      10-23-2019, 04:43 PM   #1
mgcorreia
Drives: bmw x3 2005
X3 p0171 p0174 vacuum leak help
Hello all, this is my first post. I have a BWM x3 2005 3.0L with about 180k miles. Writing in because i've been battling these p0171 p0174 codes on my car. I've replaced a lot of parts so far in perusing this:
*new valve cover gasket
*spark plugs
*coils
*cleaned the MAF
*New air filter
*New throttle body boot
*New ccv
*new disa
This certainly fixed my misfire, its running much better but still the p0171 code comes on every couple of days, sometimes paired with a p0174
Some observations: that little MAF sensor is black even after cleaning it, shouldn't it be amber colored? Could it be the 02 sensors? The baffle on the exhaust rattles is that related? My fuel economy used to average around 18mpg, now its around 17mpg. Open to any suggestions on what to try next, this is an otherwise awesome reliable car. thanks!
      10-24-2019, 08:37 AM   #2
X3MS
MARANATHA!
X3MS's Avatar
Drives: 2007 X3 M-Sport
Those are EGR Valve codes. Your EGR Valve is most likely all gummed up, causing insufficient flow, and needs to be cleaned or replaced.
      10-24-2019, 12:12 PM   #3
mgcorreia
Drives: bmw x3 2005
...oh and a new DISA too, those seals cause leaks.
Thanks x3ms! this is the component that needs cleaning correct? any advice on how to clean it or what to use?
https://www.pelicanparts.com/More_In...=0&SVSVSI=0589
      10-24-2019, 01:47 PM   #4
X3MS
MARANATHA!
X3MS's Avatar
That part looks correct. Which engine are you running... M54?
      10-24-2019, 02:14 PM   #5
mgcorreia
Drives: bmw x3 2005
yup m54
      10-24-2019, 02:18 PM   #6
X3MS
MARANATHA!
X3MS's Avatar
yup m54
Ok, then this will be pretty straight forward.
      10-24-2019, 07:47 PM   #7
mgcorreia
Drives: bmw x3 2005
Oh damn my dyslexia ... the code was p0171 & p0174. So sorry. That could be anything right? I will for sure clean the egr though, it’s never been done.
      07-26-2021, 06:20 AM   #8
hfount
Drives: 2005 BMW X3, 2008 328XI
Hi mgcorreia,
I have the same exact car as you with the same codes.
Were you able to fix this? thank you, Harry
