
1990 M3
2005 ZHP 2024 X4 X40i SCPO SW USN (ret) BMW CCA 192742, NRA Life Member, F&A M |
jwong77320.50 |
03-27-2024, 10:14 PM | #12 |
Rep 721
Drives: 2018 530e
Perfect! And do your wheels stay clean longer now?
03-28-2024, 10:16 AM | #13 | |
Rep 648
What I meant with "mainly aesthetics" is that since I won't be installing a larger rotor (395 or so), I won't feel a considerably better braking. I would also love to install a Brembo 6-piston BBK (https://www.vividracing.com/Brembo-G...153125553.html), but that could probably be overkill in my situation. If I stay with the same size rotors but drilled/slotted, and harder pads, I could probably feel a better bite or hopefully some better heat management, but being honest, aesthetics will be the main factor.
X3rd Time Is a Charm2812.50 |
03-28-2024, 10:24 AM | #14 | |
Rep 648
Greenstuff has better friction, better fade resistance, and better cold bite (this is reasonable considering yellowstuff starts getting better once hot).
03-28-2024, 10:56 AM | #15 | |
Rep 708
Drives: BMW 2018 X3 GO1
Present:
Jet Black 2018 X3 30i Previous: Sapphire Black 2013 X3 28i , Jet Black 2007 X3 3.0 Liter |
03-28-2024, 11:00 AM | #16 | |
Rep 6,032
03-28-2024, 11:01 AM | #17 | |
Rep 648
After reading so many complaints, I don't feel confident about their products.
03-29-2024, 10:22 PM | #19 | |
Rep 648
Can someone please shed some light here?
03-29-2024, 11:09 PM | #20 |
Rep 1,769
Drives: 2022 X3 M40i
Blue is a full track pad and won't work unless hot.
Yellow is Essentially a street/track pad, ok when cold, great when hot but will eat through the rotors and wear fast, super dusty....green is everyday semi metallic and red is everyday but a ceramic lowest dust |
Rottweiler3983.00 earlgsxbusa112.50 |
03-30-2024, 11:45 AM | #21 |
Rep 1,769
You want rotors..I'll show you the stinking rotors...I did purchased 2 piece rotors from ECS/Turner Motorsposrts earlier this year....Bad idea. Ive been dealing with BS for about over a month now and still waiting for a refund.
Anyway with a set of stainless steel lines coming in from Goodridge and these 2 piece rotors from Paragon, I'll be ready for the track... Last edited by Burr001; 03-30-2024 at 11:57 AM.. |
03-30-2024, 10:10 PM | #22 | |
Rep 648
Talking about Paragon rotors, did you keep the same size? Talking about Goodridge SS, I installed them on my previous X1, although they didn't come with the proper rubber to hold them in place on the wheel hub (please see attached pictures for reference); they came with a generic rubber piece instead. I want to order them for the X3 (https://www.goodridge.co.uk/collecti...w-387-hp-09-19), so please share your thoughts once you receive them. Thanks!
