01-15-2020, 11:55 AM | #1 |
Rep 33
Dead Battery
Hi guys. My wife's new 2020 X3M has 980 miles on it. When she got in it this morning it was dead. When I checked the voltage a few hours ago it read 5.9 volts and now it is down to 2.8 volts. I tried to put my battery charger on it, but it acts very funny, almost like a dead short. The needle on the charger swings wildly from zero amps to above the ten amp max.
I've called roadside service and they're on the way. The thing is, the car is pulled into my garage head first and too dead to get it into neutral. Is there a way to mechanically get it into neutral? I was going to put a new battery in it, but I don't even know where the battery is. Any advice? Should I let the wrecker try to drag it out of the garage while it is in Park? |
01-15-2020, 01:11 PM | #2 |
Rep 2,525
I'd run your questions by your Svc Advisor before roadside assistance arrives if there's still time, but as far as battery location:
https://www.newtis.info/tisv2/a/en/f...ery/1Vnc7bLk1v And battery description: https://www.newtis.info/tisv2/a/en/f...ery/1VnYsMPZJq As I don't have any electrical background I've always left everything up to the Svc team when I've had dead batteries in the past. I think they have to re-register the battery with the system with software and possibly other actions (maybe others can comment). As far as unlocking the transmission lock, again - no experience, but p. 141 of Owner's Manual describes 'Electronically unlocking', and they state "unlocking is possible, if the starter can spin the engine". So if they can jump it then try that procedure? Suspect roadside assistance have come across that before. Others with more electrical/mechanical knowledge can provide better answers I suspect, but I noticed you didn't have any replies so thought I'd share. |
ando2000.50 |
01-15-2020, 01:30 PM | #3 | |
Rep 10,249
01-15-2020, 03:08 PM | #6 |
Rep 33
I found my longer jumper cables and was able to jump it off with my Raptor before the wrecker arrived. There was an amazing arc when I made the last jumper cable ground connection on the X3M, like something was trying to draw a lot of power.
The service advisor lady said to always lock it, even in the garage. She said if it can sense the key nearby it could turn on computers and walk up lights and drain the battery that way. I’ll definitely report their actual findings. They agreed to do the run in service too. It was at 1001 miles when I got it there. Last edited by Ironwood; 01-15-2020 at 07:34 PM.. Reason: Grammar |
01-15-2020, 03:35 PM | #7 |
Rep 2,525
Glad you're getting it worked on. And FWIW, I've been using a BMW trickle-charger every two-three weeks on our X3MCs, and it usually takes a solid 12-14 hours' overnight charge to turn green (bought some years ago after a few dead batteries with our F25 models, and no issues since, knock-on-wood).
01-15-2020, 05:03 PM | #8 | |
Rep 2,220
I don’t have a great deal of faith in this battery with the massive amounts of draw when off but I’m hoping more driving will help avoid having to charge. |
01-15-2020, 07:04 PM | #9 | |
Rep 2,525
Apparently newer technology doesn't have as much regenerative capacity unless coasting in gear or braking, and on an extended highway drive when those activities aren't used, then battery charge is actually being used to run the USB laptop, sound system, iDrive, Driver's Assistance cameras, parking assistance, cruise, security system when locked, ... Or so I was advised. Whether true or not, made some sense - as when we'd drive we would only see the regenerative technology bar in the instrument cluster reach the light blue after an extended coast or braking. I honestly have no idea as zero background in any of the science behind it. And one might argue that too much charging of the battery may actually lower the lifespan? But supposedly trickle chargers and this type of battery are different? So as you can tell I have no idea, but I'm glad I have the charger, joking with my wife that I'm enjoying our plug-in vehicles. |
01-15-2020, 09:29 PM | #10 | |
Rep 2,220
I used to have an E46 M3 and it was on a trickle charger most of its life. The original battery lasted ~10 years so I don’t think over charging is an issue as long as the charger shuts off. The one I have connects to the battery terminals and can jump start. The regenerative indicator - is that on the F97s? If so, where do I find that? Alternators are run by the belts (or used to be) so they should be charging the battery when ever the engine is running - not sure if that changed. My X3Mc is such a hog for electric power with all the features so now I’m worried. |
01-16-2020, 06:39 AM | #11 | |
Rep 1,924
but i havent looked at our car |
01-16-2020, 09:42 AM | #12 |
205
Rep 668
I thought the regenerative stuff from coasting and braking was just that eco dynamic stuff. Not instead of an alternator but in addition?
