07-03-2020, 05:33 AM | #1 |
Rep 364
Bootmod3 S58 OTS map update - Version 2.4 is out!
After gathering tons of datalogging from users across the world, even more improvements were found, applied and tested
These findings resulted in a smoother boost curve at high engine speed allowing for a more clean ignition timing curve thus more efficient power, especially on stage 1 cars with stock hardware. Furthermore, burble is now working better for cars with particulate filter (OPF). Version 2.4, July 3 2020: - Boost taper at high RPM fixed - Unstable wgdc at high RPM fixed - Burble activation for OPF cars Picture for attention :slightly_smiling_face: |
07-03-2020, 08:25 AM | #2 | |
Rep 202
07-03-2020, 08:55 AM | #3 |
Rep 1,406
Drives: 2020 SO - M2C
Will update shortly!
07-03-2020, 09:43 AM | #4 |
Rep 155
Nice! Can't wait to try!
2020 Dark Graphite Metallic x3M Competition
Mods: BM3Tuning x Paul Johnson Tunes Custom Full E85 stage1+, MSS Adjustable Springs, AutoTeknic Matte Black Paddle Shifters, RG Front paint-matched reflectors, H&R 15mm F/R Spacers. IG: _x3M_Competition |
07-05-2020, 09:16 AM | #7 |
Rep 155
Does anyone know if we can flash with the mobile app with cellular signal or does it need to be connected to WiFi?
07-05-2020, 09:31 AM | #8 |
Rep 202
07-05-2020, 09:40 AM | #9 |
Rep 155
Only reason is would flash with cell, is to run E30 after I fill up at a gas station. I daily with 91.
07-05-2020, 10:22 AM | #10 | |
Rep 202
07-05-2020, 11:04 AM | #11 | |
Cowboy Astronaut Millionaire
2254
Rep 2,867
07-05-2020, 11:07 AM | #12 |
Rep 4,607
07-05-2020, 11:12 AM | #13 | ||
Rep 155
07-05-2020, 11:16 AM | #14 | ||
Rep 202
07-05-2020, 11:16 AM | #15 |
2254
Rep 2,867
Im using the BM3 agent. You need to be connected to your car at home. And when you select flash. It gives you the option to download instead of flash. Download at home assuming your car is close enough to your internet. And then when youre at the gas station reconnect and flash. Takes 1 min.
07-05-2020, 11:49 AM | #16 | |||
Rep 155
07-05-2020, 11:53 AM | #17 | ||||
Rep 202
07-05-2020, 11:28 PM | #18 |
IG @bmwF9xG80
3810
Rep 7,594
Going to flash Update now can't wait to see what it does
Already super fast on Dragy
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
07-06-2020, 01:40 AM | #19 |
Rep 155
Did you notice any difference between the updates?
07-06-2020, 09:35 AM | #20 |
Rep 70
So if you been a lot in the high RPMs, what could/would have happened before that's now resolved? I mean could the engine have gone lean before the 2.4 update?
07-06-2020, 01:25 PM | #21 | |
407
Rep 676
I 100% agree with #2. I thought I might have hit a bug where all the settings for the burbles and such had broke but guess it's not the case :/ |
