12-09-2018, 01:58 AM | #2 | |
Head Idiot
251
Rep 551
JoshV14.50 |
12-09-2018, 12:27 PM | #3 |
Rep 139
Thank you - Ceramic tinting is new to me (as is Ceramic coating), I'll have to research. Also in NY, window tint is measured upon inspection each year. I'm not sure what is legal on the front windows.
I'll lookup adapters now as well. |
12-09-2018, 12:48 PM | #4 | |
Rep 1,727
12-09-2018, 01:17 PM | #5 | |
Rep 139
Also, any recommendation on a ipad holder for back seats (for kids)? |
12-09-2018, 01:28 PM | #6 | ||
Rep 1,727
I suspect the wireless charging is only about half as fast as the 2.4A USB ports. But you can experiment with it. I would at least get one and keep it for the back passengers. The OEM BMW charger comes with the car only has 2.1A combined for both ports so that is also slow. |
12-09-2018, 01:41 PM | #7 |
Rep 1,727
IPad holders from BMW. https://www.getbmwparts.com/c-travel-comfort-system-15
There are many cheaper 'universal' iPad holders from Amazon but you have to check them out yourself and see which design is acceptable to you. |
12-09-2018, 02:09 PM | #8 | ||
Head Idiot
251
Rep 551
You can think of ceramic coating as a better form of car wax/acrylic sealant that can last years. It makes the car easier to wash (crud doesn't stick as well), and also helps to prevent damage from things like bird poop/tree sap (you still have to remove these fairly quickly). Quote:
The issue with the BMW wireless charger is that iPhones will treat it as a slow 5W charger. Works, but slow. As others mentioned, there are separate wireless chargers that you can plug into the cigarette lighter ports, but these chargers still charge iPhones slower than a wired connection. Wireless charging is convenient, but slow. If you need fast charging, you need to use a wired connection with a charger like the one above. |
JoshV14.50 |
12-09-2018, 05:41 PM | #9 |
Rep 288
Get one of these...it makes the center console so much more functional.
https://www.ebay.com/itm/Black-Cente...item3b2361ecba |
12-09-2018, 09:18 PM | #11 |
Rep 346
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
armrest organizer is great. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Toll pass holder without strips works great just suction cup. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Flush charger. got 2 of them. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Tablet holder works well and fully adjustable. |
12-09-2018, 09:52 PM | #12 | |
Retired Curmudgeon
2986
Rep 4,054
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
12-10-2018, 06:57 PM | #13 |
Rep 59
I went ahead and got two of these - one for the front and one for the back. They dont have any LED lights that stay on so zero drain on the battery.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I got the BMW all season floor mats and the cargo mat. Removed the rear badges except for the "M" and added the "m" above the side vents in the front since my car was after the badging change, Got a US mill works license plate mount for the front and a BMW license plate frame for the back instead of the dealer one. Downloaded bimmer code app and a OBD v=bluetooth adapter to take off the liability warning, the auto start/stop feature and the Dynamic sound for now. Will be getting IND body colored front reflectors. Thats about all my recomendations. Also got a coated socket for the lug nuts and two jack pads. |
JoshV14.50 |
12-11-2018, 11:52 AM | #16 | |
Rep 139
12-11-2018, 12:02 PM | #17 |
Rep 50
They are on the way, so not picture yet. I had same ones on F25, and I am pretty sure they will fit also on G01. One link here: https://www.ebay.com/itm/2PCS-Rear-D...2:pf:0&vxp=mtr Just wondering why those are not installed as standard, at least in Finland X3's are more expensive than 5 series, and lacking those tiny pieces....
12-11-2018, 12:12 PM | #18 |
Rep 773
I would skip a car cover. Any trapped dirt underneath the cover or on the paint will cause fine scratching when the two surfaces rub against each other. That is if you really care about this type of thing. I'm a bit obsessive lol.
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue 2011 328i xdrive Black Sapphire Metallic |
12-11-2018, 09:00 PM | #19 |
Head Idiot
251
Rep 551
This. A cover just helps to add microscratches and swirlies to the paint.
12-11-2018, 11:38 PM | #20 |
Rep 1,599
Car Cover Experience
I've used covers for almost 50 years. They are great for keeping your car clean in the garage and can be useful out doors to reduce sun damage. I use Covercraft brand custom fitted covers. Currently, I prefer the WeatherShield HP fabric. These covers aren't cheap, but they do fit well, are very durable, and it's my experience that Covercraft backs their products. The keys to not damaging your car's paint are to only put the cover on a clean car, develop a technique for installing the cover and removing it that you do the same every time which allows you to not rub the cover across the paint and to only touch the car with the underside (clean side) of the cover. I start at the driver's side mirror hooking the mirror pocket over the mirror, then roll the cover across the car to the passenger side hooking the passenger side mirror pocket over the mirror. I then roll/unfold the cover over the roof and on down over the back of the car. After that's complete, I roll/unfold the front portion of the cover over the hood. You then want to check that the cover is hanging down properly all around the car. If you are going to use the cover outside, you want to be sure the elastic front and rear are under the car so that the cover is well attached to the car. You also want to use a rope to tie the cover down using the supplied grommets in approximately the middle of the cover. When using the cover outside, you want to know what the weather will be that day. You want to park so that your car is in line with the wind that day, and you probably don't want to use it if it's going to rain. That said, I can't tell you how many times I've ran out to the parking lot at work to pull a cover off because of an unexpected weather change or I'd just decided to risk it that day. A wet cover is really a pain to deal with. As I recall the Weathershield HP material is water proof, but the cover is not seam sealed. Plus the material breathes; so, if you can leave the cover on in the rain and let everything dry with the cover still on, all will be well.
Covers are a bit of a pain, but for that effort you can go much longer between washes and surface protection (wax, sealant, rubber, plastic dressings) applications and cut the sun exposure your car endures way down. Our 2001 Accord at 110K miles is a great example of what long term use of a cover can achieve. The car has nearly perfect factory original gold metallic paint, a nearly new looking cloth interior, and unoxidized original headlight covers. The size of the X3 makes getting a cover on and off and just dealing with the size of the cover a difficult proposition. My wife and I are retired , and don't have the issue of daily sun exposure for any of our cars, and I don't expect the X3 to sit in the garage much; so, for me, it's unlikely that I'll buy a cover for my new X3. The 2010 M3 pictured as my signature that I'd owned from new has sadly just been sold. I have an X3 M40i on order. I'll update the photos as I figure out how to use the site again. It's been several years since I've been here (on the M3 forum) regularly.
Last edited by calintexas; 12-14-2018 at 05:13 PM.. Reason: Added photos as example of my statements |
12-12-2018, 08:39 AM | #21 |
Rep 1,063
Since those of us in the United States aren't given the option of the automatic fragrance system (Ambient Air) in our X3s, I have found that I really like the manual diffuser that can be placed over the vents. The diffuser takes fragrance sticks that can be purchased in 6 different scents. I personally like "Sparkling Raindrops" and "Woods" scents, but preferences vary.
https://www.bmwpartswholesale.com/oe...AaAullEALw_wcB
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
12-12-2018, 08:48 AM | #22 | |
Rep 1,727
