08-22-2019, 09:01 PM | #1 |
Rep 280
I've recently flashed bootmod3 stage 2 after installing a VRSF high flow downpipe. I also have an ECS Tuning charge pipe on order, but having difficulty finding a compatible intercooler for the B58. Can anyone point me in the right direction? Thanks in advance-
08-23-2019, 09:08 AM | #3 |
Rep 280
You might be correct, but I'm honestly not sure. I'm simply going by bootmod3's requirements for stage 2 AGG tune which says that in addition to high flow downpipe, one must have upgraded charge pipe and then intercooler. Would obviously save me some money if indeed I don't need to upgrade the intercooler.
08-23-2019, 10:20 AM | #4 |
Rep 1,959
Let us know what you learn!
thekronoschef182.50 |
08-23-2019, 12:40 PM | #6 |
Rep 18,721
Your car doesn't use intercooler anymore.
It is water to air intercooler type. There are some aftermarket for S55, N63tu, and S63tu motor, but I don't think there will be any for the B58 since it is integrated with the intake plenum assembly.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
08-23-2019, 12:43 PM | #7 |
Rep 280
Thanks for the teach!
r33_RGSport12978.00 |
08-23-2019, 05:26 PM | #8 |
Rep 312
Drives: 2019 x3 M40i
Ah, but as with all A/W intercoolers, you do still have the heat exchanger for the water system that can be upgraded to bring temps down in the water which in turn reduces heat from the intake....
08-23-2019, 05:36 PM | #9 |
Rep 280
I did see a listing for a heat exchanger when I was searching for the IC.
08-23-2019, 07:05 PM | #10 |
Rep 1,219
You can upgrade the stock heat exchanger but your gains won’t be crazy. Stock is pretty efficient as is... and yes it is water to air.
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
04-17-2024, 11:55 AM | #12 |
Rep 2
I know this thread is very old, but obviously now there are many after market B58 intake manifolds/intercoolers. I just ordered this one:
https://www.urotuning.com/products/w...41561197281473 The benefits of this product are many: - Significantly improved cooling performance with up to 20° lower intake air temperatures. - Maximum relief of the turbocharger with 35% less backpressure - More power and torque for your engine - 100% pressure resistance for optimal safety - Plug and play without modifications - Pre-prepared intake manifold injection (Fuel Rail optionally available here ) - Three 1/8 NPT ports for additional parameter measurement - Six prepared NOS or WMI ports (for example 90° NOS Nozzles 1/16 NPT here ) - Suitable for all power levels - Up to 4-year warranty for peace of mind Last edited by rdimaggio; 04-17-2024 at 12:49 PM.. |
04-17-2024, 12:33 PM | #14 |
DINAN SELLER
176
Rep 550
NOT an option I'm afraid
2024 X3M COMP, 2019 X3 M40i DINAN, 2015 335xi DINAN stage 4, 2014 BMW i8, 2010 M5 V10 DINAN S2
04-17-2024, 01:40 PM | #16 | |
DINAN SELLER
176
Rep 550
this doesn't apply to the G01 Im afraid..
04-17-2024, 01:42 PM | #17 |
Rep 115
5LEEPR_G01458.50 |
04-17-2024, 06:42 PM | #18 |
BM3 Tuner
298
Rep 275
All b58 manifolds will fit the g01s to my knowledge we have a much larger engine bay. Just make sure you buy the right generation one for your car
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, VTT PCV and Oil cap.
Paul Johnson Tunes Shop/Development Car |
5LEEPR_G01458.50 |
