XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum Temperature X3 35i
      07-10-2018, 02:27 PM   #1
RL325xi
Drives: 2006 e91
Temperature X3 35i
Is my 2012 X3 35i running too cold?
The temperature gauge can only reach to 1/4 mark after reaching normal operating temperature( 30 mins driving)
All my other BMW that I had (e30, e46, e39, e91) they all reached half mark after 5-10 mins drive.
and the X3 took a while(30min) to reach to the 1/4 mark
Also in the first few mins of driving, the transmission shift a bit rare.(little hard to drive smoothly, the shift point is very different)
Something I should look into it or it is normal?
BTW, it only has 44k miles.
Thanks in advance
      07-11-2018, 11:13 AM   #2
Cpt.K
Drives: 135i
Once warmed up, ours sits a tick below half way point on the temp gauge. Gets there within 5min (read it's hot as hell in California). I'm betting on a thermostat that's stuck open in your car.
As for less than smooth shifting on a cold transmission; sound about right. Plenty of threads on here about people flushing transmission/ diffs and it sounds like it makes the whole operation smoother, however it's 70-80k maintenance item. So at 45k it might be a bit too soon for it.
I'd look into the engine temp issue first and see if that also solves the transmission. Good luck!
      07-11-2018, 08:03 PM   #3
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
^^^ Agreed w/ all the above.
I too see just under the mid point of the gauge, how long it takes to get there depends ont he weather but it's certainly never a half hour or more.
      07-12-2018, 11:42 AM   #4
malicem3
Drives: N55 X3
Our operates at just a bit below the middle. If your car isn't getting there after 20 minutes of driving in >60* weather, I'd wonder if you're having some thermostat issues.
      07-12-2018, 11:52 AM   #5
E90705
E90705's Avatar
Drives: E90/F25 M-sport
Should linger around 240F (Oil temp). Does your F25 have an engine coolant gauge?
      07-12-2018, 11:54 AM   #6
Opulence
Drives: F25 X3 35i MSport
My 35i was experiencing the same issue, car eventually threw a CEL for the thermostat which I replaced.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