Regardless, I've not had to use a charger since my 10 year old 1981 Vauxhall Chevette. Certainly not on the past 3 BMWs. So far my X3MC is fine too. |
01-16-2020, 10:35 AM | #13 |
Rep 1,924
01-16-2020, 02:00 PM | #14 |
Rep 33
The dealer texted me. Bad battery was the verdict. My wife drives it about 25 minutes each way to work daily. That should definitely be enough to keep the battery charged. Thanks for the help everyone.
01-16-2020, 03:08 PM | #15 | |
Rep 192
2021 Cayenne GTS * 2021 AMG GLE 63
2019 911 Targa 4 GTS, Carrara White Metallic 2008 911 Turbo Cab, Speed Yellow 1997 911 Targa, Zenith Blue 2017 GT3-RS Lava Orange (LEGO) |
kzg19691299.00 |
01-16-2020, 04:28 PM | #16 |
Rep 69
01-16-2020, 04:33 PM | #17 |
Rep 69
As for the battery on M cars, had an F10 M5 for 3 years followed by F80 M3 for 3 years followed by current X3M. Mostly driving 5 miles each way to work (I know, a bit pointless having an M for that!) but have had zero battery issues.
01-16-2020, 04:58 PM | #18 |
Rep 2,525
If you follow some of the links in the newtis files here is a description of the alternator (not that it helps for someone as myself who has little background in this area): https://www.newtis.info/tisv2/a/en/f...tor/1VnYBm17uW
I've not seen the 'regenerative bars' in our F97s as we had in the G01 X3 M40is, so can't comment on whether anything has changed as to how the alternator sends energy back to the battery. And I don't wish to make it sound as though these are 'plug-in hybrids' by any means, I just recall being told about long drives (when using USB to charge phones and laptops, stereo, etc), that the battery drain is more than the charge can maintain so battery issues may develop and a trickle-charger can assist in preventing such. Hence one was purchased. The cost is minimal and I can't believe that was a sales pitch (but it could have been), and since we've used it over the years we haven't had an issue. Totally unrelated is absolutely possible and seems likely. But I do remain puzzled that both of our G01 X3M40i models, and now both of our F97 X3MC models, can sit on a 14 hour charge every two to three weeks and go from red to just blinking green (happened last night on my wife's). This seems to indicate that the battery control system operates just fine at a less-than-optimal charge for the duration of a vehicle's life. Again, I continue to share my lack of knowledge about this - just reporting experience. Would be interesting to see if others who are plugging into an approved trickle charger (note the requirements of slow charge as stated in the manual and tech data) have the same 12-14 hour charge times. I suspect those times will be similar. Does it matter from an operational standpoint? Probably not. I just haven't seen any data to suggest I shouldn't continue plugging them in, as long as I'm not damaging anything. |
01-16-2020, 05:11 PM | #19 |
Rep 21
SNAP!
My battery died on mine too. I think it was from cleaning the car (walking by the car when I was washing it on day one and in and out of the car cleaning the interior on day two). I had my keys in my pocket on both days and obviously have comfort access. The recovery guy cam and jump started from a battery pack. On the diagnostic it said replace battery but the dealer has tested it and said it doesn't need to be replaced. Pain in the ass but hey shit happens. |
01-16-2020, 05:31 PM | #20 |
Rep 4,703
Same, unless the battery defective you won't have an issue.
01-23-2020, 12:42 PM | #22 |
Rep 33
Well, this morning the battery was dead again and my wife's new X3M wouldn't start. The new battery lasted one week. She put 100 miles on it in four trips to her work and home again. Had to take my wife to work, jump it off and take it to BMW again. By the time I made the trip to the dealership, it was charged up and would start every time. The tech thinks maybe my wife is still leaving it unlocked in the garage and the radio on playing her CD all night. I find it difficult to believe that shutting a $80,000 vehicle off with the button and walking away will kill the battery. They're claiming you have to lock it every time, keep the key far away, press and hold the radio off button, and not leave any papers in the seat. But they said they would investigate and call me in the morning.
