      05-25-2024, 09:23 AM   #1
brad65ford
Drives: 2022 M3
2024 turning off fake sound in cabin
Hi guys, Done this prior on older M cars but with a Vgate dongle and bimmercode app. But doing some research it seems a little harder on these newer face lift x3m's. Can anyone point to me in the right direction to turn this off?
      05-25-2024, 01:54 PM   #2
s58_oreO
s58_oreO's Avatar
135
Drives: 2023 BGM X3MC
In bimmercode, go to the RAM module, hit expert mode then go to 3001 AUDIO UND ASD.
Set all ASD options to disable
ASD_INSIDE
ASD_OUTSIDE
ASD_PLUS_STARTUP
ASD_PLUS_BURBLING
ASD_PLUS_DOWNSHIFT
ASD_PLUS_EFFECTS
ASD_PLUS_EZA_UPSHIFT
Saw this in another thread on mobile and screenshotted, cant find the thread for the life of me now so just copied text from screenshot and sent here. Good luck man, did it on mine and worked fine.
pdotc8442.00
      05-25-2024, 01:59 PM   #3
Professor MSP
Professor MSP's Avatar
Drives: 2015 (981) Porsche Boxster GTS
I have an iPhone and used the Vgate dongle and Bimmercode app to code off Active Sound Design in my wife's 2024 F97. You want to code off ASD to eliminate the exhsust sounds pumped through the speakers. I found the first post in this thread to be the ticket: https://x3.xbimmers.com/forums/showthread.php?t=1987606. It does not require that you go in Expert Mode.
Good luck.
Modification \n (1603)\ the making of a limited change in something; also : the result of such a change
      05-25-2024, 02:13 PM   #4
brad65ford
Drives: 2022 M3
Good luck.
Ok did just this and I see it but saying I need to update and connect to the internet. Trying to find of if that is the case or I need to purchase new service ?
      05-25-2024, 02:36 PM   #5
Th3Walrus
Drives: 2020 X3MC Alpine White/Sahkir
Yes, that is the case. You need to update inside the app so it has the latest codes/options.
      05-25-2024, 02:41 PM   #6
brad65ford
Drives: 2022 M3
Got it. Wow it’s so quiet. But real. Thanks guys!
      05-25-2024, 06:27 PM   #7
brad65ford
Drives: 2022 M3
After driving in more, i noticed the burbles are now gone? Is that apart of the asd delete?
      05-25-2024, 08:57 PM   #8
thestimp
2022 X3mC  [10.00]
2016 BMW M3  [0.00]
They will only be on with the button pushed on your shifter area that looks like an exhaust, and in sport/sport plus coasting/downshifting,
X3MRon4.50
