08-18-2018, 05:26 PM | #1 |
Rep 1,334
My X3 M40i flashed by Mission Performance
After a few road blocks, which was completely related to the coding I had previously done to my car, Alex got my car tuned to perfection. I’m only on stage 1 and have nothing but a K&N drop-in. But, otherwise, I can report it feels as smooth if not smoother than stock and pulls harder everywhere...especially up top. And with a much better/safer AFR than stock as well.
Alex is patient, courteous, and can write code and programs on the fly to troubleshoot issues. It’s actually pretty amazing to see in realtime and gave me confidence that he is customizing the tunes himself and making sure they run properly with a few logged runs rather than grafting some european/middle eastern off the shelf stuff like other flash guys. I have been on JB+ with a mild 2lb. Additive tick and it was actually fine for me (don’t listen to those who are saying they’ve lost power or have choppy shifts with the JB) but the flash is noticeably better in every single way, obviously. Also, the tune is adaptive to E85...I was told to keep it to about E20 or so to be safe in terms of mixture. The torque is quite addictive on ethanol. Highly Recommended!
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
08-18-2018, 07:29 PM | #2 |
Rep 1,219
Well this is good that someone has a tune!
So do you have a track or VBOX to test stock and tune? Why not go stage 2? It also sounds like you did this in person, I wonder if that is something he can also do remote? (Run logs?) Thanks |
08-18-2018, 07:54 PM | #3 |
Rep 201
Sub'd.
Great news. Glad some people are putting time into the G01 unlike certain larger companies |
TxHornX3M40iGuy128.50 |
08-18-2018, 11:44 PM | #5 | |
Rep 1,334
Yes they can do this completely remote..takes 10 minutes through OBD with an E-SYS Ethernet cable. But I had to go in ... they are about 50 minutes from me in SoCal ... since I had some complications from previously coding the car that prohibited the software from entering into Program Mode. Sorry guys...probably not dynoing or anything like that (I've done that a lot in the past with my track cars and have done lots of tuning...pretty much retired from it all :P ) But this is right up my alley...Fast enough for me to have a little fun and reversible to stock in 10 minutes from my own computer and Alexs' support is great.
08-19-2018, 12:30 PM | #6 |
Rep 394
What coding did you have done that caused a problem? I’ve had coding done on my car and Mission is doing my flash later this week.
08-19-2018, 02:12 PM | #7 | |
Rep 1,334
The problem was with my car cycling down ignition, like any BMW would, as the software inhibits programming mode. It needs to do this to allow the software to begin writing. But since I had coded my car to remember the last ASS mode there was a bug where the car would NOT cycle to ON with no ignition. So Alex induced that with his software/code and wrote it into the mFlasher software to perform it if it does not work from the cars commands. I will say I had some timing pull while we were logging since it was 100 degrees out and my car's IAT's were through the roof after a long drive to their office. Right now I will chalk that up to adaption and that I was on very old DME firmware that Alex has updated. So we shall see where the car nets out after a week or so or normal driving.
08-19-2018, 02:26 PM | #8 | |
Rep 394
08-19-2018, 11:54 PM | #11 |
Rep 1,334
Yes...this things holds boost wonderfully, if not conservatively. It's a touch over 18lbs at redline and still holding great AFRs!
08-20-2018, 11:47 AM | #12 | |
Rep 1,219
Stock boost was what? Last edited by GT500R; 08-20-2018 at 01:01 PM.. |
08-21-2018, 11:10 AM | #14 | |
Rep 321
Any increase in exhaust pops/burbles?
08-21-2018, 11:38 PM | #15 |
Rep 1,334
I'm in Pasadena...I'm sure it's going to feel a lot different than your F10 considering mine is AWD and so much heavier.
08-21-2018, 11:38 PM | #16 |
Rep 1,334
I want to say it's louder but so far it seems the same.
08-25-2018, 01:09 AM | #18 |
Rep 1,334
you mean besides me? Alex @ Mission told me he has done tons of B58s already...so many that he is backed up and has tons in his queue that he needs to catch up on.
08-25-2018, 11:11 PM | #19 |
Rep 964
08-26-2018, 08:24 PM | #21 |
Rep 1,334
You mean custom tune the car based on logs? If that's the question then yes.
08-26-2018, 08:26 PM | #22 |
Rep 1,219
