      03-21-2019, 04:42 PM   #1
antjones21
antjones21's Avatar
Drives: 2022 BMW X4 M40i
Aftermarket custom wheels got X4 G02
I'm trying to look for some 20" rims for my 2019 X4 xDrive30i. I've read on here that the bolt pattern is 5x112. When I search on some websites they say the bolt pattern is 5x120. Isn't that the pattern for the previous X4? Also when I switch it to the 2018 X3 it shows 5x112, is it true that the X3 (G01) and X4 (G02) have the same pattern?
Just trying to make sure that if I buy from a site that says it doesn't fit but it is 5x112 that it will work.
Thanks
      03-21-2019, 04:52 PM   #2
winecracker
Drives: 2019 X4 M40i
wheelsize.com indicates the 2019 X4 is 5x112 and the 2018 is 5x120. Am pretty sure they are correct, but hopefully someone else will confirm as I too will soon be looking for a 20 inch winter wheel/tire set for my 2019 X4 M40i.
      03-21-2019, 05:26 PM   #3
MrPorter
Drives: 2019 X3 M40i, 2020 X7 M50i
I'm almost positive the wheels are interchangeable with the X3, so it would be 5x112.
If you want a quick answer, maybe call the parts department at a random dealer?
      03-21-2019, 05:36 PM   #4
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
G-series wheels will be 5 x 112.
So 2018 X3 and 2019 X3 are all the same - 5 x 112.
2019 x4 will be 5 x 112 also
      03-21-2019, 05:40 PM   #5
antjones21
antjones21's Avatar
Ok thanks everyone.
