08-08-2020, 10:48 AM | #1 |
17963
Rep 9,377
a
08-08-2020, 12:32 PM | #4 |
Rep 5,577
are both pieces the same smoothness ? I'd probably choose A also for furniture quality.
But B would make a really good looking box or something. Are both pieces cut to size and sanded or are you going to add finish ? |
08-08-2020, 01:25 PM | #6 |
17963
Rep 9,377
It's already cut for the table and each side has a single coat of varnish at this point. These are BBQ tables that used to have particle board as a top
Here's the one I finished last week
overcoil3073.50 Lucky John616.00 |
08-08-2020, 04:26 PM | #8 |
Rep 1,031
Drives: Like a bat out of hell.
I like the knot in the wood
08-08-2020, 04:33 PM | #10 |
17963
Rep 9,377
Outdoors
This plywood is A/C
08-08-2020, 04:47 PM | #11 |
Rep 826
I see. Well, personally, I would go with "C" if it was varnished/stained something a bit darker. Looks too plain the wait is now imo. Needs some spice if you will.
08-08-2020, 07:34 PM | #12 |
Recovering Perfectionist
15141
Rep 941
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
Personally, I'd lay out today's newspaper on either side, and hit it with several coats of "clear" polyurethane. Every single time that I have ever tried to finish wood, it always ends up with newspaper embedded in the finish. I said that if I were ever doing wood finishing again that I would intentionally seal the newspaper onto the finished surface to save myself some time.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
08-09-2020, 06:03 AM | #14 |
Rep 2,476
A/C, alone, doesn't mean it is suitable for outdoor use. That is just the surface ply "quality" designation, i.e. one side is A grade, while the other is C grade...like what you show in your photos where one side has all of the knots(C) and the other doesn't(A).
For it to be suitable for outdoor use, there need to be additional designations, which vary by manufacturer and will say things like "exterior", "exposure x", "x"...you pretty much have to look up the manufacturer's spec sheet to determine what it is. To take that further, most plywoods that have an exposure rating can only withstand that exposure a limited amount of time before they begin to fail and delaminate. Last edited by Emilime75; 08-09-2020 at 12:51 PM.. |
08-09-2020, 12:23 PM | #15 |
Rep 2,869
I vote side A. They make a marine polyurethane that is VERY durable, but if it isn't true exterior grade it will only be a matter of time. I'd use it on the finished one, either way, since you already have the time into it. But wouldn't sink more time into cutting/sanding more if it isn't exterior grade (looks like it would make nice shelving or other inside uses).
08-09-2020, 02:09 PM | #16 |
17963
Rep 9,377
Outside folding table when I take it out of storage. For the day at most. Won't be leaving it out in the elements
08-09-2020, 03:57 PM | #17 |
Rep 5,577
08-10-2020, 12:40 PM | #19 |
17963
Rep 9,377
08-10-2020, 05:09 PM | #20 |
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
08-11-2020, 04:54 PM | #22 |
Rep 4,365
I would knot go with the nots. The smooth side looks better and if you want character you can do that with a finish or an insert if you want to put a tad more work in.
