04-19-2019, 10:26 PM | #1 |
Rep 50
Bumpyyyyyy- M40
I'm not sure what to do and whether its the car or the fact I didn't get the car with adaptive. I test drove the m40 about 2 times prior to getting it and never felt this. It is like the suspension is soooo stiff that if at slow speeds there are bumps in the road it is jarring. I'm 1k miles in. My 2016 328 msport was smoother over the bumps than this. Any advice would be appreciated. That is literally my only gripe about the car. The handling, acceleration, and tech are all top notch.
thanks in advance. |
04-19-2019, 10:32 PM | #2 | |
Rep 8,030
Drives: 2024 X5 M60i
Personally, I have the 21's with RFTs and the standard suspension and have no complaints at all about the ride quality, bumps, etc.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
MechX3M40i1006.00 |
04-19-2019, 10:39 PM | #4 | |
Rep 8,030
If still not happy with the ride the next step would probably be to swap to non-RFTs but that is a bit costly of an option with only 1k on the current setup.
04-19-2019, 10:57 PM | #5 | |
Rep 264
Redid the wheel and tire setting within the iDrive, took some air out of the tires to match the new recommended pressure, and was much better.
Current: 2019 X3 M40i and 2018 330i
Previously: 2016 M235i Convertible and 2016 X4 28i and many non-BMWs |
JustChris17487.50 |
04-20-2019, 03:30 AM | #7 |
Stumpy
24
Rep 51
Possibly not the case 'gregtennis91' ....but sometimes the dealership on pdi forget to remove the transport packaging form the suspension...just another thing to check if no improvement from the above suggestions......just a thought
04-20-2019, 07:16 AM | #9 |
Rep 1,727
It's not surprising about the being bumpy in NYC In any event, there are quite a few NYC forum members here and some of them even got the 21" wheels but as far as I know they had not complained about excessively rough ride.
Besides checking tire pressure as many other had suggested, maybe it's just the characteristics of the X3M40i. It's a SUV and is much heavier than your 328. It also got bigger wheels and possibly stiffer suspension too. And yeah, run flats do not help either... |
04-20-2019, 10:51 AM | #10 |
Rep 50
Thanks. I checked the tire pressure and the shipping blocks.
Looks like no shipping blocks, but will double check when i get service done since its not that easy to tell in the rear. tire pressure is 3PSI higher than recommended on the front of the car. Idrive settings all good. |
04-20-2019, 10:59 AM | #11 |
Rep 343
Drives: '19 750i xDrive
Just switched from a 20" winter non-RFT square setup to my 21" RFT staggered setup and was caught off guard by how different the ride feels. That being said, I actually prefer the ride with the 21's despite the increased harshness.
If you want a super comfortable ride, get the 30i or a X5 with the air suspension. |
04-20-2019, 05:39 PM | #12 | |
Rep 2,532
Although tire pressure will definitely change the ride, I always modify the pressures when going on higher speed Interstate travels (from the rec PSI to 36/40 and even 38/42 - see https://x3.xbimmers.com/forums/showthread.php?t=1440682 ) and haven't noticed the 'jarring' you suggest. Understandably a harder tire is going to 'feel' the bumps more, but shouldn't be jarring. Would respectfully suggest it may be worth a scheduled Svc visit with someone you trust at your Dealer and let them ride with you. And even better if they have another one on the lot you can check out at the same time. Wouldn't matter if the comparison vehicle has the 20" or 21" as they should, if anything, produce a more noticeable issue you describe so shouldn't slant the evaluation the other way. |
04-20-2019, 09:15 PM | #13 |
Rep 288
Bumpyyyyyy- M40
My m40i is in the shop for a recall and warranty work for a bubble in my right front tire. The loaner they gave me is a 2018 530i on 18" (245/45R18) run flat tires no adaptive suspension. The ride is night and day compared to my m40i on 21s with Alenzas and Adaptive. I honestly cant feel a difference when im driving my car on adaptive vs not. Even driving the 530 in sport is a lot more comfortable than the m40. If I could do it all over again I would get the smaller wheel/tires.
04-21-2019, 02:16 PM | #15 | |
Rep 547
Previous Bimmers: F25 X3 20d LCI xLine, F30 320d Luxury
04-21-2019, 08:28 PM | #16 | |
Rep 120
04-21-2019, 09:03 PM | #17 |
Rep 50
Well went to UDE today and tried the x4 3.0, x5 4.0, 330, z4, and x3m40.
My car was the bumpiest and I had two other people, wife included try the car out. I mean it’s not as smooth as an m240 so something is up. Tire pressure has been addressed. Calling for service tomorrow. Tried to look for shipping blocks but don’t see anything. |
Crassus229.00 |
04-22-2019, 09:47 AM | #18 | |
Rep 343
I actually prefer the slightly more uncomfortable ride of the 21's. Taking turns I feel like I'm in my M4 ZCP again! (exaggerating slightly) |
IM_ALL_IN57.00 |
04-22-2019, 04:39 PM | #19 |
Rep 111
Drives: BMW X3 M40i, Carbon Black
I’m so glad the OP asked this question and for the great replays. I’ve never been thrilled with how the car reacts to bumps and potholes but always chalked it up to the RFTs. After reading the replies though I checked my tire settings in iDrive and discovered that my 20” tires were listed as “other” and were set to speeds over 100mph. After adjusting to the correct tire size and recalibrating the tires there is a very noticeable difference. Very nice!
chicagofan0019143.00 |
04-23-2019, 04:16 AM | #20 | |
Rep 35
04-23-2019, 02:18 PM | #21 |
Rep 111
04-23-2019, 03:04 PM | #22 | |
Rep 153
