XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum Tail Light STILL not working after fix
      10-05-2018, 08:35 PM   #1
crosis
Drives: 2011 BMW X3 (x35i)
Question Tail Light STILL not working after fix
Vehicle: 2011 BMW X3 (F25) x35i
The right rear tail lamp (the led bar) is not lighting; it is the inner lamp not the one on the tailgate. The turn signal light works. The brake light works. I've already replaced the LED control board with a new Mean Well LDD-500L led driver.
Referencing the photo below I applied 12v battery power to the 2 gold leads. Nothing. I checked voltage from the very thin black / gray wire (located at right) and the very thin pink / red wire (located at right); attaching my multimeter + and - leads to those to locations on the driver produced 12.1 volts. It appears to be passing power from the Vin side to the Vout side.
Could my issue be a bad fuse which controls JUST the led bar within the right rear tail lamp? Sounds unlikely but i'm all out of ideas. I have to assume the led light died. And for the record i cant make any sense of the heiroglyphs of the BMW fuse chart or wrap my head around why there is a fuse box within my glovebox and another in my trunk.
Thanks for any tips
      10-05-2018, 09:15 PM   #2
Commerce
Drives: 2019 X3 M40i
I had the same thing happen with 3/4 rear LEDs, the turn signal and brake lights would work but the LED bars would not. I purchased a new set of identical LED drivers from eBay and it was a simple plug and play.
Is this the only tail light you have tried to fix? The issue could be related to the Mean Well or soldering.
      10-06-2018, 12:17 AM   #3
crosis
Question
Thanks for the reply.
This is my first go at replacing the led driver. I ordered 4 led drivers (Mean Well LDD 500-L) and replaced the right tailgate light. It worked fine. But my second attempt, this rear side light, has failed.
I will try desoldering and doing it all again to see what happens.
Is there any chance the led tubes could be toast?
Thanks.
      10-06-2018, 10:33 AM   #4
nonot
Drives: 2016 X5 M Sport
https://www.bimmerpost.com/forums/sh...php?p=22358308
2016 X5 35i F15 (Prod.date 2015-10-01)
2014 X3 2.8i F25 (Prod.date 2013-10-25)
2006 X5 3.0i E53 (Prod.date 2006-04-05)
2008 X3 3.0si E83 (Prod.date 2007-10-23)
      10-06-2018, 11:07 AM   #5
Commerce
Thanks.
I'm doubtful that would be the case but the best way to test this would be connecting a driver/board that you know works.
      06-14-2021, 11:03 AM   #6
neelkc12
neelkc12's Avatar
Drives: x3
2011 BMW X3  [0.00]
Tail light STILL not working after the fix
Is there a fuse for left turn signal. Just like OP by rear left module went bust. I followed exactly what I done before -replace the board witha LDL driver - tested the module by attaching to my right - tests fine. But when connected to the original left connector - no lights at all . Dash chirping at high rate - same for a gone bulb.
      06-22-2021, 07:20 PM   #7
Rounde1Head
Drives: BMW X3 F25
looks like LED tail is dead. I had the same thing. In the left part, replacing the board helped. In the right after a while, no. I had to change it completely
      06-23-2021, 06:15 PM   #8
neelkc12
neelkc12's Avatar
Drives: x3
2011 BMW X3  [0.00]
update on x3 Tail light saga
After fixing up the rear tail light - It still did not work - I had to go to the dealer. -
The fix was the hardness - BMW replaced it @170(inspection)+370
My eye could not tell - apparently harness connectors was corroded.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
