02-23-2019, 04:20 PM | #1 |
Rep 147
Vdm under voltage
Hi guys I have posted previously regarding a chassis error fault that is currently showing on my 2014 X3 30d.
I have had it checked today and below is a list of codes that came up. Specialist cleared the last four codes, but couldn’t clear the vdm undervoltage code. Specialist says further investigation is required to find reason behind vdm undervoltage, anyone have a clue what it could be causing it?? DCT. Description 482881. VDM undervoltage. 482A28. Valve coil - rear left - short circuit terminal 15 / terminal 30. 482A2A. Valve coil - rear left - open circuit. 482A2F. Valve coil - rear right - short circuit, valve. 482A38. Valve coil - rear left - current regulator plausibility error. |
02-27-2019, 10:25 AM | #3 |
Rep 540
Drives: 2016 BMW X3 35i M-Sport
Fuse maybe. Check the plugs on the coils as well. Those are the exact same codes I got when I intentionally unplugged and removed my coils.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others Instagram @TheCoolX3 |
02-28-2019, 03:25 AM | #4 | |
Rep 147
They are changing it free of charge as the short circuit codes cleared and only left the VDM under voltage which he is 100% sure is due to water ingress even though we couldn’t see any signs of water. I too think it’s a dodgy sensor on either one of the rear suspension so will check that when I get a break from working ( long hours ). Thanks for your replies lads |
