07-08-2020, 11:31 AM | #1 |
Rep 641
I'm tuned with BM3 Stage 1 - E30, v2.4.
Is anyone running aftermarket plugs? For my past 335i, tune and ethanol fuel i'd always run NGK plugs with a smaller gap to avoid misfiring. So far no issues, but I wonder if it would benefit and help keep timing more consistent across cylinders.
X5 40i
07-08-2020, 12:54 PM | #4 |
Rep 146
I have for my M5, went with ngk cold plugs and gap at .020
Oh, I also talked to Troy Jeup and his recommendations are to change the thermostat and use 5w-50 for oil. |
07-08-2020, 03:02 PM | #5 |
Rep 1,219
Who is Troy Jeup?
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
07-08-2020, 03:12 PM | #6 |
Rep 146
He rebuilds a lot of E60 M5, I was going to have him build me a 4.6L for my F10 M5.
https://www.instagram.com/troyjeup/ |
07-08-2020, 03:43 PM | #7 | |
Rep 1,219
07-08-2020, 04:19 PM | #8 | |
Rep 155
2020 Dark Graphite Metallic x3M Competition
Mods: BM3Tuning x Paul Johnson Tunes Custom Full E85 stage1+, MSS Adjustable Springs, AutoTeknic Matte Black Paddle Shifters, RG Front paint-matched reflectors, H&R 15mm F/R Spacers. IG: _x3M_Competition |
07-08-2020, 06:10 PM | #9 | ||
Rep 641
X5 40i
FSociety3812.50 |
07-08-2020, 06:11 PM | #10 |
Rep 146
07-10-2020, 12:39 AM | #11 | |
IG @bmwF9xG80
3813
Rep 7,593
Same lol, 10.80@127 and 10.87@127mph full tank here on 21s
60-130 8.10s on 2.3 Going to update to 2.4 its even better i hear Quote:
It is recommended at the moment to stick to OEM plugs, I've actually seen a lot of cars under-performing with NGK 97506 (Most Popular Fxx series plug) when used in B58 engines. Road smoothness (or if you have traction on it will just cut power at times it notices slip), If you're hitting bumps this will cause it too. Most importantly is Fuel Quality
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 07-10-2020 at 10:29 AM.. |
sd306380.50 |
07-10-2020, 09:43 AM | #12 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
12-08-2020, 04:46 PM | #13 |
2314
Rep 2,885
Bump to hear any updates. Anyone change out the plugs on tuned X3 for any benefits?
12-08-2020, 05:57 PM | #14 |
Rep 641
Mission Performance said I can just re-gap (to .024") my existing plugs (should be NGK stock) in the 2020 X4M I have ~13K miles on them for the MP e50 tune. I just bought their e50 tune today.
I am going to re-gap the plugs (will grab model number in the process) and leave my BM3 e30 OTS tune and see if anything is better (log wise), then will flash back to stock, then flash the new Mission Performance E50 tune. |
GT500R799.50 |
12-08-2020, 09:10 PM | #15 |
Rep 641
F97 & F98 - S58 - Removing and Installing Spark Plugs Guide
Spark plug install/removal guide since newtis is down. Reuploaded new version that isn't cut off. Attached.
It doesn't mention disconnecting the battery - I recommend doing that before you start (leave the doors unlocked, trunk open, and place a towel where the trunk latches just in case) as you unplug/plug in connectors as a part of the install - not just the coils. Last edited by sd306; 12-11-2020 at 09:42 AM.. |
12-12-2020, 02:05 AM | #16 | |
Rep 641
-ngk silzkgr8e8s -other info on the plugs: m977, R5, Japan, BMW -gapped at .029"-.030" -10K miles (8k tuned miles on BM3 Stage 1 E30) (see pictures) BM3 Stage 1 E30 OTS with stock plugs re-gapped to .024" (stock was gapped at .029"-.030"): https://www.bootmod3.net/log?id=5fd2...0b436304ff6033 -timing seems a bit better -felt like it had a bit more "pep" |
12-12-2020, 02:09 AM | #17 | |
Rep 641
Max Well4734.50 floating.spirit1017.00 |
12-12-2020, 07:32 PM | #18 | |
IG @bmwF9xG80
3813
Rep 7,593
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
sd306380.50 |
06-18-2021, 02:03 PM | #21 |
Rep 641
Should be the same after replacement, i have new tires (295s rear)and won't launch it since I want to keep things in tact 🤣 265s on the rear went 2.94 0-60.
X5 40i
06-18-2021, 07:19 PM | #22 |
Rep 3,904
For an X3MC that isn't tuned, what do you think is an ideal interval to change plugs at... ?
I'm still learning a lot about the new S58. The N55 in my E90 M-Sport has a BMW Stage 1 PPK installed from the dealer & the upgraded package came with a "change spark plugs every 45k" decal under the hood. Kind of as a dummy reminder, just in case I guess. LOL
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
