08-24-2020, 12:20 PM | #1 |
Rep 169
Thud Noise when driving off
Hi All
Hope your all keeping safe in these strange times. I am looking for a little reassurance from fellow X3MC drivers. I have noticed when I put the car into gear wether it be drive or reverse as I pull off i get a low level thud in the rear middle of the car You can definitely hear it every time you go for a gear, I can't say I've noticed it before it had it's RIS or I may have just become paranoid about it. Not sure if its just the Drive system kicking in. So just looking to see if any of you guys have the same noise before I ring the Dealer as he's not just round the corner. Cheers in advance Steven. |
08-26-2020, 11:25 AM | #2 |
Rep 192
I'm not hearing or feeling any clunks when I put the car in any gear. You may want to have that looked at. My Macan had a transfer case replacement early in its life due to a clunking when I took off from start & at low speeds. I can't imagine you're having the same issue here.
2021 Cayenne GTS * 2021 AMG GLE 63
2019 911 Targa 4 GTS, Carrara White Metallic 2008 911 Turbo Cab, Speed Yellow 1997 911 Targa, Zenith Blue 2017 GT3-RS Lava Orange (LEGO) |
08-27-2020, 12:19 PM | #4 |
Rep 169
Hi Thanks for the replies.
Just to double check do you guys get any noise at all when you drive off either reverse or drive I'll keep ear on it and try to get it booked in at the dealers |
08-27-2020, 04:18 PM | #5 |
Barge driver
8653
Rep 12,424
Well a thud is more of a physical feeling than a noise to me, plenty of noise from the exhausts but no thud or perhaps more accurately drive train shunt..
730d/Z4C
08-28-2020, 01:08 AM | #7 |
Craig
233
Rep 389
no noise of strange feeling from mine when driving off either in reverse or first
f97 x3m competition Donnington/Adelaide.
f80 m3 competition pack white/black gone f15 40d space grey/ ivory/black gone f31 335i mineral grey/coral gone but will be missed. gone 2014 range rover sport dynamic. |
09-09-2020, 12:58 PM | #8 |
Rep 169
HI All
Just a little update drove the car the other day with the window down to see if you can hear the noise outside. You can hear the noise but outside the sound is more of a loud metallic clunk rather than a thud. Car has been at the dealers for a couple of days now to have this and another couple of jobs looked one of which is the brakes pads biting onto the discs when i wash the car. The other day I had to put 1500 revs on to make the car move due to the brakes biting onto the disc. Rang the Dealer today to see how the cars going. They have cleaned the brakes to try to help with them biting on but it is a problem with M cars apparently. According to the dealer the noise is caused by the brakes which I find a little strange as most of the time its in the centre of the car. Due to collect the car tomorrow so we will wait and see. P.S Need another new tyre that's 2 new tyres and 1 reaper on a car that hasn't covered 1400 miles yet. Thanks for all the replies. |
09-10-2020, 12:55 PM | #9 |
Rep 169
Went to collect the car today. Put the car into drive and guess what the noise was there.
So went back into the dealer technician came out scratched his head and said we are going to need the car again. Apparently he's need to start stripping thing to find the source of the noise. Up shot is car goes in next Monday fro another week. Cheers steven |
09-10-2020, 02:55 PM | #10 |
Barge driver
8653
Rep 12,424
A thud due to the brakes binding is a thing every now and then but even the UK during the summer it shouldn't be a repetitive issue.
I've had the brakes bind and "thunk" many times but generally in the winter if the car has been standing for a few days.
730d/Z4C
09-10-2020, 03:08 PM | #11 |
Rep 169
Thanks for the reply Wills2
Thinking about it thud is probably the wrong word it's more like a popping noise. I tried to explain to the technician I know I will get binding and scraping sounds from the brakes if the car has been washed or not used for a while but that usually goes after a couple of miles this popping noise is there nearly every time I select a gear. Both the technician and service desk member heard the popping noise so hopefully they can get to the bottom of it. Cheers Steven. |
Wills28653.00 |
09-10-2020, 03:15 PM | #12 | |
Barge driver
8653
Rep 12,424
It must be quite loud as well to hear it above the cold start exhaust, I'll have listen tomorrow to see if I can hear anything out of interest, could it be the diff or more likely the gearbox? Hope they can sort it.
