01-20-2020, 08:48 PM | #2 |
Rep 814
I forget. How many miles is the battery good for?
I’m not too knowledgeable on these PHEV’s but correct me if I’m wrong, after the battery runs out the vehicle drives sluggish with very slow acceleration, right? |
01-21-2020, 09:22 AM | #3 |
Gravity Sucks.
172
Rep 213
No, Not at all. It drives just normal. Keep in mind regardless of if you have a full battery or not, the primary powerplant is the ICE (Internal Combustion Engine). The Electric motor assist the ICE and improve fuel economy,add extra powerboost as needed and is also able to drive the vehicle for shorter distances. This is not an electric vehicle so vehicle operation stays normal.
01-21-2020, 09:12 PM | #4 |
Rep 814
I recently read this...
The X3 shares its hybrid powertrain with the 330e sedan, which means the core components consist of a 2.0-liter turbo-four engine, an electric motor integrated into the eight-speed automatic transmission and a 12.0-kilowatt-hour lithium-ion battery pack under the rear seat. Total system output is 252 horsepower, with the 0-62-miles-per-hour run pegged at 6.5 seconds and top speed set at a healthy 130 mph. The electric motor is rated for 80 kilowatts, equivalent to 107 hp, which is just a bit behind the 330e's motor rating of 83kw. So do I understand this right?....So when the electric motor runs out of electricity isn’t the vehicle running from the ICE engine only which is 252 - 107 = 145 horsepower? The X3 putting out 145 horsepower would feel sluggish and have slow acceleration? Right? |
01-22-2020, 03:41 AM | #5 | |
Rep 100
The 30e has a petrol engine of 184hp and electric engine of 109hp. The combined effect is 292hp(with a boost function which lasts 10seconds or so) without boost the combined effect is 252hp. But generally for overtaking the boost should be enough. If you want a track/performance car one probably should not look at a hybrid…. 😊 Very often with hybrids you can adjust the settings so that the car leaves a percentage of the battery untouched for maintained performance for acceleration and overtaking so if you are afraid of the 184hp standalone petrol engine not being enough you can always ensure the power like that. The cars charge back some of breaking power etc to the battery so that will also charge up the battery during driving. |
01-22-2020, 06:10 AM | #6 | |
Rep 271
Alias1431795.00 |
01-22-2020, 08:12 AM | #7 | |
Rep 100
BarlasaM172.00 |
01-22-2020, 06:00 PM | #8 |
Rep 814
Yea, I’m afraid the 184hp standalone engine won’t be enough for me. I’m going have Toyota RAV4’s and Hyundai Tuscans passing me on the on-ramp.
I would love to purchase the X3 30e but my daily commute is 30 miles, each way, with no charging station at work. So I would be running the standalone 184hp for more than I like. |
01-23-2020, 02:28 AM | #9 | |
Rep 100
When it comes to “running the 184hp standalone”. In case you are nervous about not having the full power(292hp) and are okay by consuming petrol a large part of the way, then you should be fine in case it is not super aggressive driving you want to do. So no worries about the Toyotas or Hyundais. You can run the car so that it leaves a fair bit of power reserve on electric engine and runs on petrol when you do not have enough battery and the electric motor just jumps in when you need the extra power( e.g. motorway ramps). In general driving in hybrid mode the car knows when to use electric and petrol. But it will never be an M40i, for example when it comes to sound and speed, if that is what you are looking for. |
01-23-2020, 03:09 AM | #10 |
Rep 744
The battery of the PHEV drive will never be empty. It's constantly charged by the generator and/or recuperation. So there is always the full power of the drivetrain available. If the battery is empty this will affect the fuel efficiency and the car can not run on electric power alone.
In addition if you charge the battery over night at home you can drive on full electric drive in the city with 0-emission. So the benefit of a PHEV is to do short distance city trips with full electric drive resulting in low emissions as long as the electrical power comes from environmental friendly sources like solar or wind. |
01-23-2020, 04:37 AM | #11 | |
Rep 100
02-02-2020, 12:05 PM | #13 |
IS350 to IS-F to M3 and M4
117
Rep 803
I see production is starting as early as March first. I'm eager to see the real world all electric range for this and the X5-45e. Anyone placing an order?
