      04-29-2024, 05:46 PM   #1
Gr8ZongB58
Your Average B58'er
Gr8ZongB58's Avatar
452
Drives: 19' X3 M40i
Paragon P3 Brake Pads
Received partial delivery of my new P3 pads and rotors.
Let's play a game of "can you spot it" and see if someone can spot a difference in these 4 pads? 2 are still in the wrapper and the other 2 are loose. Good luck! 😁
2019 X3 M40i - MHD STG2 HPFP E40ish | MHD FlexFuel Kit | TU HPFP | xHP stg 3 | VRSF catless downpipe | MST intake | BMS occ | Verus turbo heat shield | P3 V3 gauge w/ P3 ESVA | FTP Charge Pipe | RossRacing PCV v1 VTA | MSS Springs | RES Exhaust w/o valves | Vossen HF-5 21x9.5/10.5 265/295 PS4S | Yellow DRLs | Paragon Rotors w/P3 pads | GTS Tail Lights |
      04-29-2024, 06:44 PM   #2
Burr001
Burr001's Avatar
Philippines
3730
Drives: 2022 X3 M40i
2022 BMW x3 m40i  [10.00]
It's fine...only one inboard pad on drivers front uses 1 sensor and one sensor for inboard pad on passenger rear.
      04-29-2024, 06:56 PM   #3
Gr8ZongB58
Your Average B58'er
Gr8ZongB58's Avatar
452
Drives: 19' X3 M40i
Yeah I understand that part.
What concerns me is the notch area where the pad is looking brittle. Seems like they manufactured the backing plate in the wrong orientation.
After the pad wears down, that part of the pad may be susceptible to further damage due to uneven distribution of pressure? What do you think?
      04-29-2024, 09:09 PM   #4
Burr001
Burr001's Avatar
Philippines
3730
TBH. if you get that low on the friction material to hit the backing plate.... lol time to change pads or if you mean that notch long line area of the pad wearing faster than the rest of the pad face I wouldn't be concerned as the main middle part of the 2 seperated sections of the pad is the larger contact face to create the friction needed to stop.
Also this pad compound is aggressive but durable from what I understand, lol the wear with the paragon grooved rotors will always cut an even face on the pad under hard braking..it shouldn't be "brittle" where chuncks will come off.
Or I am talking out of my ass and not sure I understand what your asking,.....lol
      04-29-2024, 09:26 PM   #5
Gr8ZongB58
Your Average B58'er
Gr8ZongB58's Avatar
452
Drives: 19' X3 M40i
TBH. if you get that low on the friction material to hit the backing plate.... lol time to change pads or if you mean that notch area of the pad wearing faster than the rest of the pad face I wouldn't be concerned as the main middle part of the pad is the larger contact face to create the friction needed to stop.
Haha I would never run it down THAT low!
More so the possibility that the pad bridging over the notch area would become a weak point under heat, vibration, pressure.
Regardless of it all, I payed for it and currently in email contact to get a correctly made product replacement. Don't really feel like being a guinea pig for bad QA, especially on a piece that my life could depend on lol
Now we'll see if their customer service can exceed their product reputation. I have received only 1 email reply to the situation so far acknowledging that it is pressed on the wrong side of the backing plate.
      04-29-2024, 09:58 PM   #6
Burr001
Burr001's Avatar
Philippines
3730
LMAO...I didn't notice that, I'm blind.
      04-30-2024, 03:47 AM   #7
Gr8ZongB58
Your Average B58'er
Gr8ZongB58's Avatar
452
Drives: 19' X3 M40i
Hot damn!...here I am thinking were talking about the same issue and maybe I'm just overreacting 🤣
      04-30-2024, 08:20 PM   #8
Burr001
Burr001's Avatar
Philippines
3730
FYI rotors are the same with GR Supra.
      05-23-2024, 06:57 PM   #9
Gr8ZongB58
Your Average B58'er
Gr8ZongB58's Avatar
452
Drives: 19' X3 M40i
Here is an update on the new paragon 2-piece rotors and paragon p3 semi-metallic pads:
Roughly 200 miles into the new rotors and pads, I will have to say that the p3 pads are starting to perform well over stock. Initial bite has increased. Brake fade on the few apex corners i've experienced them on while coming from a 65-70 mph to nearly 10-20mph turn going slightly downhill is gone. No squeaks or odd noises with exception of the last few inches of fully stopping. Have not tried them in the rain yet so more to come.
They do rust when in contact with water(i washed my car) on parts that the pads don't touch. As much as it bothers me, braking performance wins here in my opinion.
To save someone else the headache I went through if you decide to go this route, here are the correct parts for pads and rotors:
*The rotors does say "Supra" on them but hey, it's pretty much a bmw anyways. Same dimensions all around*
Front Rotor
Rear Rotor
Front Pads
Rear Pads Yes, these are G80 pads according to the webisite but they are the correct dimensions as well!
Burr0013729.50
jrveron317.50
      05-24-2024, 11:07 AM   #10
jrveron
jrveron's Avatar
318
Drives: 2023 X3 m40i
Thanks Gr8ZongB58 !
BTW, Burr001, I wanted to ask you what you think about the Paragon rotors after a while of use. Less brake fading?
TIA.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      05-24-2024, 01:32 PM   #11
Burr001
Burr001's Avatar
Philippines
3730
Originally Posted by jrveron View Post
Thanks Gr8ZongB58 !
TIA.
