06-08-2020, 05:44 PM | #1 |
Rep 14
M40i or All X3 - Driver side water leak
Hi, I have a well maintained and low mileage M40i bought July 2018.
I am very happy with it and even the rattle in the passengers side dash board has disappeared so I was feeling like it was a problem free car...but In the winter last year I had to leave the car on the roof of a airport parking garage and when I returned the drivers foot well had about half an inch of water in it. It had been raining exceptionally hard in the 3 days I was away and very windy. There was no water on the sides of the foot well nor any where else, like a roof leak. But there was water in the deep snow mats and under the snow mat the carpet was soaked, again only on the floor not the sides. I dried it out and the garage said they could not find a leak. Now, even though I have hardly used the car in these COVID times, the carpet under the mat is very wet again. We had a series of thunder storms in the week previously which are accompanied around here by some blustery winds. I pulled the mat and dried it out again. As before no signs of any water coming in from the sides of the foot well. I know water can find its way in through many different routes and the leak maybe a long way from the wet carpets. Anyone else experience this problem? Any pointers I can give the garage when I tell them about this leak? Advice appreciated Richard |
06-08-2020, 06:07 PM | #2 |
Lucky13
211
Rep 1,762
I remember reading something similar in either Car and Driver or Motor Trend where their long term X3 M40 had a leak. Seems like it was the drain plug was plugged up for the sun roof but you should try and find the article, been in the last year but I can’t remember which magazine or issue.
06-09-2020, 04:22 AM | #4 |
Rep 179
Just to eliminate this, all cars with AC may leave a little puddle of water as it’s the condensate from the AC system. This normally appears after the car has been in use. I’ve had people point out to me I’ve got a leak when it’s actually been condensate from the AC.
Obviously if the car has been standing at an airport or in a garage for a period of time, then it’s unlikely to be this.
2020 X3 M40i Carbon Black.
06-09-2020, 08:40 AM | #5 |
Lucky13
211
Rep 1,762
A quick google search showed it was Motor Trend had the problems, first time was at the car wash where water was coming through the area around the center console with light switch in the roof. I know they talked about the fix and issue in several updates of their 2018 model.
06-10-2020, 08:23 AM | #6 |
Rep 3,552
have them check to see if the sunroof drains are blocked.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
06-13-2020, 04:55 PM | #7 |
Rep 14
Thanks for all the responses. I really appreciate the feedback and desire to help.
I may have found where the water is coming from. I use the car once a week during lock down so its been easy to monitor it and check after light and heavy rain. Two days ago we had a light shower so as soon as it had stopped and the sun was out I was out looking. On opening the door I found a small puddle in the winter mat but also the carpet underneath was wet again. I saw water dripping down the hood release catch. Depending where the drip released from the curved released catch depended it hit the car mat, or released early, and hit the carpet by the side of it. I then saw that I had water ingress between plastic panels on the side of the console where the door closes on to. See photos, II suspect I have a leak in the windscreen edge somewhere. I plan on giving the garage a call Monday and fighting my way through the COVID reluctance to do anything else but servicing and tire changing. https://x3.xbimmers.com/forums/pictu...ictureid=75544 https://x3.xbimmers.com/forums/pictu...ictureid=75545 |
06-20-2020, 11:37 PM | #8 |
Rep 2,049
Totally unrelated, but this exact symptom is what i'm going through with (older) e46 and e39, worn out vapor barriers...
Hopefully our g01 cars don't have this crappy barriers with butyl tapes... |
06-21-2020, 08:02 PM | #9 | |
Rep 1,122
06-22-2020, 09:50 AM | #11 | |
Rep 2,220
I recently had this on my Nissan Armada (due to a poor drain design) where the passenger side rug was soaked under my rubber floor mats. I installed a new drain line and sealed with RTV silicone and I see the water dripping out where it is supposed to. Next step is to ensure it stopped the leak at the inside. Sometimes drains can get plugged as well. |
07-09-2020, 03:53 PM | #12 |
Rep 14
Update: After it got worse I fought through the COVID hassle and took the car back in. I didn't take long to call me back and tell me that the sun roof was leaking. The ingress route was in through the roof, inside the liner, down the windscreen piller on the drivers side and then out near the door and onto the floor.
They had the car 2 days and claim its fixed. They had to replace sealing parts around the sun roof. I will update when it rains. Also, for info, the wireless charger was replaced as it was incorrectly reading too hot and shutting down. The new one worked all the way home so I will see long term. |
07-09-2020, 03:54 PM | #13 |
Rep 14
