03-19-2020, 07:08 PM | #1 |
Rep 1,314
Starting the project of adding in heated seats in my 2016 M sport X4.
Coding done via: Steve Ma at Code my Bimmer. ($25 per session). Driver seat module coded and Junction box coding for the passenger seat. I will continue to update this post. Parts List: Climate control panel(Used) - ($60) 1x Passenger and 1x driver seat module(Used) - $120 total. 2x Base Seat backs (64117240107) - $120x2 2x sport seat bottoms (64117249283) - $135x2 2x sport seat extender (64117240114) - $45x2 1x connects- 611 313 837 76(under seat connection to junction box)- $.055 1x Double Flat spring connectors for rear fuse connection( 61 13 0 007 440) - $3.43. Total - $808.48 excluding wiring, hog rings/Zip ties and a few tools. New wiring 2,5mm wiring from rear fuse(Fuse189) for passenger seat module. ,35mm wiring from passenger junction box to passenger harness connector. Last edited by SM2; 01-08-2021 at 09:13 AM.. |
03-19-2020, 07:12 PM | #2 |
Rep 1,314
03/19/2020- Currently waiting for passenger parts to come in.
Current issues: Seat belt light turns on after adding in bottom heated seat element. Possible solutions: - code out seat belt alert - Reset weight for the passenger seat. |
04-22-2020, 10:25 PM | #5 |
Rep 1,314
Passenger seat completely heated!
Wiring from rear fuse locations 186-189 one per each seat module. Then wiring from seat to yellow PIN number 9(fuse together). A little extensive but not too bad overall. Last edited by SM2; 01-08-2021 at 09:07 AM.. |
evilchargerfan269.00 |
05-19-2020, 10:17 PM | #7 |
Rep 1,314
06-06-2020, 03:14 AM | #8 |
Rep 6
Impressive work! I own a 2014 X3 and I am also considering to add heated seat to my car! Thanks for your sharing! However, I managed to find a pair of seats with heating function on ebay, so I plan to swap two front seats instead of removing the leather of my seat. In this case, I definitely need a new climate control panel, but do I need to do the wiring or I can just plug the cable under the seat to my swapped new seats? XD
SM2731.50 |
06-06-2020, 09:31 PM | #10 | |
Rep 1,314
oliverzhc1.50 |
06-07-2020, 01:46 AM | #11 |
Rep 6
Thanks for the info! I will do some research before going forward!
07-01-2020, 01:38 PM | #12 |
Rep 6
Hi it's me again.....
I bought two seats with seat heating and lumbar support (my original seat does not)from ebay and installed them on my vehicle. The adjustment of seat height and seat back worked but the lumbar support and heating controlled failed. Does this mean I should also do the coding? Or should I add a fuse to somewhere else other than the bottom of the seat? Thanks for your help! PS: I just installed and tested for the passenger side. Any difference for the driver side? |
07-01-2020, 04:00 PM | #13 |
Rep 2,546
Pretty sure you need to VO code options you add to you vehicle for them to work. I can't speak to the wiring. Here's the codes:
07-01-2020, 04:09 PM | #14 | |
Rep 1,314
Reach out to Steve Ma at Cody my BMW. Driver side as long as it has the proper seat module and coding will work. The passenger side will need to be wired in though. One wire going from the rear Fuse carrier to the seat and a wire going from the passenger seat to the front junction box to the seat. But, passenger seat does need a module and harness which I found used on ebay. Last edited by SM2; 01-08-2021 at 09:17 AM.. |
09-27-2020, 04:02 AM | #15 |
Rep 335
What is the total cost including and excluding seats? I'm assuming you used the seats that came with the car.
Nevermind, I saw your older post with the cost of parts. I too found a brilliant X4 I want to buy but its missing the cold weather package. I feel it is a must for roughly 8 months out of the year here in Washington state but probably not nearly as much as you need them in Chicago. Might have to pass on this one because I'd really like the heated steering wheel as well.
2010 135i M-sport SOLD
2019 X3 M40i Glacier silver w/cognac Last edited by Skotcoop; 09-27-2020 at 04:09 AM.. |
09-27-2020, 08:48 AM | #16 | |
Rep 1,314
Skotcoop269.00 |
01-08-2021, 09:14 AM | #17 |
Rep 1,314
Update: Currently dealing with a problem with the passenger seat, not heating. Running into a LIN Slave issue. I Will attempt to recode the JBE.
01-08-2021, 09:15 AM | #18 | |
Rep 1,314
01-09-2021, 12:03 PM | #21 |
Rep 6
Nice work - I’ve today just managed to install a heated steering wheel into our X4. Relatively straightforward with the right parts (some work on RealOEM needed to get the correct part numbers).
Keep up the good work, you’ll get there with it 👍🏻 |
SM2731.50 |
01-09-2021, 12:25 PM | #22 | |
Rep 1,314
Have mine setup too just waiting for a used steering wheel. |
