10-26-2021, 07:50 AM | #1 |
Rep 616
Going on 30 days at the dealer service department
So my X3M has been to the dealer several times in the past 2 months chasing an annoying (and sometimes very loud) rattle coming from the exhaust/rear of the car at idle and around 1,800-2,000 RPM.
- Visit 1 - 1 Day: Car was in for the annual oil change, and I mentioned the rattle. First they tell me all M cars "are supposed to be loud". After explaining that this is a very atypical sound and only recently started they took another look. Somehow they deemed the sunroof needed to be adjusted as the fix. - Visit 2 - 4 Days: On the drive home from visit 1 I realize the sound is still there. I come back 30 min later and leave the car again. This time I also bring a video to showcase the noise. They decide to change the full muffler section of the exhaust. - Visit 3 - 21 Days (On-Going): After 2 weeks of periodically hearing the noise, it came back full force. Back to the dealer it went, with another video. They first said they need to compare it to another X3M they had, which they confirmed that yes something was off. They then said the exhaust they put on at visit 2 must've been defective, so they ordered one from Germany which took some time to get here. After installing that, the rattle must've persisted because they then told me they also ordered a new driveshaft which also needs to come from Germany. The driveshaft is scheduled to be here by the end of the week (assuming that fixes it). 1. Has anyone else experienced this? 2. Is there any ground to get BMW FS to reimburse some of the lease payment? I'm paying for an $80k car while I've been driving a base model, last generation 3 series for the past month. Here is a video of the rattle: Last edited by Hoonigan; 10-26-2021 at 08:23 AM.. |
10-26-2021, 08:23 AM | #3 |
Rep 616
10-26-2021, 08:39 AM | #4 |
Rep 663
They should reimburse you. Happened a few years ago on my z4 when the top broke, and had to replace wiring harness, dealership had the car for 5 weeks. They took care of a month or two of payments.
10-26-2021, 10:11 AM | #5 |
Rep 862
Start the conversation now.
21 x3mC
Previous: 08 e90 M3, 02 e46 M3,2011 335is, 2016 AYM M3 |
Kevin_The_Clean13269.50 |
10-26-2021, 10:29 AM | #6 |
Rep 608
You need to use the search function. I know it sucks but all the of this has been talked about numerous times. None of this is news. Exhaust rattles, I've had mine changed and it was good for about 1k miles then came back although not nearly as bad. Paint on these cars is atrocious, most people have had bumper and spoiler repainted. There's a long list of stuff i won't get into it all, but you're not the first.
10-27-2021, 05:23 PM | #7 |
Rep 10,256
These "let's throw parts at the symptoms" exercises can be frustrating. The real concern is whether the dealer is on the right path to find the root cause.
The good / mixed news: during Visit 3 and 21 days later the dealer decided to compare your X3M with another X3M and confirmed differences. Why wait 21 days ... Find some time to speak with the service manager and document the meeting with an email and phone call to BMW NA. There is no substitute for paper work in these situations. |
10-27-2021, 10:24 PM | #8 | |||
Rep 616
cfm56d7b5886.00 |
10-28-2021, 12:25 AM | #9 |
Rep 328
Ouch, but how is this problem more than a day to diagnose? I don't get it?
See where the sound is coming from, identify part number, order and replace?!? If its not a loose component in the exhaust or the rubber exhaust mounting dampers... then work backwards towards the engine, cats, down pipes, turbos, exhaust manifold, the engine itself? I'm sure it's not easy, seeing you are touching the trunk to "feel" the vibration... its a legit issue... not the usual little inconvenience. Anything causing a noticeable vibration is either loose or broken, or and I really hope this isn't the case... a problem with the power unit and the exhaust pressure released. I just don't get how the hell its taking any mechanic doing their job, 30 days to figure this out... hang in there |
cfm56d7b5886.00 |
10-28-2021, 10:35 PM | #10 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,207
Definitely sounds like a defective weld inside the resonator. I've seen this with other mufflers as well, usually M Performance ones though.
12-08-2021, 10:51 PM | #13 |
Rep 1,041
Glad the car is fixed
But how does it sound like that while stationary and then have the defect part be the driveshaft?
2024 M2, 2024 CGT4RS, 2020 M2 CS, 2021 Macan GTS, 2017 Cayenne S, 2002 M Coupe |
12-08-2021, 11:02 PM | #14 | |
Rep 616
Based on the notes they disassembled everything you can imagine, but to no avail until they decided it was the driveshaft. I'm just happy to have the car back and not driving a base 330 |
12-09-2021, 10:42 AM | #15 |
Rep 562
