XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum CARB approved charge pipe for n55?
      06-17-2021, 03:07 PM   #1
spelk3
Confused Member
spelk3's Avatar
Drives: BMW X3,i3,i3; Harley FLSTF
Is there a CARB approved charge pipe for the X3 with the n55 engine? COBB has one that doesnít fit the X3.
      06-20-2021, 09:30 AM   #2
Phantom10R
Check out my Youtube @n55david!
Drives: 2015 335i, 2015 X3 x35i
doubtful. the certification is too expensive for a small volume product like that. nobody checks them during inspections because it's not easy to get at nor see and most people wouldn't know the difference anyway.
2015 335i xDrive 11.76 on stock turbo. (dragy) uphill!
2015 X3 x35i 12.96 catless w/bm3 stage 2 93 flash
IG: @N55David For pics and updates!
Youtube: @ n55david For videos or Racing etc
      06-21-2021, 03:48 PM   #3
spelk3
Confused Member
spelk3's Avatar
Thanks. Living in California the smog inspection is mostly a thorough visual inspection (they read readiness via OBDII) and anything not stock without a CARB certification is instant failure.
Since the charge pipe is a common failure I’m hoping to find a certified replacement as a preventative measure.
COBB is the only CARB certified one I’ve found so far and it doesn’t fit the X3.
      06-21-2021, 11:00 PM   #4
Phantom10R
Since the charge pipe is a common failure I'm hoping to find a certified replacement as a preventative measure.
COBB is the only CARB certified one I've found so far and it doesn't fit the X3.
okay.
do they have one for an f30 n55 xdrive auto? if yes, buy it. it works just fine and is the same part
      06-22-2021, 11:20 AM   #5
Bdavi011
Drives: 2013 BMW X3 3.5i
I live in Socal and my x3 was smogged this year and they didn't say anything about my FTP charge pipe. As far as I know, it's not carb approved.
      06-23-2021, 07:26 PM   #6
spelk3
Confused Member
spelk3's Avatar
Originally Posted by Phantom10R View Post
okay.
No luck there. From COBBís webpage for the n55 charge pipe: **Will not fit F-chassis vehicles.**
Thanks for that information. Might be worth the risk for the peace of mind.
      07-02-2021, 12:50 AM   #7
hellokitty
hello kitty oke?
hellokitty's Avatar
Drives: '17 M3 ZCP DCT | '12 335iS DCT
2012 BMW 335iS  [0.00]
2017 BMW M3  [0.00]
Just get something that looks like OEM with no logos showing. The techs wonít know or care as long as it isnít flashy.
      07-04-2021, 06:51 PM   #8
spelk3
Confused Member
spelk3's Avatar
Just ordered the ftp charge pipe. I’ll paint any logos with black high temp paint to help keep it stealth.
      07-14-2021, 11:10 PM   #9
spelk3
Confused Member
spelk3's Avatar
Anyone with a COBB charge pipe on their 135 or 335 that doesn’t live in California want to get rid of your CARB D-660-31 sticker?
MHD stage1, xHP stage3, Continental ExtremeContact DWS06
      07-15-2021, 10:35 AM   #10
hellokitty
hello kitty oke?
hellokitty's Avatar
2017 BMW M3  [0.00]
Anyone with a COBB charge pipe on their 135 or 335 that doesn't live in California want to get rid of your CARB D-660-31 sticker?
Maybe you can reach out to Cobb and ask for one
2017 F80 M3 ZCP / ARM Resonated DPs / Akrapovic Evolution / Bend Calibration Ultimate / Bilstein B16 DDC / BM3 Stage 2 (Cary Jordan) Flex Fuel / BMS OCC / CSF Heat Exchanger / One Piece Crank Hub
      07-15-2021, 01:53 PM   #11
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
probably a bigger fine to falsify a CARB sticker than to fail smog inspection...
Current: 2011 X3 35i M-Sport, Deep Sea Blue Metallic/Oyster, HUD, aFe intake, RaceChips Ultimate, FTP pipes, Sprintbooster, Class III hitch, Ultra Racing Strut Tower Brace, xHP trans flash, F80 ///M steering wheel, GFB DV+, akebono ceramic pads/centric cyro rotors, Koni Special Active Struts
      Yesterday, 12:46 AM   #12
spelk3
Confused Member
spelk3's Avatar
Yea, probably is a bigger issue.
I was sort of joking, it’s just annoying that an OEM part with known issues is not legally replaceable with a stronger aftermarket part.
I pealed off the Ftp stickers, just a black pipe now. Just waiting to get it installed after having unscheduled back surgery last week. Currently I can’t even drive.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
