04-09-2023, 06:57 PM | #1 |
Rep 131
Disable auto start stop or enable the memory function
Have a 23 X3 and unable to get this to work. I have a 21 530 running idrive 7 and that works just fine. Am user bimmercode. I know folks have had difficulties but I want a definitive answer if it can be coded or not?
04-09-2023, 07:14 PM | #3 |
Captain (Retired)
4335
Rep 1,861
Here
04-09-2023, 07:49 PM | #4 |
Rep 131
Thats not the module under which that is on g01. Its the EDC module
https://www.bimmercode.app/cars/g01/ This is not my first rodeo so am simply asking if someone has successfully done it on a 2022 or 2023 X3 and if they can send me step by step method. |
04-09-2023, 07:51 PM | #5 |
Rep 1,486
(ASS) forces me to place the car in Sport Mode (smile)!
Usachampion194.00 838140.00 |
04-09-2023, 08:17 PM | #6 |
How YOU Doin?
1816
Rep 1,636
Drives: 2022 BMW X3 M40i
This is it in my car (2022 M40i). I only set the “function” to not active. No reason that I know of to set the “memory” setting to Active since the former disables it entirely. It will always be inactive.
Rottweiler4334.50 HeatJoey1299.00 |
04-09-2023, 08:27 PM | #7 |
Rep 160
I kinda like having the option for it in an extended highway jam, so I don’t disable it permanently. Remembering last option is great for that!
ContactPatch2458.50 |
04-09-2023, 08:46 PM | #8 |
Rep 131
Thank you i have tried that and trying to yet again. Whats your normal steps? Put the car in diagnostics mode, start bimmercode, go to the EDC module, code the setting, done, disconnect from bimmercode?
04-09-2023, 09:11 PM | #9 |
How YOU Doin?
1816
Rep 1,636
For a pre-LCI car that makes sense. But in the LCI, there is no button to turn it back on. If you disable it through the app, it is permanently disabled, unless you code it back on again. I actually wish I could turn it back on in Eco-Pro mode. But there is no such option for my car.
04-09-2023, 09:12 PM | #10 |
How YOU Doin?
1816
Rep 1,636
Yep. I don’t put it into diagnostic mode, though. The app does that automatically for me. Might be an iDrive 7 or LCI thing. But the other steps are the same.
04-09-2023, 10:29 PM | #12 |
Rep 2,112
As already stated, many ways to do this, eg. if you are already MHD user, then MHD recently added this coding capability as a Disable MSA feature (nit is that ASS LED doesn't come on in pre-LCI showing that it's disabled). Nonetheless good inclusion, since who wants to have this enabled anyway, as mentioned elsewhere, especially if the car is a keeper, and not a throwaway (aka. lease).
ocdx30.00 gofastbmw5100.00 |
04-09-2023, 10:43 PM | #14 |
Rep 2,112
04-10-2023, 10:33 AM | #15 | |
Rep 452
What does “unable to get this to work” mean, in more detail? This is one of the “easy” coding options, on both LCI and pre-LCI, so it would help if you can provide more info about the specific problem you are running into. |
g11hoonigan833.00 ASAP10587.00 |
04-10-2023, 03:40 PM | #18 |
Rep 131
This is the response from bimmercode
Hi, does not work for cars running latest BMW software unfortunately. We are looking into this, but it may be possible that BMW completely disabled this function. -- Kind regards / Schöne Grüße Stephan Gauch -- SG Software GmbH & Co. KG Linsenäcker 18/1, 72379 Hechingen |
04-10-2023, 03:42 PM | #20 |
Rep 8,885
now i am confused... how old is your car?
everyone just did the sw update and everything works for me was there an ecu swap that no longer allows this?
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
04-10-2023, 04:05 PM | #21 |
Rep 8,885
i guess i am going to repeat... i do... unless your car was just built and there was an ECU swap... i dont know whats going on here
04-10-2023, 04:24 PM | #22 | |
Captain (Retired)
4335
Rep 1,861
[QUOTE]
What version is your software? I just upgraded to 11/2022 with no issues but I thought someone posted here on the forum that their new car had 3/2023 I could be mistaken of course |
