      05-23-2024, 04:03 PM   #1
Maximus_OM
Drives: X3M Competition Daytona Grey
Oil leak???
Just had my car serviced by my usual mechanic and he noticed an oil leak. He said it was coming from crank seal ?
Has anyone else seen this problem or had this problem? Should this be a concern?
It doesn’t look a lot. X3M is 3 years old and only covered 31,000 miles! So I’m shocked to see an oil leak..
Any help would be appreciated
      05-23-2024, 04:17 PM   #2
omniphil
Drives: me crazy, Woo Hoo
I literally just got back from the shop 30 minutes ago with the same issue, what are the odds...
Possible rear main seal from the location but it's a really small leak as it's still showing full on the oil gauge after 2000 miles.
They cleaned it and will check it again in 3000 miles when I get my oil changed again to see if it's come back.
2020 with 42000 miles.
      05-23-2024, 04:21 PM   #3
Maximus_OM
Oh wow what are the odds! Let me know how you get on
My mechanic didn’t have the time to fully investigate it as I needed the car back for holiday but il be taking back once I back
      05-24-2024, 02:12 AM   #4
Kevin_The_Clean1
Kevin_The_Clean1's Avatar
Drives: 2020 X3 MC
A RMS leak fix is an expensive job. Hope it's not that.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten
2011 E90 335i M-Sport - Daily Driver
2017 F87 M2 - Sold & missed
2020 F97 X3 M Competition - Finally arrived ///
      05-24-2024, 03:56 AM   #5
Maximus_OM
I’ve managed to get under the car and wipe it off. It was very easy and the oil was very golden coloured so thinking it is a recent leak…I’m going to monitor it now and see what happens and how bad the leak is.
      05-24-2024, 03:35 PM   #6
Maximus_OM
So I’ve managed to really have a look tonight and it appears the problem is bigger than I first thought….
I’m not sure if the pics are clear enough but had anyone got any ideas on how bad this is and what it is? It’s situated under the car right next to exhaust looks like the engine but maybe gearbox I can’t tell as I’m lying on the drive under car with a phone torch 😂
I’m off to drive up north for a holiday this weekend with the family…the oil isn’t leaking over the driveway or anything like that…will I be ok to drive it?
      05-25-2024, 07:27 AM   #7
Th3Walrus
Drives: 2020 X3MC Alpine White/Sahkir
If it's not dripping onto the ground, it's a small leak, and you'll be fine. If it's between the engine and transmission, it's your rear main seal. If it's only 3 years old, you have a 2021? Why aren't you taking it to the dealer instead of your 'regular mechanic'. Isn't it still covered under warranty?
      05-25-2024, 10:48 AM   #8
X4MC
Drives: 2021 X4MC
The same exact leak was noticed by the dealership on my nephews 2020 X4M, during a differential and transfer case fluid service at 30K. The service technician mentioned “not to be concerned” but will keep an eye on it. The dealer mentioned the CPO warranty may not cover the repair if it’s not actively leaking oil.
      05-25-2024, 02:05 PM   #9
Maximus_OM
Just outside of warranty bud, it was 3 years in January. I am tempted though to write an email of complaint to BMW UK as it’s disgraceful an M car with 32k miles and just over 3 years old is leaking
      05-25-2024, 08:50 PM   #10
95wildtt
Need mo $$s
95wildtt's Avatar
Drives: 2020 X4M Competition
There is another thread on this topic... FYI
https://x3.xbimmers.com/forums/showthread.php?t=2064922
2020 TRM-BLACK X4///M Competition
1995 Dodge Stealth TwinTurbo
Past: 2020 Macan, 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport
      05-28-2024, 12:49 AM   #11
Kevin_The_Clean1
Drives: 2020 X3 MC
I would surely do the same thing if my X3 MC experiences the same thing at that low mileage level.
      05-28-2024, 09:07 AM   #12
omniphil
Mine is a 2020 and is still under warranty. Its 4 years/50k isn't it?
      05-28-2024, 09:32 AM   #13
95wildtt
Need mo $$s
95wildtt's Avatar
Correct.
      05-28-2024, 09:07 PM   #14
DBU
DBU's Avatar
237
Drives: 2022 X4MC - Marina Bay Blue
Warranty is 4 years. Maintenance is only 3 years, no??
'22 ///X4M Competition - fully loaded Marina Bay Blue.
Lowered on MSS springs. 20" x 10 ET20 Vertini RFS1.2 wheels wrapped in Firestone Indy 500 Firehawk 275/40 tires (square setup).
Hers: '15 X4 2.8i - Glacier Silver - loaded M-Sport
      05-29-2024, 02:11 AM   #15
Maximus_OM
UK is 3 years or 100k….i got a letter stating it was out ☹️
      06-26-2024, 10:18 AM   #16
Maximus_OM
So the car went in to bmw today for investigation at £120! They’ve had it day and just called me to say they can find the origin of the oil leak and they think it’s just oil sweat?!?! Oil sweat what the f**k is that?! Sounds like bollocks! I told them I’m refusing to pay £120! They’ve investigated nothing
Anyone ever heard of that BS?!
      06-26-2024, 10:44 AM   #17
Potatohead-M2
Potatohead-M2's Avatar
285
Drives: X3MC
It's a rear main leak, it's a BMW, this is basically par for the course lol. You can either live with it and add oil when necessary, or fix it. Unless you run it low on oil you are not going to damage anything.
Sucks they won't cover it, it is a big enough job, transmission needs to come out.
      06-26-2024, 10:47 AM   #18
Maximus_OM
I’m not that familiar with bmw engines so basically it’s prone to it and I’ve just got to keep an eye on it
      06-26-2024, 11:12 AM   #19
Potatohead-M2
285
Drives: X3MC
You're not going to hurt anything by waiting. If it starts dripping on the ground, it might get annoying. The vehicle will let you know when/if the oil is down by one litre, then you can add another, if it gets to that point. You can also check the oil level through the idrive system every few weeks if you want to be proactive about it.
      06-26-2024, 03:03 PM   #20
Maximus_OM
Thanks very much for your advice makes sense and makes me feel a bit less stressed about it