So driving daily..it's been good..driving hard and taking mid braking turns with ebc red pads has been a improvement over stock. Great bite less dust and though I installed ss lines, the brakes are touchy but I'm getting a ton of good pedal feedback.
I haven't gone to the track yet, but with a more aggressive pad I will see how well the rotors will take it. So far so good, my money well spent.
      05-24-2024, 02:40 PM   #12
Gr8ZongB58
Your Average B58'er
Gr8ZongB58's Avatar
452
Drives: 19' X3 M40i
Guess what, after a few more email exchanges with Paragon, they said their future rotors will be Geomet coated! Makes me mad staring at my rotor rings of rust knowing that I could've waited a little longer haha 😤
jrveron If you decide on these, I would highly recommend the goodrich ss brake lines and a brake fluid flush(I used ATE type 200), not sure what fluid burr is using but doing this to get the maximum difference in feel and performance.
jrveron317.50
      05-24-2024, 02:55 PM   #13
Burr001
Burr001's Avatar
Philippines
3730
I also used ate..lol when you need to get replacement rings...they should be coated by then.
      07-23-2024, 03:47 PM   #14
Burr001
Burr001's Avatar
Philippines
3730
So update on EBC red pads....its been great not washing the wheels every other day almost a week and half, great ceramic option. But from 140 to 40 I overheated the pads and glazed the shit out of them. Had to wait till everything cooled down to get pedal feel back, they were smoking and I may have created a few hot spots on the rotor...lol. Everyday driving they out performed OEM pads, and felt great when spirted driving, but under heavy repeated braking on twisty roads it decided no ty and left the chat.
BTW the rotors are still in great shape after all the abuse since install.
I am torn between isweep 2000, 2500 or just going EBC semi track yellow upfront. We have a group trip later this year to tail of the dragon and at over 300 turns and me following a few G80/G82's, I do not want to be that guy.
Gr8ZongB58 how are you liking the p3 pads?
      07-23-2024, 05:24 PM   #15
Gr8ZongB58
Your Average B58'er
Gr8ZongB58's Avatar
452
Drives: 19' X3 M40i
That is unfortunate to hear, glad you made it out safely. Probably the one reason I didn't go with ceramic. Less brake dust is nice and all until you can't stop LOL!
I personally had an annoying experience with the P3 pads. Followed the break in procedure and everything turned out fine until about 2 weeks after. I took the trophy for the loudest squealing brakes in my town. Re-did the brake in procedure but it did not help. Greased all parts also did not help, until one day when I was washing my car and getting ready to sand my pads, I applied iron-x to my wheels and it happen to also get on my rotors and every other brake part. Pressure washed it all off and went for a drive...squealing gone and been gone for over 2 weeks now. Coincidence? Who knows. May have just been broken in finally(after 1k miles) or pads may have hard material that needed to wear off. Just to note, the pad manufacturer are Winmax Japan but the shipment came from an address in China? ��
Performance-wise, these pads are an improvement over stock pads and If i were to give it a number of increase, I would say about 50% better than stock. The pads don't bite well at initial drive off until it's warmed up(1-2 moderate stop sign stops out of my neighborhood). Once they are warm, they work confidently. I've only tested them from about 80mph to 10mph hard stops and they still perform confidently afterwards. The pads seems to reach peak stopping power at high temps and still have no issues with brake fade or pedal feel...yet. I did not measure temperature of the rotors but I can feel intense heat radiating off the rotors outside my wheels. Wheel dust is what you would expect..shitty. Overall, after the squeals were gone, I like them and would buy them again. I would like to try out ebc yellows and/or hawks in the future just to get a better comparison. So if you do get the yellows, please update!
TL;DR: Initially struggled with loud brake squealing from P3 pads despite proper break-in, but accidentally applying iron-x to my wheels and rotors seemed to solve the issue. Performance-wise, they're about 50% better than stock pads, though they need warming up for optimal initial bite. They perform well under hard stops from high speeds with no noticeable brake fade. They produce a lot of wheel dust but overall, I'm satisfied after the initial squealing stopped and would consider buying them again, but I'm curious about trying EBC yellows or Hawks next time for comparison.
Burr0013729.50
      07-23-2024, 05:43 PM   #16
jrveron
jrveron's Avatar
318
I highly recommend EBC yellowstuff. I had them on my previous F48 (ecu tuned, lowered, slotted rotors, etc.), and they perform very well under heavy driving, including many turns and ups and downs (mountain road style).
Of course, the G01 is a different animal, but they will be my number 1 option when my pads need replacement.
Burr0013729.50
      07-23-2024, 07:14 PM   #17
Burr001
Burr001's Avatar
Philippines
3730
Well with red or any ceramic its not meant for really hard driving. An organic pad is nice but a semi metallic or any other high heat operating pad will be for me now on. All I can say that these rotors have exceeded my expectation for those who tend to push the limits more often.
The P3 sounds like the same compound of EBC yellows or Isweep 2500. I can't find anyone who carry isweep 2500 in stock, so Yellow it is when I take the trip and I will be reinstalling my ebc green pads as the daily. The green had no issues and the dust levels seem to be on par of what Isweep 2000 are.
BTW i also ordered the shims from Paragon...
      07-24-2024, 06:17 AM   #18
Gr8ZongB58
Your Average B58'er
Gr8ZongB58's Avatar
452
Drives: 19' X3 M40i
I tried some girodisc shims for my rears, they "would" fit if it wasn't for the little nipples on the P3 backing plate!
