08-26-2024, 12:26 PM | #1 |
Rep 2
Staggered Wheel Setup - Need Help
BACKGROUND: I purchased a 2017 BMW X3 xdrive35i from someone and it came with a staggered setup. I ended up having to replace the transfer case and now about half a year later it feels like I may need to swap it out again. The dealership believes it is because the wheel size is 20" which is not a wheel size option for that model/year.
QUESTION: Could someone provide me with the correct tires to run with the wheels/rims I currently have. I have attached the wheel/rim brand & specs. I use these rims for summer driving, so summer or all season tires would be ideal. Dealer said rear tires need to be replaced as they are 3/32 tread remaining which is on the threshold of causing TC damage...I would like to do all 4 tires at the same time. OEM SPECS: OE Wheels: 8Jx18 ET43 / Bolt Pattern: 5x120 / CB: 72.6 OE Tires: 245/50R18 CURRENT STAGGERED WHEELS & TIRE SPECS: Front Wheels: 9.5Jx20 ET30 / Bolt Pattern: 5x120 / CB: 74.1 Front Tires: 245/45R20 Rear Wheels: 10.5Jx20 ET35 / Bolt Pattern: 5x120 / CB: 66.6 Rear Tires: 275/40R20 CURRENT WHEEL INFO (WANT TO KEEP): Brand: Superspeed Flowform RF07 Thank you!! Last edited by VTBMW802; 08-26-2024 at 12:36 PM.. Reason: CB for rear wheels was off in original post |
08-26-2024, 02:32 PM | #2 |
Rep 322
Drives: E46 M3 & LCI X3 35i M Sport
My 2016 M sport came stock from the factory with staggered 20" wheels so... I think those are 8.5 from and 10 rear.
My advice would be to run stock wheels on xdrive BMW's. |
08-26-2024, 03:27 PM | #3 |
Rep 2
I just had assumed that as long as the driving circumference from front to back wheels was under 1%, then it shouldn't affect the TC. It's too bad the TC tolerances are so small, as the factory rims make the car look a little "soccer mom-ish." I am getting a 2025 M3 Comp xdrive and the stock rims I chose are the forged & black 826M's, so I feel like those will be fine. I'll most likely just throw the M-Sport stock rims (non-staggered) back on the X3 and just run it for the winter. Still figured it was worth a shot for finding a tire size that would work on those rims for the next handful of months while I wait for the allocation and build of the M3.