730d/Z4C
09-10-2020, 03:22 PM | #13 |
Rep 169
It's when you go from P into D or R not really noticed it when using paddles but will have a try using them over the weekend.
It is quite loud especially from outside the car inside is more o muffled pop. The service desk advisor was stood a fair distance from the car when she came out to listen and she could clearly hear it. Like you I think it's either the Diff or the gear box. |
09-16-2020, 07:07 AM | #14 |
Rep 169
Rang dealer today to see if the cars going to be ready for tomorrow.
Apparently they have had to get BMW technical involved who gave them a test to do but they need to do another test today. Test takes 3-4 hours and they will not know what's wrong with the car till this test is done. Up shot is they can't say I will have my car for the weekend till they get the results of this test. |
Wills28653.00 |
09-16-2020, 09:44 AM | #15 |
Rep 192
I'm a bit underwhelmed with the car at the moment - I got it back after the dealership had it for two weeks to replace a malfunctioning rear differential sensor & to repaint the rear bumper.
Went to back into my parking space this morning at the office & had a message pop up about a parking sensor malfunction. I'm going to see if it happens again, but I'm not happy to have another error message pop up two weeks after I get my car back.
09-16-2020, 01:15 PM | #16 | |
Rep 2,221
I had a TPMS error which left a code and they didn't do anything to fix it and it popped up again after I took the car back. It has now gone away but they didn't even try because it wasn't on the dash at the time. |
Macanakey138.50 |
09-16-2020, 01:24 PM | #17 |
Rep 169
To be honest I'm not to impressed with my first M car it has only covered 1450 miles and to have an issue were they need to involve BMW technical to me its not an easy fix and doesn't fill me with confidence for the future. I do know new cars have issues but my last 3 BMW's (all 5 tourings) never had an issue which required BMW technical. Had the last one for over 3 years and it never put a foot wrong. Hopefully get some info tomorrow on what the fault is. |
09-16-2020, 05:55 PM | #18 | |
Rep 59
Whenever I start, hear lots of revs and noise from the exhaust, gentle on the throttle to move forward, revs drops but it is a little aggressive as the brake releases. Wouldn't describe as a thud though. |
Wills28653.00 |
09-17-2020, 12:07 AM | #19 |
Rep 169
Out of interest I checked the tracker app last night and noticed that the car hasn't moved for over 36 hours.
According to the app the car is sat in a compound at the back of the dealers and has been there since Tuesday afternoon. So they either don't need the car in the workshop to do the test or someone is telling me porkies. |
09-17-2020, 04:18 AM | #20 |
Rep 169
Rang the dealer this morning. Apparently the issue is with the prop shaft. So they are having to drop it off the car re lube it and put it back on this fix works in most cases but won't know till the car is retested after repair.
It's apparently been an issue with M3 and M4 cars but mines only the 4th X3MC in the UK with this issue. To say I'm not impressed is an understatement and to be honest if the fix work I don't want the car back. This sort of issue on an M car after 1400 miles has finished me with this car. Thanks for reading and all the replies. |
09-17-2020, 05:02 AM | #21 | |
Barge driver
8653
Rep 12,424
I think there are plenty of ghosts in this machine.
730d/Z4C
09-17-2020, 03:05 PM | #22 | |
Barge driver
8653
Rep 12,424
Although I have to say this is the first BMW regardless of M or not I've had that hasn't been a German made one and although we don't want to ascribe cultural stereotypes I do feel it's a bit like a BL car built at Longbridge as I've had many niggles and certain parts of the build quality are well below par with this car, ones that haven't been present on the others. The good news is if you're not happy and want to jump the pricing is very strong at the moment on them so shouldn't be too painful, I have thought about jumping out myself however the engine is for me wonderful as is the handling so I'll keep it a bit longer.
730d/Z4C
