      06-08-2023, 05:32 PM   #1
pyo
Drives: 2022 X3MC
Broke Stud for Strut Bar
Hey, all. Looking to get some advice here. Was putting everything back after installing the BMS Intake and broke a stud while tightening down the strut bar. I was using a torque wrench at 30 Nm / 22 ft-lbs... FML
Can the stud be removed and a new one inserted? Or, do I need to get a new guide support? I believe this is the 51-61-8-075-318
I assume I should take it easy driving until I get this fixed, even though the bar does not feel loose...
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
      06-09-2023, 07:49 PM   #2
goldfz8
Drives: 08 Bmw 135
you could not fix it...I removed my bar
2022 BMW X3M - 11.604 @117.96
Gone But not forgotten
2008 BMW 135 - 10.9 @ 131
2016 BMW X6
      06-10-2023, 08:20 AM   #3
rmnoonan
Drives: F30 328I (July '12 ED)
Same boat, what was your solution? Thanks!
      06-10-2023, 08:32 AM   #4
Vervish
Drives: 2020 X3M Competition
I think the part you need is actually for sale in the members sale section.
Support mounting brackets - 51618075317 (left) / 51618075318 (right)
      06-10-2023, 08:50 AM   #5
rmnoonan
Thanks for the heads up, doesn't look like that person is parting out.
      06-13-2023, 10:26 AM   #6
pyo
Drives: 2022 X3MC
Spoke with a local shop + BMW dealer and the stud itself is not repairable. I ordered a new support plate (passenger side) and should have it soon. My go to modification technician said should be able to replace without messing with the alignment.
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
      06-13-2023, 10:56 AM   #7
rmnoonan
Yeah I just ordered one too, dealer said only one in country is in Dallas lol. We’re probably fighting for the same part. Will be ordered from Germany if not. I’m gonna try to do it myself….
      06-13-2023, 11:59 AM   #8
pyo
Drives: 2022 X3MC
haha, when did you order yours? I ordered 51-61-8-075-318 (passenger) on Fri morning (6/9).
Good luck, it should be straight forward but I am not going to chance it. This was my 3rd time removing/installing the strut bar (installed Dinan Engine Cover and swapped for CF Strut bar myself) and I snapped the stud...It was the 4th (last) bolt I was torqueing down to finish up BMS Intake install...
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
      06-13-2023, 01:14 PM   #9
Dawgz
2022 M4 Comp Xdrive
1057
Drives: 2022 M4 Comp Xdrive
No need to torque that bolt down that far. Just a little past snug is sufficient.
      06-13-2023, 04:52 PM   #10
spta97
Drives: BMW 2020 X3MC
As this is not the first I have heard of one of these snapping, it appears BMW did not use a strong enough bolt.
The torque spec should be way below the breaking point.
      06-13-2023, 05:35 PM   #11
rmnoonan
Mine is driver side. Yeah I was wrapping up spark plugs and oil change. Doh! Good luck. Let me know when you get yours, I didn’t go through dealer so I’m sure I’ll be waiting longer I’m sure…
      06-13-2023, 06:13 PM   #12
FLX4M
FLX4M's Avatar
78
Drives: BMW X4 M Comp, F30 335i xDrive
Exact same thing happened to me. Tq wrench...SNAP. Brutal. Dealer fixed mine. Was like $400. I chalked it up to a learning moment. I didn't want to leave it as is. My .02
      06-13-2023, 06:18 PM   #13
rmnoonan
My part is shipping now, was like $125 part. Will see how hard to fix myself, expecting to be simple.
      06-14-2023, 07:26 AM   #14
robopp
robopp's Avatar
2026
Drives: 2020 X3MC
So what’s the recommendation for torquing these bolts down? BMW TIS calls for 30NM, which broke the bolt according to the OP
      06-14-2023, 11:32 AM   #15
JB20DGM
Drives: 2020 BMW X3M Competition
I would also like to know...it's a decent sized stud so I'm surprised it would be breaking at only 30nm.
2006 BMW 325i (E90)
2006 Pontiac GTO
      06-16-2023, 06:01 PM   #16
rmnoonan
For those in the future, this is an easy easy fix. The plate doesn’t interact with suspension at all, took me 10m to replace. It’s a $125 part but don’t pay the dealer to fix it, sooo simple.
      06-16-2023, 07:27 PM   #17
spta97
Thanks for the info. I don’t plan to remove mine anytime soon but good to know.
So if a torque wrench will snap it, is it just snug and that’s it? Loctite?
On my gfs Supra (built by BMW, basically a Z4) they have a yellow Loctite which is very strong. I forgot the torque rating but it was pretty high.
      06-16-2023, 07:44 PM   #18
rmnoonan
I just snuggled it down tight, maybe three finger tight? Haha. Just snug then a little bit more. I’ll check the bar later for looseness. I don’t think it. Has to be very tight.
      06-20-2023, 09:22 AM   #19
spta97
Hmmm...a part like this will have a lot of stress on it. I would imagine the torque spec is for a reason. Annoying to say the least.
3 finger tight - I understand that measurement
      06-20-2023, 12:33 PM   #20
pyo
Drives: 2022 X3MC
Replaced mine on Sunday too. Straight forward replacement. I was extra careful tightening everything this time. Finger tight, then 3 finger tight, then torque with 20ft lbs as good measure, and making sure full socket engagement at 90 degrees.
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
      05-24-2024, 03:05 PM   #21
JaCole9
JaCole9's Avatar
Drives: BMW X3M
Just did this to mine after putting in some drop in filters.
Is this the suspension top hat, ie take off wheels and suspension or can you just remove the 3 bolts and slap the new support on?
      05-24-2024, 03:14 PM   #22
pyo
Drives: 2022 X3MC
Just remove 3 bolts and put on the new support. It's separate from the top hat.
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
JaCole935.50
