10-22-2020, 03:05 PM | #1 |
Rep 862
What engine changes were made on the s58 for the m3?
It seems like output is a little different on the new m3 versus the x3m. Torque is up like 35. Were there any internal changes? Or is this just down to the tune?
21 x3mC
Previous: 08 e90 M3, 02 e46 M3,2011 335is, 2016 AYM M3 Last edited by sittingmongoose; 10-22-2020 at 03:16 PM.. Reason: Had wrong info in here |
10-22-2020, 03:08 PM | #2 |
Rep 4,607
10-22-2020, 03:21 PM | #4 |
Rep 4,607
i was always wondering, from a technical standpoint, can you really increase the peak torque number without changing the hp? or is it BMW just playing mental games with us?
10-22-2020, 05:52 PM | #5 |
Rep 3,783
Tuning changes and major sandbagging, which BMW loves to do with M3 power numbers.
sittingmongoose622.00 |
10-22-2020, 05:54 PM | #6 |
Rep 862
That's what I was thinking. I guess if they changed a bunch of stuff it wouldn't be the s58 huh?
21 x3mC
Previous: 08 e90 M3, 02 e46 M3,2011 335is, 2016 AYM M3 |
10-22-2020, 06:11 PM | #7 |
Rep 2,955
The intake arrangement is better for starters. They had to make some compromises to the intake to fit in the X3 which is why we have that big monstrocity on top of the engine. The intake system on the M3/M4 is more traditional with the air filters near the front of the car. Also I'm sure that they have made some tweaks to the tuning to more adequately match that chassis.
10-23-2020, 06:34 AM | #8 |
Rep 4,977
Lots of info below. Between compression ratio and turbo set up, sounds like it will be similar to the F97 with a bit more torque on paper.
G80 Technology Improvements? https://g20.bimmerpost.com/forums/sh....php?t=1761848
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
10-23-2020, 08:26 AM | #9 |
Rep 86
Yes, especially on a turbo motor. A bit more boost on the low end and you'll see an increase in peak torque but no increase in peak hp.
10-23-2020, 12:26 PM | #10 |
Rep 2,219
I find it interesting the 0 - 60 times appear the same (or very similar) from the specs I've seen between the M3/4 and X3M/X4M.
I would have thought a lighter vehicle would make more of a difference. |
10-23-2020, 12:57 PM | #11 |
Rep 318
BMW is sandbagging the numbers as per usual I'm sure. Expect to see 3.3-3.5 ish?!
10-23-2020, 02:37 PM | #12 |
Rep 2,219
hellcat2m4218.00 |
10-23-2020, 05:08 PM | #13 | |
Rep 2,067
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB |
10-25-2020, 01:15 PM | #14 |
Rider and driver
141
Rep 506
HP=Torque (lbs.)*RPM / 5252, correct? Also, that would account for the torque and HP being the same number at 5252 RPM (where you usually see the HP vs. Torque lines on a chart cross-over).
If the above is true, then 35lb increase in torque is going to bump the HP up. Speed, on the other hand, can still be limited as well as acceleration. Marketing vs. engineering.
2021 X3 MC
I work for Keyser Söze |
AlexFL7833.00 F82Tazmanian137.50 |
